Nissan DLR put 0w20 in car that specs 5w30. worry?
by CrAlt
06/17/18 10:40 PM
revive Nicd battery
by Donald
06/17/18 10:27 PM
Need help finding an apartment for friend
by RazorsEdge
06/17/18 10:07 PM
ceratec with redline 5w30?
by 08z06
06/17/18 09:53 PM
does your COMCAST modem have weak wifi??
by edwardh1
06/17/18 09:50 PM
I hate stuck thermostats
by jakewells
06/17/18 09:49 PM
Mag1 75w90
by SavagePatch
06/17/18 09:32 PM
Old batteries at HD
by bbhero
06/17/18 09:27 PM
Buying a CPO Toyota - still get inspected?
by Parlay_Slow
06/17/18 09:08 PM
Water Pump Paper Gasket With RTV? Longevity?
by nobb
06/17/18 08:22 PM
Who makes Briggs & Stratton oil?
by spk2000
06/17/18 08:13 PM
Shure stylus replacement
by aquariuscsm
06/17/18 07:54 PM
Any 'crazy UCL overdose' fans out there?
by addyguy
06/17/18 07:11 PM
Source for Castrol Edge Supercar 5w50 oil?
by Rainier42
06/17/18 06:50 PM
Cherry vs orange hand cleaner
by JHZR2
06/17/18 06:27 PM
Why buy low mileage tires?
by HowAboutThis
06/17/18 05:49 PM
Mercury 35-8M0065104 cut open w/ oil change pics
by dlundblad
06/17/18 05:37 PM
2019 Hondaís miniMOTOs (125cc)
by DuckRyder
06/17/18 05:18 PM
Car Sales Scammers on Letgo
by ZZman
06/17/18 04:18 PM
Air shocks or Timbren for trailer towing ?
by Oldtom
06/17/18 04:10 PM
mostdecent, T1TN, Piper58, dunlop0078, Truth_Syrup
65258 Registered Users
71 registered (Aero540T, Ag76, AnonOIl, alphadog, 11 invisible), 1250 Guests and 31 Spiders online.
65258 Members
67 Forums
285500 Topics
Page 1 of 2 1 2 >
#4629311 - 01/09/18 01:43 PM 75k and never changed diff fluid
monster1 Offline
Loc: ca
I have an 04 2500 4 x 4 dodge with 5.9 Cummins. I've never changed the fluid out of my diff as it's always been out of sight out if mind. I've learned this is something I should have done some time ago. Anyway, first off, have I killed my gears? I don't drive the truck hard and I only occasional tow a 5k trailer. Second, what weight gl-5 synthetic gear oil am I supposed to use? I'd look it up in the owners manual but I've never had one. Also, is it as simple as draining with a mityvac and refilling or do I need to make a mess and remove the covers? As always, thanks for the helpful replies.
#4629317 - 01/09/18 01:52 PM Re: 75k and never changed diff fluid [Re: monster1]
FordBroncoVWJeta Offline
Loc: KS
Highly doubt you damaged it. There are TONS of people that go 200K and never change it. On the Trailblazer it never was changed till 110K. No damage. Although I would change it at this point VERY easy to do.
17 Volkswagen Jetta 1.4T
15 Honda CRV 2.4
12 Volkswagen Jetta 2.0
01 Pontiac Sunfire 2.2
#4629318 - 01/09/18 01:53 PM Re: 75k and never changed diff fluid [Re: monster1]
JEL01 Online   content
Loc: Rainville, USA
Your gears are fine, FWIW I did the mityvac method on my old 99 F359 and seapped it with Mobil 1 75w140 for the first time at over 200k shocked when I got it, so 75k is not bad. What does the interwebs call for? I suspect itís the same as my old truck, check Amsoilís site for the exact specs for your truck.
Cars I maintain:
02 MB CLK430-Edge 0w40
05 Honda Accord V6-Maxlife 5w30
13 Lexus RX350 AWD-M1 AFE 0w20
02 Toyota Tundra 4x4 M1 5w30
#4629328 - 01/09/18 01:59 PM Re: 75k and never changed diff fluid [Re: monster1]
Snagglefoot Online   content
Loc: Alberta
Not a problem. Get on RAM.com or Dodge.com and you should be able to look up your owners manual.
To be honest, most truck makers do not suggest you need to change the rear diff for the first 150,000 miles unless you have severe service like lots of towing or going off-road. It's only us gear heads who do. (Ever wonder why there is no drain plug on the rear diff?).
Take a look at your owners manual and feel free to bring up any issues.
One more thing. Your transfer case does need changes. For severe service (which I like to use), it is usually 50,000 miles or so. Most people think, front diff, transfer case and rear diff. It should be front diff, rear diff and 3 times more for the transfer case.
You need to make a mess and take off the rear cover. That way you can clean out any gear shavings.
SF
#4629343 - 01/09/18 02:13 PM Re: 75k and never changed diff fluid [Re: monster1]
CT8 Offline
Loc: Idaho
The owners manual has the recommended viscosity .
"Don't let your preconceived notions get in the way of facts."Geoff Metcalf"
#4629361 - 01/09/18 02:40 PM Re: 75k and never changed diff fluid [Re: monster1]
440Magnum Offline
Loc: Texas
Unless the fluid got water in it, you've probably done zero harm. Heck, my 73 Satellite went close to 200k (with some trailer towing) on a lightweight 8.25 rear gear before the fluid ever got changed, and it proceeded to continue quite happily until over 240,000 miles (still going when I sold the car). Solid axle differentials are notoriously tough, with a few exceptions. None of those exceptions show up under a 3/4 ton Ram (unfortunately, half tone Rams do get the 9.25, which has a lot of reliability problems due to the tooling being so old.)
'66 Dodge Polara & '69 Dodge Coronet R/T both 440/727
'08 Ram 1500 4.7/545RFE
'12 Challenger SRT8 392/6-speed
'99 XJ 4x4 4.0/AX15, '14 WK2 4x4 3.6/8HP
#4629402 - 01/09/18 03:29 PM Re: 75k and never changed diff fluid [Re: monster1]
bdcardinal Offline
Loc: Santa Barbara, CA
I wouldn't worry about it. I'm sure if you went to a junkyard, most of the vehicles have the factory fill diff and trans fluid.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
#4629475 - 01/09/18 04:27 PM Re: 75k and never changed diff fluid [Re: monster1]
gman2304 Offline
Loc: n.c.
My 05 Chevy Avalanche just tripped 193,000 on the FF. Iíll change mine soon.
#4629522 - 01/09/18 05:11 PM Re: 75k and never changed diff fluid [Re: CT8]
bullwinkle Offline
Loc: Cincinnati, OH, USA
75W90, I have RP full syn Severe Gear in mine, along with the oversize rear diff cover (Mag-Hytec).
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 15 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
#4629530 - 01/09/18 05:17 PM Re: 75k and never changed diff fluid [Re: monster1]
demarpaint Offline
Loc: NY
I know plenty of people who sent their vehicles to the junkyard with the differential fluid that the vehicle rolled off the assembly line with. Many with hundreds of thousands of miles on them.
God Bless Our Troops
#4629579 - 01/09/18 06:10 PM Re: 75k and never changed diff fluid [Re: demarpaint]
CKN Offline
Loc: Utah
THIS-they don't seem to wear out under normal use.
#4629595 - 01/09/18 06:20 PM Re: 75k and never changed diff fluid [Re: monster1]
Linctex Offline
Loc: Waco, TX
Early 90's Dana 70 rears had some side carrier bearing problems, but it sounds like yours has had an EASY life so far!
#4629789 - 01/09/18 08:41 PM Re: 75k and never changed diff fluid [Re: monster1]
Lubener Offline
Loc: N.Ohio
I never change differential oil unless it has to be opened up for some reason. That only happened once in 38 years for an axle seal. I make sure the level is up and that's it. I doubt your diff. has been damaged and is the most durable component on your truck.
Edited by Lubener (01/09/18 08:44 PM)
The "thinking" man's friend.
#4629854 - 01/09/18 10:10 PM Re: 75k and never changed diff fluid [Re: monster1]
dakota99 Offline
Loc: indiana
I changed the factory fill diff fluid in my 99 Dakota at 90k just out of a combination of boredom and curiosity. One word of caution, differential oil smells terrible. I mean i canít even describe it. FF looked fine to me. I cleaned the magnet and filled it back up with Mobil 1 and some slip lock? additive. I canít remember the name exactly. It made noise with just the mobil 1 and no additive.
Iím guessing I wonít need to do it again with a good quality oil in there now.
#4629895 - 01/09/18 11:11 PM Re: 75k and never changed diff fluid [Re: monster1]
eyeofthetiger Offline
Loc: South Carolina
I suspect that my '88 GMC has the factory fill in the rear end, but it doesn't make noise or have excessive play. I have a mini spool waiting to be installed, so it will be taken care of soon enough.
2017 Ford Fiesta 1.0T - Valvoline SynPower 5W-20, Motorcraft FL910S
1988 GMC K1500 4.3/700R4 - Supertech 15W-40, Fram TG3980
1986 Ford Ranger 2.0 - uhh
Page 1 of 2 1 2 >
