Pennzoil GF-6 & Low Viscosity Q&A
Click here to participate in the Pennzoil Q&A
Another Amazon issue....
by mjk. 06/25/19 09:10 PM
Leupold screws
by buck91. 06/25/19 08:51 PM
2004 Lexus RX330, 5659mi, Pennzoil Platinum HM 5W30
by newtoncd8. 06/25/19 07:38 PM
Milesyn 5w/20, 5500 miles, 2007 Mazda6 2.3L
by RayCJ. 06/25/19 07:12 PM
Mystik JT-6 Green tube @ Tractor Supply
by K20FA5. 06/25/19 06:58 PM
Saw a '53 Chevy this morning
by fdcg27. 06/25/19 06:20 PM
Motorcraft Mercon V opinions?
by Vigilant. 06/25/19 05:28 PM
New Personal Best MPG
by Kjmack. 06/25/19 05:01 PM
DuraMAX Synthetic Oil?
by Torino117. 06/25/19 04:54 PM
Battery Cables!
by NYEngineer. 06/25/19 04:35 PM
Brake Rotors
by WyrTwister. 06/25/19 04:00 PM
Rubber cement tubes?
by buck91. 06/25/19 03:53 PM
2019 Camaro SS 10sp auto, brief review
by Cujet. 06/25/19 03:14 PM
John Deere LX280 Help!
by johnmichael. 06/25/19 03:01 PM
Which grease?
by maverickfhs. 06/25/19 12:43 PM
Potenza SO4 Pole Position on the 968
by BeerCan. 06/25/19 12:15 PM
New wheels and tires on our VW Passat
by SLO_Town. 06/25/19 11:28 AM
Absorber drying chamois
by Redright9. 06/25/19 10:36 AM
Beason, Toddstephens22, Macky, javadog, giwatcher
68488 Registered Users
122 registered members (AC1DD, 87sammy, 1nighttrain, 2015_PSD, aba4430, 94MaxGXE, 11 invisible), 2,141 guests, and 31 spiders.
Topics290,969
Posts4,996,131
Members68,488
Most Online2,967
Mar 10th, 2019
Page 1 of 5 1 2 5
Considering buying a Franz Filter #4628559
01/08/18 07:53 PM
01/08/18 07:53 PM
WA
DeafBrad Offline OP
DeafBrad  Offline OP
WA
Hi Everyone,
I am considering in the near future buying a Franz filter for my Dodge Grand Caravan. It looks like the full kit is a little under $300. I have watched a few videos, and the install looks fairly simple.
It appears the kit comes with a fitting to "t" off of the oil sending unit or something like that (correct me if I am wrong). I plan to drill a hole in the oil filler cap and running the return line there instead of puncturing the oil pan. My plan is to make minimal modifications to the van so I can return the van to stock easily and move the filter to the next vehicle.
Are there other tp filter brands to consider? Any other suggestions or tips?
Thanks for your time,
Brad
Toyota Echo 250,000 + miles
Geo XFI 50+ mpg
Honda CBR250r 65+ mpg
Re: Considering buying a Franz Filter [Re: DeafBrad] #4628562
01/08/18 07:55 PM
01/08/18 07:55 PM
Oshawa, Ontario Canada
JC1 Offline
JC1  Offline
What year is the caravan?
2015 Grand Caravan SXT Plus 5w-30 Valvoline White Bottle/Fram Ultra Filter
1997 Honda Civic CX 5w-30 Shell Conventional/Fram Ultra Filter
Re: Considering buying a Franz Filter [Re: DeafBrad] #4628568
01/08/18 08:01 PM
01/08/18 08:01 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
1) Use a good quality synthetic oil, change every 10K (typically, YMMV)
2) Use a good glass media oil filter
Following this formula, the rest of your van will likely fall apart before the engine dies.
Re: Considering buying a Franz Filter [Re: DeafBrad] #4628572
01/08/18 08:03 PM
01/08/18 08:03 PM
Kelowna, BC, Canada
A310 Offline
A310  Offline
Kelowna, BC, Canada
That's what I would do and have done on my trucks. As far as brands of Tp are concerned Scott 1000, BoardWalk, and Kirkland brands work well. You might want to consider getting a sleeve or orings to seal the center roll to the Frantz tube. If you look on Ebay NOS units come up from time to time, so you don't need to pay 300 for one.
2009 Ford F-350 (Detroit 4-53T)
2000 Ford Excursion (Triton V10)
1993 Dodge D250 (Cummins 6BT)
Re: Considering buying a Franz Filter [Re: JC1] #4628577
01/08/18 08:10 PM
01/08/18 08:10 PM
WA
DeafBrad Offline OP
DeafBrad  Offline OP
WA
It is a 2006 Dodge Caravan. I "get it" why these are popular, as they are nice. I have 153k miles or so on it now.
Geo XFI 50+ mpg
Re: Considering buying a Franz Filter [Re: Linctex] #4628580
01/08/18 08:13 PM
01/08/18 08:13 PM
WA
DeafBrad Offline OP
DeafBrad  Offline OP
WA
Thanks for the info. Do you change out the tp early or do you leave it in 10k miles? I have a microgreen filter on the van now, and most likely will just leave it on.
Geo XFI 50+ mpg
Re: Considering buying a Franz Filter [Re: DeafBrad] #4628587
01/08/18 08:18 PM
01/08/18 08:18 PM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
Bypass filter because?
2015 F150 2.7
2018 F350 6.2
Re: Considering buying a Franz Filter [Re: A310] #4628590
01/08/18 08:20 PM
01/08/18 08:20 PM
WA
DeafBrad Offline OP
DeafBrad  Offline OP
WA
Thanks for the info. So my understanding is the oil comes up the center tube and drains through the tp and out the bottom, right? I am assuming the tp must be tight on the center roll, and on the outside of the roll up against the canister as well.
Geo XFI 50+ mpg
Re: Considering buying a Franz Filter [Re: CT8] #4628593
01/08/18 08:21 PM
01/08/18 08:21 PM
WA
DeafBrad Offline OP
DeafBrad  Offline OP
WA
Because I want to. Think of it as a hobby, and something to do. As well, it would be a big plus for the engine to not to wear and use oil as the miles pile on. I tend to keep my vehicles a while.
Geo XFI 50+ mpg
Re: Considering buying a Franz Filter [Re: DeafBrad] #4628597
01/08/18 08:24 PM
01/08/18 08:24 PM
Kelowna, BC, Canada
A310 Offline
A310  Offline
Kelowna, BC, Canada
That's correct.:)
Re: Considering buying a Franz Filter [Re: DeafBrad] #4628618
01/08/18 08:39 PM
01/08/18 08:39 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I can see this as a hobby.... just please don't expect any stellar results, OK?
Re: Considering buying a Franz Filter [Re: Linctex] #4628639
01/08/18 08:52 PM
01/08/18 08:52 PM
WA
DeafBrad Offline OP
DeafBrad  Offline OP
WA
What expectation are you finding people have with the bypass filter? I don't think my expectations are too high... I would say my expectation would be #1 to extend the oil change intervals to 10k miles (the manual calls for 3k mile oil changes in severe duty) and #2 extend the amount of life the engine has as a non-oil burner. I currently am using a Microgreen filter, and I believe the Franz is a step or 2 above the Microgreen.
Geo XFI 50+ mpg
Re: Considering buying a Franz Filter [Re: DeafBrad] #4628745
01/08/18 10:24 PM
01/08/18 10:24 PM
Planet Earth
Jonzobot Offline
Jonzobot  Offline
Planet Earth
I installed one on my car. Mostly as a conversation piece and a laugh. I T'd the pressure feed from the oil pressure sender (which broke off in the block on removal, whee!) and drilled a hole in the oil pan for the return line. I made sure to install a restriction prior to the inlet of the filter. I've had my car running on toilet paper for 60,000km now (out of 320,000), no signs of issues.
I did an oil analysis on my last oil change without the Frantz, and my first oil change upon using the TP filter, and the results were surprisingly good.
I use some generic single ply from Rona (hardware store) - I think it's rebranded Scott 1000, but we can't get Scott 1000 here.
Re: Considering buying a Franz Filter [Re: DeafBrad] #4628760
01/08/18 10:38 PM
01/08/18 10:38 PM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
I can see the hobby part as a good reason.
2015 F150 2.7
2018 F350 6.2
Re: Considering buying a Franz Filter [Re: DeafBrad] #4628816
01/09/18 12:18 AM
01/09/18 12:18 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Just about any oil can get you to 10K in Washington's climate.
You'll have to do the math... $300+ is like 30 oil changes, every 5,000 miles is another 150,000 miles without the installation of the bypass.
A bypass filter helps get out PARTICULATE. Only.
It does not improve TBN, or help with shearing, etc.
I said "don't expect stellar results", because you can get your 2006 Caravan engine
to 300,000 miles with just good maintenance.
But I worry about the rest of the van....
Page 1 of 5 1 2 5
