Silicone containing waxes
by mjoekingz28
06/19/18 09:44 AM
Matrix totaled
by circuitsmith
06/19/18 08:32 AM
Door rust problems
by Dave Sherman
06/19/18 07:51 AM
2016 Honda Civic problems
by dbias
06/19/18 07:39 AM
Royal purple 75-140 in a subaru rear
by 91camarosRS
06/19/18 07:32 AM
OCI. With short trips. Nissan 4 liter
by Gawardawg
06/19/18 06:52 AM
Approach Watching on the Beach @ St Maarten ...
by LoneRanger
06/19/18 06:41 AM
Honda Accord Needs Shocks; Front, Back, or Both?
by tc1446
06/19/18 05:50 AM
How much oil does your oil filter hold?
by Snagglefoot
06/19/18 05:44 AM
better day
by mx5miata
06/19/18 05:26 AM
BRAVO to Officer Wheeles......
by Sayjac
06/19/18 05:17 AM
People Watching ....Airport style.
by ZZman
06/19/18 04:24 AM
Subaru's at play...
by OneEyeJack
06/19/18 03:50 AM
Treating a 2003 Jetta
by llmercll
06/19/18 01:41 AM
Brakes not working - brake pedal sinks
by tookien
06/19/18 12:42 AM
Dave thinks I can make it 12--15k
by Marco620
06/19/18 12:26 AM
'05 Impala front wheel "squeal". Cost !
by Lee4212
06/19/18 12:16 AM
One Dollar Per Gallon?
by Y_K
06/18/18 11:53 PM
Walmart Tightening up Returns
by John_K
06/18/18 10:21 PM
flare nut wrench set
by spasm3
06/18/18 09:46 PM
JustaDude, 3horseman, Firedog45, WtsTacoma01, Orion62
65265 Registered Users
79 registered (badtlc, Atesz792, beanoil, andyd, BAJA_05, AndyB, 7 invisible), 1531 Guests and 37 Spiders online.
65265 Members
67 Forums
285586 Topics
Page 1 of 2 1 2 >
#4628557 - 01/08/18 06:51 PM GM 5.3 Lifters
Ian1982 Offline
Loc: Ct,USA
Between FB and forums seems like there has been a lot of issues with lifters in these AFM motors. What's everyone's opinion on preventive maintenance on these motors whether it's shorter OCI's, additives, or just running OLM with a top notch oil and keep fingers crossed? Thanks everyone for your input, appreciate it.
#4628570 - 01/08/18 07:03 PM Re: GM 5.3 Lifters [Re: Ian1982]
14Accent Offline
Loc: MN
There isn't anything you can do. It's a design flaw from the get-go. The lifters just aren't strong enough for the design parameters.
The bungled PCV system (that was just recently fixed with a valve cover update), combined with the fairly heavy usage that most of these engines see adds up to failure.
If you bought the truck new, took epic care of it, used only top notch oils, you MIGHT have been able to avoid an issue. Maybe.
To be fair, it's not really as bad of an issue as it seems. Yes, it's common. No, it's not a guarantee. It's like the VVT solenoids on Toyota V6's. Are they common? Yes. Widespread? Hardly. They built hundreds of thousands of those engines just like they built 5.3's as fast as they could move the assembly line.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
#4628589 - 01/08/18 07:19 PM Re: GM 5.3 Lifters [Re: Ian1982]
Oil_Flunky Offline
Loc: Michigan
PEA fuel system cleaners, Rislone Concentrate, and Mopar Combustion Chamber Cleaner, made my high mileage 2011 5.3 Silverado AFM run really good.
Oil, you need it. Oil snobbery, you don't need it.
#4628616 - 01/08/18 07:37 PM Re: GM 5.3 Lifters [Re: Ian1982]
CKN Offline
Loc: Utah
The updated valve covers I believe were being installed on the assembly line the later part of 2011.
GM sells over 40,000 units a month (Silverado/Sierra combined). It's not a big of an issue as the Internet makes it out to be.
Do the math-these motors (with the AFM) started appearing in 2007. As mentioned-just think how many are on the roads.
Edited by CKN (01/08/18 07:39 PM)
#4628622 - 01/08/18 07:39 PM Re: GM 5.3 Lifters [Re: Ian1982]
eyeofthetiger Offline
Loc: South Carolina
AFM delete, new cam and lifters, add a supercharger.
2017 Ford Fiesta 1.0T - Valvoline SynPower 5W-20, Motorcraft FL910S
1988 GMC K1500 4.3/700R4 - Supertech 15W-40, Fram TG3980
1986 Ford Ranger 2.0 - uhh
#4628625 - 01/08/18 07:42 PM Re: GM 5.3 Lifters [Re: Ian1982]
Snagglefoot Online   content
Loc: Alberta
Donít try to outsmart the GM engineers. Use only Dexos approved motor oil. No conventional oil, and no 40 weight blends. The Dexo oils come in 0-20, 5-20, and 5-30. Check your manual. If it asks for, 5-30, stick with 5-30.
Now this is me, but I would stick with top tier gasoline, and maybe use the cleaners. What year is the engine?
SF
#4628633 - 01/08/18 07:47 PM Re: GM 5.3 Lifters [Re: Ian1982]
das_peikko Offline
Loc: San Antonio, TX
Texas Speed & Performance has an AFM delete kit to make it a normal V8 engine again.
#4628642 - 01/08/18 07:53 PM Re: GM 5.3 Lifters [Re: das_peikko]
WillB Offline
Loc: Innisfil, Ontario, Canada
What he said ^^ - delete the AFM, then tune it off....Problem solved.
Thanks,
Will
2017 Ram 1500 Crew Cab 4x4 Hemi 5.7 6 Speed Auto
2011 GMC 1500 CC 4WD 4.8 - Traded.
04 GMC 1500CC Z71 350,000km 217,000 miles - Retired.
#4628652 - 01/08/18 07:59 PM Re: GM 5.3 Lifters [Re: Ian1982]
clinebarger Offline
Loc: Fort Worth, Texas
It's not the end of the world to replace the lifters & delete the AFM altogether, It also allows use of a LS3 Valley Cover that has a oil separator/PCV built-in.
*LS7 Lifters GM part# 12499225
*LS3 Lifter Guides GM part# 12595365 (X4)
*LS3 Valley Cover GM part# 12599296
*L33/5.3L-HO Head Gasket GM part# 12589226 (X2)
*2004 & up LSx Head Bolt kit GM part# 17800568 (X2)
*Upper Engine Cleaner GM part# 88861803 (X2)
*4 foot of 3/8" Trans Cooler Hose (Used to reroute the PCV to the Valley Cover)
*3/8" Vinyl Vacuum plug (To plug the drivers Valve Cover PCV port), I like to use a GM/LS3 piece here but GM doesn't sell them separate from the valve cover.
*ECM Tune to turn off all AFM functions.
*I highly recommend replacing the Exhaust Manifold Bolts with ARP replacements......part# 134-1202
The Upper Engine cleaner is to soak the pistons overnight while the cylinder heads are off.
I do about 1 of these a month on average, Annoying ticks, Misfires & oil consumption are eliminated!!
2001 Chevy Camaro L92/4L80E
2010 Toyota Corolla 2ZR-FE/Auto
#4628655 - 01/08/18 08:04 PM Re: GM 5.3 Lifters [Re: Ian1982]
clinebarger Offline
Just to add as I didn't see the post ahead of me....
You DO NOT need to change the Camshaft or remove the Balancer & Front Cover!!!
#4628662 - 01/08/18 08:08 PM Re: GM 5.3 Lifters [Re: Ian1982]
Loc: Alberta
I think I see two water pump gaskets there. Might as well change the water pump if you go that route. From what I heard, if the engine fails you typically lose the contribution of the cylinders it failed on and then the engine doesnít run well. Then it would be time for the kit. To have a mechanic install that kit looks to me like a couple thousand dollars.
I have not heard of the failures wiping out the engine. Anyone have other info?
SF
#4628681 - 01/08/18 08:20 PM Re: GM 5.3 Lifters [Re: clinebarger]
das_peikko Offline
No but they got the camshaft available for you incase the AFM lifters destroyed the camshaft.
#4628696 - 01/08/18 08:33 PM Re: GM 5.3 Lifters [Re: Snagglefoot]
Ian1982 Offline
Loc: Ct,USA
It's a 2013 5.3 LC9
#4628708 - 01/08/18 08:42 PM Re: GM 5.3 Lifters [Re: Snagglefoot]
clinebarger Offline
SF
Calls for 11.4 hours, I charge $85 per hour.....$969.00
#4628822 - 01/08/18 11:29 PM Re: GM 5.3 Lifters [Re: Ian1982]
Loc: Alberta
Originally Posted By: Ian1982
It's a 2013 5.3 LC9
Owners manual says 5-30 Dexos. That should work.
SF
Page 1 of 2 1 2 >
