Interior "quick detailer"
by Redright9. 03/25/19 08:21 AM
Seafoam For Last 100 Miles Before Oil Change ?
by ChrisD46. 03/25/19 07:56 AM
WIX 57151XP factory filled with synthetic oil
by Donald. 03/25/19 06:58 AM
BMW Buying Guide: Every Model, Explained
by wemay. 03/25/19 05:43 AM
Double Din Android Auto Advice
by JeffKeryk. 03/24/19 11:25 PM
VW mk5 a/c intermittently works
by ram_man. 03/24/19 11:01 PM
DIY alignment done right?
by tookien. 03/24/19 10:03 PM
Cell phone privacy question
by loneryder. 03/24/19 10:00 PM
Ride quality between 45 and 35 sidewall
by bowlofturtle. 03/24/19 09:23 PM
FRAM TG 7317 - 12K miles opened
by crazy_raccoon. 03/24/19 09:01 PM
2014-2017 Toyota Corolla CVT Quiet Recall
by StevieC. 03/24/19 08:11 PM
Finally Found Factory Ammo my 308 Bolt Gun Likes
by Fastzntn. 03/24/19 08:10 PM
Umarex Glock 19 Co2
by Sonic. 03/24/19 07:57 PM
I put in 2 1/2 qts, damage?
by JLawrence08648. 03/24/19 07:21 PM
How to dispose / recycle Li-Ion batteries?
by 92saturnsl2. 03/24/19 06:16 PM
New member of the (automotive) family!
by addyguy. 03/24/19 06:04 PM
sonusfaber, Rollo, Drifted, Jcar516, gregjr7
67614 Registered Users
89 registered members (2006dodge2500, ArrestMeRedZ, avi1777, alarmguy, Ag76, 14 invisible), 1,836 guests, and 58 spiders.
Topics286,387
Posts4,907,375
Members67,614
Most Online2,967
Mar 10th, 2019
Monroe Shocks Seem 1.5" too short #4628450
01/08/18 06:25 PM
01/08/18 06:25 PM
Louisiana
linuxology Offline OP
Louisiana
Bought some Monroe shocks for replacement on a 2009 Mazda 5. The shock is clearly 1.5" shorter than the OEM. I have contacted the Monroe and they state...
"Monroe uses an improved rebound extension prevention method than the OE and other aftermarket manufactures. We use a spring instead of a bumper. The spring provided better handling and smoother operation. "
Not exactly sure what this means, but I call and the Monroe rep tells me to jack up the control arm so it fits, then bolt every thing up and then let the tension off the jack. Not sure of this advice and don't want to shear off a bolt that the shock connects to. I did not have to jack up control arms, for the OEM shock, so hesitant to do it for the Monroe. Any insights?
Pics here --->
Re: Monroe Shocks Seem 1.5" too short [Re: linuxology] #4628499
01/08/18 07:04 PM
01/08/18 07:04 PM
NoVA
Jimzz Offline
Jimzz  Offline
NoVA
I have used those same shocks on some Mazda 3/5's without issue. I don't think you will have a problem.
yup
Re: Monroe Shocks Seem 1.5" too short [Re: linuxology] #4628503
01/08/18 07:07 PM
01/08/18 07:07 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Its obviously the wrong shock IMO, the double talk is how they justify selling the correct part for one (not yours) and the wrong part for multiple other vehicles.
Re: Monroe Shocks Seem 1.5" too short [Re: linuxology] #4628505
01/08/18 07:09 PM
01/08/18 07:09 PM
WI
HoosierJeeper Offline
WI
I wouldn't run it. I think you'd run a good risk of over extending it and that's not real healthy for the shock if it happens often.
15 Jeep KL Limited V6: Formula Shell 5W20
07 LR3 SE V8: Maxlife 5W30
05 Jeep KJ Limited: PHM 5W30
96 Jeep XJ Country: STP HM 5W30 (winter)
Re: Monroe Shocks Seem 1.5" too short [Re: HoosierJeeper] #4628510
01/08/18 07:12 PM
01/08/18 07:12 PM
PENNSYLVANIA
JeepWJ19 Offline
JeepWJ19  Offline
PENNSYLVANIA
+1!
2002 Jeep WJ 4.0 | Mobil 1 HM 5w30 |
TG8A | 2.5" lift | 148k miles
Software Engineer :]
Re: Monroe Shocks Seem 1.5" too short [Re: linuxology] #4628514
01/08/18 07:16 PM
01/08/18 07:16 PM
Michigan
64bawagon Offline
64bawagon  Offline
Michigan
It comes down to who you believe. the people that built it and have to stand by it, or a group of people with unknown backgrounds and experience on the internet ?
64 Chevy wagon, 10 Jeep Wrangler, 18 Silverado 1/2 ton
Re: Monroe Shocks Seem 1.5" too short [Re: linuxology] #4628535
01/08/18 07:32 PM
01/08/18 07:32 PM
DFW
DBMaster Offline
DBMaster  Offline
DFW
If it's compressed, even a little, with the car on the ground I wouldn't give it a second thought. My vote goes to the "use it" group.
Re: Monroe Shocks Seem 1.5" too short [Re: 64bawagon] #4628541
01/08/18 07:36 PM
01/08/18 07:36 PM
Trav Offline
Trav  Offline
There are two ways of looking at it, do you believe a minimum wage worker on the telephone and answering from a cheat sheet or use a little common sense? If you effect the rebound with a shorter rod you also effect compression.
Replacing a bumper with a spring hence the shorter rod doesn't make any sense but may be someone can enlighten us.
Re: Monroe Shocks Seem 1.5" too short [Re: linuxology] #4628542
01/08/18 07:38 PM
01/08/18 07:38 PM
Kentucky
Fsharp Offline
Fsharp  Offline
Kentucky
Their explanation makes sense: there’s a metal spring inside that’s longer than the rubber bumpstop in the original spring to prevent overextension. However, this means that the shock won’t extend as far by itself, just from the pressure of the nitrogen gas in it.
Re: Monroe Shocks Seem 1.5" too short [Re: Fsharp] #4628548
01/08/18 07:44 PM
01/08/18 07:44 PM
Trav Offline
Trav  Offline
If it the spring is longer than the bump stop but the same length when the spring is compressed and the rod is the same length when not installed I would agree.
Re: Monroe Shocks Seem 1.5" too short [Re: linuxology] #4628554
01/08/18 07:49 PM
01/08/18 07:49 PM
USA
slacktide_bitog Offline
USA
Who made the OE shocks?
Re: Monroe Shocks Seem 1.5" too short [Re: slacktide_bitog] #4628560
01/08/18 07:53 PM
01/08/18 07:53 PM
Louisiana
Louisiana
Think it was KYB after doing some research...
Re: Monroe Shocks Seem 1.5" too short [Re: linuxology] #4628643
01/08/18 08:55 PM
01/08/18 08:55 PM
USA
USA
it'll say who made it right on the old shock smile
Re: Monroe Shocks Seem 1.5" too short [Re: slacktide_bitog] #4628653
01/08/18 09:03 PM
01/08/18 09:03 PM
Louisiana
Louisiana
KYB is the shock for OE.
Re: Monroe Shocks Seem 1.5" too short [Re: linuxology] #4628850
01/09/18 02:19 AM
01/09/18 02:19 AM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
If one does not have confidence in the part and the tech people haven't built on that confidence, it's best to exchange, in my view. Further as to what Trav said, the guy on the phone isn't with you installing the part. wink
Plain, simple Garak.
