Oil For High Sustained RPM on BMW S52
by ZEK
06/21/18 10:41 PM
Chevy brought the blazer back
by WiskyBadger
06/21/18 10:07 PM
LC20 and uses in modern motor oil
by synman
06/21/18 10:01 PM
Full Synthetic CJ-4 or > 5W-30 or 10W-30
by LeTempt
06/21/18 09:57 PM
2018 RAM 1500 EcoDiesel
by OVERKILL
06/21/18 08:37 PM
Fram SureGrip coating
by mobilaltima
06/21/18 08:24 PM
Manual transmissioned electric car
by mjoekingz28
06/21/18 06:45 PM
1991 Toyota Previa New JDM engine Redline
by Kurtatron
06/21/18 06:26 PM
8 yr old channeling John Bonham
by Toy4x4
06/21/18 06:02 PM
Traveller nlgi 2
by Spitter
06/21/18 05:33 PM
Upgrading the Kohler 7000 series air cleaner
by Patrick0525
06/21/18 05:08 PM
Any nano reefers here?
by RichardS
06/21/18 05:04 PM
ARC remanufactured Power Steering Pump
by Pajero
06/21/18 04:58 PM
John Deere "Easy Change" System gimmick
by SnowmanCO
06/21/18 04:55 PM
Oz Planstic Bag Bans - not so green.
by Shannow
06/21/18 04:31 PM
help me choose...
by chaindrive
06/21/18 04:07 PM
France F1 Grand Prix
by DeepFriar
06/21/18 03:16 PM
Valvoline High Mileage with maxlife tech semi-syn
by bradtech
06/21/18 03:16 PM
Best additive in oil to clean sludge?
by ffgb
06/21/18 02:19 PM
Who is a Dirt Track regular?
by thooks
06/21/18 01:39 PM
ZEK, Dudewayne, kmdz, harborbirds, frascati
65292 Registered Users
26 registered (dishdude, Char Baby, ctechbob, buffalobob, bmod305, 2 invisible), 473 Guests and 32 Spiders online.
65292 Members
67 Forums
285749 Topics
#4628385 - 01/08/18 04:32 PM Noob Question : Plastic Knob on OPE
chefwong Offline
Loc: New York
So my fuel control knob went missing while cleaning out the ~bombgenesis~
LOL, found the cherry red knob in the white snow.
Dumb ? but aside from a new knob , any way to tweak the tension spring inside the small little cavity of the knob so it will actually hold it place tight. I just put the knob back on and see why it went missing - tension spring is not holding it in place
Edited by chefwong (01/08/18 04:41 PM)
#4628538 - 01/08/18 06:33 PM Re: Noob Question : Plastic Knob on OPE [Re: chefwong]
Linctex Offline
Loc: Waco, TX
Put a li'l dab of epoxy in it before pushing it back on.
#4628821 - 01/08/18 11:28 PM Re: Noob Question : Plastic Knob on OPE [Re: chefwong]
dwendt44 Offline
Loc: Central Wisconsin
Or Teflon tape.
There's no such thing as:
Too big of a battery,
Too large of a gas tank,
or too loud of a horn,
or too bright headlights.
#4629182 - 01/09/18 11:40 AM Re: Noob Question : Plastic Knob on OPE [Re: chefwong]
yeehaw1960 Offline
Loc: Nebraska
Hopefully, it's not something that has to come off for any kind of disassembly required for a repair. Might just wedge some cardboard in with it, or use glue that stays pliable, so you can pry it back off if necessary. Teflon tape +1 actually.
#4629210 - 01/09/18 12:06 PM Re: Noob Question : Plastic Knob on OPE [Re: chefwong]
EdwardC Offline
Loc: Chicago, IL
Is it something that you need to pull in and out, like the spring is pushing on a ball to hold a position on several detent points? You may be able to pull the spring out and replace it, least stretch it out a little, or maybe add some kind of spacer behind the spring so it pushes harder. Squeezing in a little of the thickest grease you have might help keep it on too.
#4629354 - 01/09/18 02:34 PM Re: Noob Question : Plastic Knob on OPE [Re: chefwong]
chefwong Offline
Loc: New York
Either thickening up the post it slides or or a dab of silicone caulk (for easy removal) is the easy answer I suppose. I'll need to look at the overvall shrouding to determine if X needs to be removed, etc that might interfere.
No ball detent. Inside the knob itself is a thin piece of metal which acts as as tension that holds it in place. I suppose engine vibrations rattled it off. While it fits back, I can clearly see it coming off with the engine on
#4629662 - 01/09/18 07:10 PM Re: Noob Question : Plastic Knob on OPE [Re: chefwong]
EdwardC Offline
Loc: Chicago, IL
Ah, thickening the shaft with a wrap of tape might work well.
