Best recommendation for Honda 10w30 trans
by Pepsibottle1
06/25/18 01:55 PM
Mills Fleet Farm Roadrunner batteries - who makes?
by volk06
06/25/18 01:09 PM
Honda ATF DW1 bottle stamp decoding
by parshisa
06/25/18 12:03 PM
How to lower throttle sensitivity?
by NICAT
06/25/18 11:41 AM
That's some service! (New Central AC...)
by xBa380
06/25/18 11:13 AM
Valvoline 2 Cycle TC-W3 Marine Oil - 6qt - $20
by Jimzz
06/25/18 10:45 AM
Plumbing/Bldg Experts: Cause of Wet Slab?
by LoneRanger
06/25/18 10:13 AM
How to CONFIRM the Country of Manufacture
by Ed_Flecko
06/25/18 09:58 AM
Replacing trans oil seal
by redhat
06/25/18 09:50 AM
VW diesels sitting in huge lots waiting......
by ZZman
06/25/18 09:09 AM
DTD/DT Independence Day Promos
by Sayjac
06/25/18 08:39 AM
It's AMSOIL®, not Amsoil
by Rat407
06/25/18 06:39 AM
VW Passat 2007
by madRiver
06/25/18 06:18 AM
Review: CVJ Remanufactured CV Axles
by The Critic
06/25/18 03:40 AM
Towing without 85w140?
by OilFilters
06/25/18 03:07 AM
2015 VW GTI autobahn oil questions
by Skyalbo
06/24/18 11:28 PM
Corrosion in the garage - salt or humidity?
by Kurtatron
06/24/18 11:13 PM
Darn dogs
by AZjeff
06/24/18 10:21 PM
New GC?
by Bullwinkle007
06/24/18 10:04 PM
The guy with the plexiglass head on you tube
by andyd
06/24/18 09:21 PM
dhy808, ROD_Z, lozpxs, danthemanx07, FunktasticLucky
65319 Registered Users
88 registered (AndyB, 4WD, badtlc, 87sammy, aquariuscsm, 9050lx, 11 invisible), 1670 Guests and 34 Spiders online.
65319 Members
67 Forums
285971 Topics
Page 1 of 3 1 2 3 >
#4628588 - 01/08/18 07:18 PM STP Maximum Life Oil Filter Defect
69Torino Offline
Loc: Indy
Got an oil change special from Autozone for a friend's 2002 Monte Carlo, figured I'd up to the super premium STP Max filter with Valvoline Synthetic for 30 bucks. Seemed like a good deal. Got home and found a torn ADBV. My bad, should have opened the box beforehand. Sticking with OEM, K&N or Wix now, for the rest of my life, never straying again. They happily exchanged it for an A/C Delco with no question.
Apparently I own too many cars and toys to fit in a signature.
#4628615 - 01/08/18 07:37 PM Re: STP Maximum Life Oil Filter Defect [Re: 69Torino]
Bottom_Feeder Online   content
Loc: Occupied Virginia
Not seeing a tear. That's rubber flash from the mold.
#4628619 - 01/08/18 07:39 PM Re: STP Maximum Life Oil Filter Defect [Re: 69Torino]
das_peikko Offline
Loc: San Antonio, TX
It's strange they use a Fram part number and yet the base plate sure looks like a Purolator.
#4628621 - 01/08/18 07:39 PM Re: STP Maximum Life Oil Filter Defect [Re: 69Torino]
69Torino Offline
Loc: Indy
Seemed off center too. Maybe that's what was going on. Either way no warm fuzzy feeling.
#4628641 - 01/08/18 07:53 PM Re: STP Maximum Life Oil Filter Defect [Re: 69Torino]
MParr Offline
Loc: Georgia
I got an S2808ML today as part of the AZ promotion. I opened a few boxes. They all looked pretty good except one. That one had small sliver of metal leftover from the threading process. It’s definitely made by Purolator. The manufacturing code on the dome end is the clue.
2013 KIA Optima EX 2.4L. Now: Castrol Magnatec GTX 5W30 synthetic & STP S2808ML
2017 Ford Escape SE 2.0T Now: Pennzoil Platinum 5W30 & Motorcraft 910s
#4628675 - 01/08/18 08:15 PM Re: STP Maximum Life Oil Filter Defect [Re: MParr]
MParr Offline
Loc: Georgia
Here it is.
#4628716 - 01/08/18 08:55 PM Re: STP Maximum Life Oil Filter Defect [Re: das_peikko]
Nyogtha Offline
Quaker State oil filters use the Fram numbering system for most applications but are currently manufactured by Putolator.
Super Tech oil filters at Walmart use the Fram numbering system for most applications but are currently manufactured by Wix.
STP oil filters use the Fram numbering system for the most part, and were historically manufactured by Champion Laboratories (and some of the blue can applications still are).
However, there are notable exceptions, such as crossing the Motorcraft FL-500S to these various brands. Fram is the PH/TG/XG 10575. Quaker State is the QS173. Super Tech is the ST 10086. STP is the S10590.
"No matter how paranoid you are you're not paranoid enough. Tell the truth. Reach as many people as you can with it. That's your weapon." - Susanne Modeski, aka "Holly" to The Lone Gunmen
#4628726 - 01/08/18 09:05 PM Re: STP Maximum Life Oil Filter Defect [Re: 69Torino]
goodtimes Offline
Loc: california
This looks like adbv cutting by the baseplate to me. I guess Puro doesn't come here to read. An interesting alternative for this filter number is the Luber Finer PH477. Made by Champ Labs which probably made the Delco OE. I got mine from Zoro as an add on to an order with a 20-25% off deal. I found it to be a heavily built thing with a silicone adbv. Still haven't figured out why it is made. Why does a Chevy Volt need a high performance oil filter? It's a perfect cross to the 3387a.
http://productguide.luber-finer.com/Home/PartDetail?partNo=PH477
#4628740 - 01/08/18 09:18 PM Re: STP Maximum Life Oil Filter Defect [Re: das_peikko]
Hootbro Offline
Loc: DELAWARE
Private label customers can select any filter makers style number system or have their own made up.
2018 Jeep Wrangler JL 3.6L (Idemitsu 0W-20)
2017 Jeep Renegade 2.4L (Idemitsu 0W-20)
#4628998 - 01/09/18 08:43 AM Re: STP Maximum Life Oil Filter Defect [Re: 69Torino]
ARCOgraphite Offline
Loc: N.H, U.S.A.
I don't see a problem. Though I wish the adbv was on the engine not the filter. Likely to prevent gumming and sticking.
2014 Nissan Rogue S CVT, OC#9 41392mi-QSUD10W30 + M110A CHAMP Filter; 2017 Subaru Crosstrek CVT OC#2 ?? mi-SOA/Idemitsu 0w20 + SOA Filter
#4629009 - 01/09/18 08:56 AM Re: STP Maximum Life Oil Filter Defect [Re: ARCOgraphite]
goodtimes Offline
Loc: california
There is no problem because he returned the defective filter with the split in the adbv, a clear, giant picture of it is above, and they gave him a Delco. smile
#4629073 - 01/09/18 10:07 AM Re: STP Maximum Life Oil Filter Defect [Re: goodtimes]
MParr Offline
Loc: Georgia
Not a problem at all with the S2808ML, I purchased. The ADBV has a new design feature. Notice the molded in nubs that limit the contact with the baseplate. Also, I found no burrs on the back side of the baseplate where the holes were punched.
#4629081 - 01/09/18 10:16 AM Re: STP Maximum Life Oil Filter Defect [Re: 69Torino]
TheOilWizard Offline
Loc: US
What will you do after you find a defect on an OEM, K&N and Wix?
#4629160 - 01/09/18 11:18 AM Re: STP Maximum Life Oil Filter Defect [Re: TheOilWizard]
69Torino Offline
Loc: Indy
Throw a hissy fit and waive my clenched fist in the air.
#4629162 - 01/09/18 11:19 AM Re: STP Maximum Life Oil Filter Defect [Re: goodtimes]
Loc: N.H, U.S.A.
I cant view the OP pictures for some reason. I can see yours, I didn't read carefully on my short break, I though you had reloaded the OP photos. I was looking at you Purolator OE unit with the nice gray paint smile
Page 1 of 3 1 2 3 >
