Which of these sub $4 filters
by jayjr1105 - 02/25/20 04:05 PM
Flaring tool
by P10crew - 02/25/20 01:52 PM
Hazet 600LG/8 Wrench set - $160
by drtyler - 02/25/20 01:34 PM
Cartridge Filter Question
by Tundra73 - 02/25/20 01:21 PM
Buying another car of the same generation
by brages - 02/25/20 01:02 PM
Buying Tires on Amazon
by jcartwright99 - 02/25/20 12:52 PM
plated cylinder liners and sulphur
by alex_at - 02/25/20 12:31 PM
Have we reached the ceiling in improvents to PCMO?
by Speak2Mountain - 02/25/20 11:59 AM
International travel for pleasure
by Pew - 02/25/20 11:42 AM
maxi scooter - should i change the oil now?
by alex_at - 02/25/20 11:05 AM
Toyota NA vs Toyota Global...
by mv6845 - 02/25/20 10:11 AM
How to determine Group II, III or IV
by Drew7a - 02/25/20 09:41 AM
Pulling axle question
by supton - 02/25/20 07:50 AM
Sams Club gas
by dbvettez061 - 02/25/20 07:44 AM
2019 Ram Battery Issue
by NYEngineer - 02/25/20 06:00 AM
belt squeaking suddenly
by dogememe - 02/24/20 11:45 PM
Is Mobil 1 advanced synthetic a full synthetic?
by apollo18 - 02/24/20 11:08 PM
what stocks to buy?
by daves66nova - 02/24/20 08:55 PM
BJD2020, ToyTaco2002, EarlT500, Newbie111, Boris_Be
70800 Registered Users
124 registered members (55hambone, AC1DD, 762fermeandyou, 2009Edge, 1978elcamino, Anthony, 14 invisible), 2,505 guests, and 16 spiders.
Topics301,914
Posts5,205,329
Members70,800
Page 1 of 5 1 2 5
Considering buying a Franz Filter #4628559 01/08/18 06:53 PM
DeafBrad Offline OP
Hi Everyone,
I am considering in the near future buying a Franz filter for my Dodge Grand Caravan. It looks like the full kit is a little under $300. I have watched a few videos, and the install looks fairly simple.
It appears the kit comes with a fitting to "t" off of the oil sending unit or something like that (correct me if I am wrong). I plan to drill a hole in the oil filler cap and running the return line there instead of puncturing the oil pan. My plan is to make minimal modifications to the van so I can return the van to stock easily and move the filter to the next vehicle.
Are there other tp filter brands to consider? Any other suggestions or tips?
Thanks for your time,
Brad
Toyota Echo 250,000 + miles
Geo XFI 50+ mpg
Honda CBR250r 65+ mpg
Re: Considering buying a Franz Filter [Re: DeafBrad] #4628562 01/08/18 06:55 PM
J
JC1 Offline
J
What year is the caravan?
2015 Grand Caravan SXT Plus 0w-20 Pennzoil Ultra/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: Considering buying a Franz Filter [Re: DeafBrad] #4628568 01/08/18 07:01 PM
L
Linctex Offline
L
1) Use a good quality synthetic oil, change every 10K (typically, YMMV)
2) Use a good glass media oil filter
Following this formula, the rest of your van will likely fall apart before the engine dies.
Re: Considering buying a Franz Filter [Re: DeafBrad] #4628572 01/08/18 07:03 PM
A
A310 Offline
A
That's what I would do and have done on my trucks. As far as brands of Tp are concerned Scott 1000, BoardWalk, and Kirkland brands work well. You might want to consider getting a sleeve or orings to seal the center roll to the Frantz tube. If you look on Ebay NOS units come up from time to time, so you don't need to pay 300 for one.
2009 Ford F-350 (Detroit 4-53T)
2000 Ford Excursion (Triton V10)
1993 Dodge D250 (Cummins 6BT)
Re: Considering buying a Franz Filter [Re: JC1] #4628577 01/08/18 07:10 PM
DeafBrad Offline OP
It is a 2006 Dodge Caravan. I "get it" why these are popular, as they are nice. I have 153k miles or so on it now.
Geo XFI 50+ mpg
Re: Considering buying a Franz Filter [Re: Linctex] #4628580 01/08/18 07:13 PM
DeafBrad Offline OP
Thanks for the info. Do you change out the tp early or do you leave it in 10k miles? I have a microgreen filter on the van now, and most likely will just leave it on.
Geo XFI 50+ mpg
Re: Considering buying a Franz Filter [Re: DeafBrad] #4628587 01/08/18 07:18 PM
CT8 Offline
Bypass filter because?
2015 F150 2.7
2018 F350 6.2
Re: Considering buying a Franz Filter [Re: A310] #4628590 01/08/18 07:20 PM
DeafBrad Offline OP
Thanks for the info. So my understanding is the oil comes up the center tube and drains through the tp and out the bottom, right? I am assuming the tp must be tight on the center roll, and on the outside of the roll up against the canister as well.
Geo XFI 50+ mpg
Re: Considering buying a Franz Filter [Re: CT8] #4628593 01/08/18 07:21 PM
DeafBrad Offline OP
Because I want to. Think of it as a hobby, and something to do. As well, it would be a big plus for the engine to not to wear and use oil as the miles pile on. I tend to keep my vehicles a while.
Geo XFI 50+ mpg
Re: Considering buying a Franz Filter [Re: DeafBrad] #4628597 01/08/18 07:24 PM
A
A310 Offline
A
That's correct.:)
Re: Considering buying a Franz Filter [Re: DeafBrad] #4628618 01/08/18 07:39 PM
L
Linctex Offline
L
I can see this as a hobby.... just please don't expect any stellar results, OK?
Re: Considering buying a Franz Filter [Re: Linctex] #4628639 01/08/18 07:52 PM
DeafBrad Offline OP
What expectation are you finding people have with the bypass filter? I don't think my expectations are too high... I would say my expectation would be #1 to extend the oil change intervals to 10k miles (the manual calls for 3k mile oil changes in severe duty) and #2 extend the amount of life the engine has as a non-oil burner. I currently am using a Microgreen filter, and I believe the Franz is a step or 2 above the Microgreen.
Geo XFI 50+ mpg
Re: Considering buying a Franz Filter [Re: DeafBrad] #4628745 01/08/18 09:24 PM
J
Jonzobot Offline
J
I installed one on my car. Mostly as a conversation piece and a laugh. I T'd the pressure feed from the oil pressure sender (which broke off in the block on removal, whee!) and drilled a hole in the oil pan for the return line. I made sure to install a restriction prior to the inlet of the filter. I've had my car running on toilet paper for 60,000km now (out of 320,000), no signs of issues.
I did an oil analysis on my last oil change without the Frantz, and my first oil change upon using the TP filter, and the results were surprisingly good.
I use some generic single ply from Rona (hardware store) - I think it's rebranded Scott 1000, but we can't get Scott 1000 here.
Re: Considering buying a Franz Filter [Re: DeafBrad] #4628760 01/08/18 09:38 PM
CT8 Offline
I can see the hobby part as a good reason.
2015 F150 2.7
2018 F350 6.2
Re: Considering buying a Franz Filter [Re: DeafBrad] #4628816 01/08/18 11:18 PM
L
Linctex Offline
L
Just about any oil can get you to 10K in Washington's climate.
You'll have to do the math... $300+ is like 30 oil changes, every 5,000 miles is another 150,000 miles without the installation of the bypass.
A bypass filter helps get out PARTICULATE. Only.
It does not improve TBN, or help with shearing, etc.
I said "don't expect stellar results", because you can get your 2006 Caravan engine
to 300,000 miles with just good maintenance.
But I worry about the rest of the van....
Page 1 of 5 1 2 5
