I have read a Spectro product catalog in the past (past 2 years) and several oils in their lineup have up to 1800ppm zddp; might want to call them to find out which ones have the extra zddp; if ya wanna go the way of hdeo with cj-4 ratings then consider Traveller brand 15w-40 at Tractor Supply Company; current special is 2.5 gallon container for $21.99; I think Supertech 15w-40 at Walmart is still cj-4; if ya want a true name brand in hdeo...Shell Rotella T-4 is ck-4 WITHOUT sn rating which means higher zddp potential or Motorcraft which states higher than 1000ppm zddp on the bottle;
on a sidebar...I'm doing the annual research on choosing oil for my 2-wheeled death machines; I go round & round...synthetic vs synblend vs conventional, hdeo vs motorcycle oil vs 10w-40 pcmo; I have NO idea where to land...I have 5 qts of 10w-40 & 15w-40 frankenbrew, 2 qts of Kolpin 10w-40 synblend powersports oil, and 3 qts of Kawasaki 10w-40 synblend mower oil with wet clutch capability (thought it was bike oil and didn't read the bottle...can't find the receipt); most likely I will tap the frankenbrew for the first oil change after running the storage oil for a month and go from there...
