OVERKILL
$100 Site Donor 2021
Originally Posted By: burla
TN moly seams to have no better effect then organic moly in redline, if it is the Moly that is the key, a distinct possibility. PUP 0w40 if TN moly, and Amsoil 5w30 if TN moly, both left ticks killed by redline. I still do not know why redline is killing the ticks, just that it is killing the ticks. Could be the moly, in which case a super dose of Lubeguards biotech in theory should also kill ticks. or polarity of the base oil, in which case you would need ester content to kill ticks, also possible to duplicate with bio guards biotech, but impossible to isolate as they have no known organic moly additive w/o esters, a note maybe liquimoly newer moly treat might for the first time have a similar moly dose w/o esters. Yes some success was had with Mso2, but not nearly the same as redline at killing ticks. If hths was the key, hard to believe as 5w20 redline has also killed ticks including mine. Answer to why is still in the air, answer "if" has been settled to a high degree. It is worth a shot of you don't replace the lifters, unless you like the tick.
I doubt the AMSOIL product has TN.
When you say PUP 0w-40, do you mean the Euro or SRT version? The SRT one has a decent dose but we don't know if it is TN or not.
If it's the moly, increasing the dose significantly should cause the exact same effect as Redline. If it doesn't, it isn't.
If it's the ester content, running something like 300V should then in turn have similar results. Has anybody tried 300V?
If it was HTHS, anybody running a heavier lube like the 0w-40 should see the improvement.
