Does Your 3.5EB Make Oil
by Gene K. 09/21/18 09:07 AM
F150 Front Differential
by hatt. 09/21/18 08:45 AM
EU version of Subaru 2.5 FB engine
by IMPALA08. 09/21/18 08:40 AM
New “rules” changing your choice of car?
by daves87rs. 09/21/18 06:04 AM
WIX51334XP Oil Filters
by CB900F2. 09/21/18 05:14 AM
Signal Oil Company radio advertising
by 21Rouge. 09/21/18 04:07 AM
Anyone "Wim Hof"ing ?
by Shannow. 09/21/18 02:35 AM
New R1250GS and R1250RT
by 02SE. 09/21/18 12:55 AM
Inside Break Booster & Master Cylinder
by StevieC. 09/20/18 11:22 PM
Inside an Alternator
by StevieC. 09/20/18 11:18 PM
What vehicles are you using Maxlife ATF in?
by BlakeB. 09/20/18 11:10 PM
How a Power Steering Rack Works (Electronic)
by StevieC. 09/20/18 11:00 PM
How a Power Steering Rack Works (Hydraulic)
by StevieC. 09/20/18 10:58 PM
silly wiper problem
by bowlofturtle. 09/20/18 10:33 PM
Canadian Tire Shell Rotella T-6 in Pails
by Snagglefoot. 09/20/18 10:04 PM
Best diesel fuel for cold weather?
by Dickm. 09/20/18 10:03 PM
Type 1 Diabetics - New Research
by StevieC. 09/20/18 10:00 PM
Tire Sizing and Options
by NewEnglander. 09/20/18 09:59 PM
2013 Scion FR-S | Transmission Fluid Questions
by nicknak. 09/20/18 09:47 PM
Meguiar's Liquid Cleaner Wax $5 WalMart, Amazon
by The_Cams. 09/20/18 08:42 PM
ScottRousell, Direct_Rejection, donatom, Sylent_Snyper, Ajizzle
66034 Registered Users
92 registered members (A310, Ablebody, andyd, Aero540T, AnthonyF, 2015_PSD, 7 invisible), 1,490 guests, and 38 spiders.
Topics290,751
Posts4,849,626
Members66,034
Most Online3,590
Jan 24th, 2017
Magnetic drain plugs and UOA sampling? #4629225
01/09/18 01:18 PM
01/09/18 01:18 PM
California
CleverUserName Offline OP
California
I recently installed a dimple magnetic plug in my engine oil pan.
Has anyone ever tried taking the material captured on the magnet and re-introducing it back into the drained oil, mixing thoroughly, and then grabbing a sample for UOA analysis? If so, how did you do it?
I was thinking a stronger magnet covered with a piece of thin steel would pull the material of of the dimple plug and it would stick to the piece of magnetized steel. Then I could remove the stronger magnet and wipe off the material from the steel into the drain pan ? Then mix it up and collect my sample.
Anybody see flaws in this idea, or have a better solution ?
Re: Magnetic drain plugs and UOA sampling? [Re: CleverUserName] #4629235
01/09/18 01:27 PM
01/09/18 01:27 PM
Florida
Artem Offline
Artem  Offline
Florida
I'd want to see two UOAs for comparison. One showing the used oil as is, and the second after introducing the collected iron from the magnet. Should be interesting.
2014 Mazda 3 Hatch 2.0L & 6spd - Idemitsu 0w20 Synthetic @ $0.75 a quart. (thanks Advance Auto Parts for the awesome deal)
Re: Magnetic drain plugs and UOA sampling? [Re: CleverUserName] #4629246
01/09/18 01:37 PM
01/09/18 01:37 PM
Ca.
UncleDave Online content
UncleDave  Online Content
Ca.
Makes no sense to me. if you are going to do that - Why stop at what the magnet caught?
That would be little like cutting the filter open and dumping the content of the filters run and testing that.
The UOA will tell me what Im circulating and the cut filter and mag shows me how much I'm putting out.
I know the second I look at the mag, or in the filter if I have a a big wear/ or cleanliness problem or not.
UD
Uncle Dave
Cat 3126/2 MB3500/Titan/RX400H/17 Ridgeline
700HP V10/ 725HP BBC/ Raptor 700/ KFX450/ YZ250/Onan 8K/ Cat3011C
Re: Magnetic drain plugs and UOA sampling? [Re: CleverUserName] #4629249
01/09/18 01:38 PM
01/09/18 01:38 PM
Texas
440Magnum Offline
440Magnum  Offline
Texas
Its a pointless test, IMO.
For one thing, doing that will grossly OVER estimate the ratio of particulates to oil in the sample compared to just running with a non-magnetic drain plug.
For another thing, most $30 class UOAs will only show it as "particulates" not as iron. The particles tend to be outside the size range that a UOA captures.
'66 Dodge Polara & '69 Dodge Coronet R/T both 440/727
'08 Ram 1500 4.7/545RFE
'12 Challenger SRT8 392/6-speed
'99 XJ 4x4 4.0/AX15, '14 WK2 4x4 3.6/8HP
Re: Magnetic drain plugs and UOA sampling? [Re: CleverUserName] #4629251
01/09/18 01:44 PM
01/09/18 01:44 PM
SE British Columbia, Canada
Snagglefoot Online content
Snagglefoot  Online Content
That sounds interesting. One other way would to be clean off the magnetic plug using a very small piece of gauze while wearing latex gloves. Drop the gauze into a small glass container containing a solvent and swirl it around to get the metal to drop off. Then pour off the solvent and move the metal to a small plastic vial. Label the vial and that way you can have a qualitative record of what is coming off.
The magnetic plug in my transfer case looks pretty fuzzy after 50,000 miles. I'll try this next time I drain it.
SF
If you want the job done right......do it yourself.
Re: Magnetic drain plugs and UOA sampling? [Re: 440Magnum] #4629258
01/09/18 01:51 PM
01/09/18 01:51 PM
California
California
Im not sure I understand your reasoning. Wouldnt the same quantity of metal exist without the plug, but held in suspension? Why would the plug increase the level of particulates?
Arent metals measured by running a GC test? If so, I dont think particle size will matter. If there is Iron present it will be picked up.
Re: Magnetic drain plugs and UOA sampling? [Re: Snagglefoot] #4629263
01/09/18 01:54 PM
01/09/18 01:54 PM
California
California
SF
I dont think gauze would work. The magnet on the dimple plug is very strong, not like a diff. or tranny drain plug. It was very difficult to install as it wanted to stick to the side of the pan instead of threading into the hole.
Re: Magnetic drain plugs and UOA sampling? [Re: CleverUserName] #4629270
01/09/18 02:00 PM
01/09/18 02:00 PM
I noticed magnetic drain plugs are usually 1/2 inch 20. Are GM, Ford and Ram trucks all the same as far as the oil plug goes? Say, 2005 to present?
SF
Re: Magnetic drain plugs and UOA sampling? [Re: Snagglefoot] #4629276
01/09/18 02:06 PM
01/09/18 02:06 PM
California
California
SF
I doubt it. It is a metric plug on my 2.8 duramax
Re: Magnetic drain plugs and UOA sampling? [Re: CleverUserName] #4629291
01/09/18 02:17 PM
01/09/18 02:17 PM
SW Ontario Canada
KGMtech Offline
KGMtech  Offline
SW Ontario Canada
The universal averages for Iron in UOA will be mostly from cars not equipped with magnetic oil plugs. You might consider of what value is spending the money for UOA if you are influencing the results by pulling out the Iron before the test?
To re-introduce the Iron into the UOA sample collection would have to be done in a way to match the engine's actual & average generation of Iron to be of any accurate measure.
I'd mention the drain plug magnet in the special notes section of the mailing kit for the UOA, but leave the Iron filings out of the bottle.
2017.5 Nissan Rogue SV FWD
2013 Nissan Maxima SV
2009 Ford Flex SEL FWD
1984 Yamaha XJ750RL
Re: Magnetic drain plugs and UOA sampling? [Re: CleverUserName] #4629312
01/09/18 02:45 PM
01/09/18 02:45 PM
"I dont think gauze would work. The magnet on the dimple plug is very strong, not like a diff. or tranny drain plug. It was very difficult to install as it wanted to stick to the side of the pan instead of threading into the hole.[/quote] "
I see. I didn't realize Dimple was a brand name. Here is the website for the other folks interested in this. http://www.drainplugmagnets.com
"M12x1.75x21 Magnetic Drain Plug for GM
Many GM products take this coarse thread plug, including Corvettes, Buick V6, Chevrolets, and Chevy trucks. It includes a 5/16" diameter high temperature Neodymium magnet.
$34.95 "
SF
Re: Magnetic drain plugs and UOA sampling? [Re: CleverUserName] #4629373
01/09/18 03:55 PM
01/09/18 03:55 PM
Texas
440Magnum Offline
440Magnum  Offline
Texas
If you perfectly re-distribute them through ALL the oil drained, then maybe. But that woudl take a lot more than just a casual stirring.
The metals shown on a typical Blackstone labs report (or other labs for similar prices) only show metal that can be vaporized in the gas chromatograph or mass spec or whatever tool they use. Particles that are too large don't contribute to the metallic numbers in the sample.
Re: Magnetic drain plugs and UOA sampling? [Re: Snagglefoot] #4629627
01/09/18 07:44 PM
01/09/18 07:44 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
"M12x1.75x21 Magnetic Drain Plug ..... It includes a 5/16" diameter high temperature Neodymium magnet.
I don't stop with just one....
Originally Posted By: Linctex
Magnets are 8mm N50 neodymium
Re: Magnetic drain plugs and UOA sampling? [Re: 440Magnum] #4629684
01/09/18 08:21 PM
01/09/18 08:21 PM
UT
BHopkins Offline
BHopkins  Offline
UT
It seems like a very flawed experiment.
I'm assuming your intent is to try to quantify how much iron is captured by the magnet? Do a sample before reintroducing the iron particles, and another after adding them back in?
Here are my concerns.
First, as mentioned earlier, it seems extremely unlikely that you will get the iron particles totally blended throughout the used motor oil. It seems almost certain that your sample taken after adding the iron back in will be something other than representative of the actual. It took perhaps 100 - 200 hours of engine running time for all the iron particles to be introduced. How long could it take to redistribute them evenly?
Second, I agree with your own evaluation, that it will be almost impossible to get all the iron particles off of the magnet. But if you are OK with the knowledge that the data will be biased to something less than complete iron, then that's OK. But it seems like a lot of work for inaccurate results.
Third, and this is the one that bothers me the most. Are you taking into consideration that a great share of the iron particles that are caught by the magnet, may have been caught by the filter if the magnet had not been in place? Without a much more robustly designed experiment, you will never know. This has always been one of my biggest questions when people proudly boast of how much they capture with a drain plug or filter magnet. Unless 100% of the iron particles were removed from the magnet, and then measured for particle size distribution, then compared to the filter efficiency rating, you will never know.
2013 Subaru Outback 2.5i - Idemitsu 0W-20 & Mobil 1 filter
2003 Oldsmobile Alero 3.4 - M1 5W-30 & NAPA Gold filter
Re: Magnetic drain plugs and UOA sampling? [Re: Linctex] #4629689
01/09/18 08:25 PM
01/09/18 08:25 PM
Ca.
Ca.
This setup is probably the best per dollar spent Ive seen.
I nitpick about partial inlet blockage , but its probably meaningless.
Im an old dog and learned a new trick with this one
UD
Uncle Dave
