debris in my engine oil--what to do?
by Jasper8146. 09/22/18 03:50 PM
Is this seal bad?
by parshisa. 09/22/18 03:44 PM
Leather Masters Protection Cream review....
by gregk24. 09/22/18 03:13 PM
Aisin WS
by RodneyM. 09/22/18 03:11 PM
Husqvarna trimmer questions
by BrianF. 09/22/18 02:51 PM
Uber Self-Driv Death: Disabled Pedest Avoidance!!!!
by oil_film_movies. 09/22/18 02:29 PM
Question on Backlight setting on LED tv's
by LoneRanger. 09/22/18 02:16 PM
Are all Dexos 1 Gen 2 Oils the Same?
by Gene K. 09/22/18 01:58 PM
ECOGARD X10479 CUT OPEN
by 53' Stude. 09/22/18 01:38 PM
Rust-Oleum Driveway Sealer review
by SVTCobra. 09/22/18 01:24 PM
Flush OAT/IAT mixture
by OpenClose. 09/22/18 12:20 PM
And They Say Spelling is Not Important.
by PimTac. 09/22/18 12:06 PM
Toyota Genuine oil 10W30
by gordond. 09/22/18 09:27 AM
Good Dealers
by HowAboutThis. 09/22/18 09:12 AM
electric brakes rely on heat to work?
by motor_oil_madman. 09/22/18 09:09 AM
help please 7.25 briggs idle too fast
by edwardh1. 09/22/18 08:49 AM
Java update and Flash not working
by JLTD. 09/22/18 08:47 AM
Bought a Giulia
by RamFan. 09/22/18 08:38 AM
Sarrge, Big_R, gordond, mrgreggn, JRMFt11
66040 Registered Users
87 registered members (92saturnsl2, aquariuscsm, Anduril, 77GrandPrix, 13 invisible), 1,859 guests, and 36 spiders.
Topics290,833
Posts4,851,166
Members66,040
Most Online3,590
Jan 24th, 2017
Page 1 of 3 1 2 3
Idemitsu or Mobil 1 #4628297
01/08/18 04:03 PM
01/08/18 04:03 PM
Nor Cal
nate95023 Offline OP
Nor Cal
I bought my new 2016 Sequoia last April and changed the oil at 1k with Mobil 1 0W-20 AFE. I change my oil in all my cars every 5k and I'm almost at 6k. Since this is the second oil change, should I use Idemitsu 0W-20 or stick with Mobil 1 0W-20 AFE? I wonder if I'll get better mileage (13 mpg) if I use Idemitsu. Thanks guys.
2016 Toyota Sequoia Limited-Personal
2016 Ram 2500 Cummins-Work
Re: Idemitsu or Mobil 1 [Re: nate95023] #4628309
01/08/18 04:12 PM
01/08/18 04:12 PM
Michigan
A_Harman Offline
A_Harman  Offline
Michigan
Probably not enough fuel economy difference between the two to measure. Go with whatever is easier to get and cheaper. I think that means M1 AFE from WalMart. Idemitsu is a rare brand to find in the USA. Maybe easier to find in California?
1985 Z51 Corvette track car
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel
1972 GMC 1500 shortbed project truck
Re: Idemitsu or Mobil 1 [Re: nate95023] #4628320
01/08/18 04:25 PM
01/08/18 04:25 PM
Texas, Mentone for work, Galve...
Bryanccfshr Offline
Bryanccfshr  Offline
You won’t see a difference between a 5w30and the 0w20 much less betweeen brands in a sequoia.
Whatever one is in your supply stream and at a price you like should be fine.
2018 Trd Pro 4Runner M1 0w40
2018 Tacoma off-road Castrol 5w30 Magnatec
Re: Idemitsu or Mobil 1 [Re: nate95023] #4628325
01/08/18 04:29 PM
01/08/18 04:29 PM
Danh Offline
Danh  Offline
Fwiw, regular Idemitsu 0w-20 seems to be a fairly typical Group III synthetic. They used to market a molybdenum-heavy “Zepro” version but this seems to have been superseded and was hard to find and pricey in any event.
Mobil1, on the other hand is c. 30-35% PAO in the 0w-20 AFE flavor and c. 65-70% PAO in EP. Even if you don’t think PAO matters, with Wal-Mart pricing Mobil1sure looks like the better choice to me.
Re: Idemitsu or Mobil 1 [Re: Bryanccfshr] #4628329
01/08/18 04:32 PM
01/08/18 04:32 PM
Nor Cal
Nor Cal
What brand do you run in your Pro's?
Re: Idemitsu or Mobil 1 [Re: Danh] #4628331
01/08/18 04:34 PM
01/08/18 04:34 PM
Nor Cal
Nor Cal
Thanks!
Re: Idemitsu or Mobil 1 [Re: nate95023] #4628338
01/08/18 04:43 PM
01/08/18 04:43 PM
Bryanccfshr Offline
Bryanccfshr  Offline
They both have FF in them but will each probably get some Delo LE 5w30 or 10w30 delo semi syn or magnatec 5w30(really haven’t made up my mind but a strong 30 weight is going in)for the summer trail season. Then in August’s and September they both will get the Motorcraft 0w20the dealer uses for the provided oil changes. When the 2 changes are up I will probably stick with a strong 5w30 or 10w30 Synthetic for the year unless I rack up a lot more miles than normal.
I had a FJ cruiser for 7 years and ran nothing but 0w20 AFE in it. Boring, reliable, clean. No complaints. See it running all over the place now with the new owner.
Re: Idemitsu or Mobil 1 [Re: nate95023] #4628342
01/08/18 04:55 PM
01/08/18 04:55 PM
Toronto, Canada
HKPolice Offline
HKPolice  Offline
Toronto, Canada
I used idemitsu 0w20 because it was the cheapest 0w20 locally. There's a reason why OEMs like Honda & Subaru use them: because they're the cheapest. M1 is way better because of the PAO basestocks.
Re: Idemitsu or Mobil 1 [Re: nate95023] #4628381
01/08/18 05:30 PM
01/08/18 05:30 PM
USA
slacktide_bitog Online content
slacktide_bitog  Online Content
USA
For 5k, it doesn't matter. Just use whichever is the better price smile
Toyota recommends 10k when using syn. If you actually did 10k, then M1 would be worth the extra cost
Re: Idemitsu or Mobil 1 [Re: Danh] #4628394
01/08/18 05:42 PM
01/08/18 05:42 PM
toronto
PeterPolyol Offline
PeterPolyol  Offline
toronto
Remember, it's not about the base stocks but the overall performance of the oil. Chasing a single base stock is a fools game wink
Re: Idemitsu or Mobil 1 [Re: nate95023] #4628404
01/08/18 05:50 PM
01/08/18 05:50 PM
Texas
FZ1 Offline
FZ1  Offline
Texas
M1 EP or AFE at Walmart.
Re: Idemitsu or Mobil 1 [Re: PeterPolyol] #4628420
01/08/18 06:01 PM
01/08/18 06:01 PM
Ontario, Canada
OVERKILL Online content
OVERKILL  Online Content
Ontario, Canada
Right, but in oils that are similarly approved, choosing the oil that was obviously more expensive to blend because it has expensive base stocks, makes sense. It will also have superior ultra low-temp performance if that's relevant to a specific situation. PAO doesn't have a point where wax crystals quickly demolish its ability to pump.
2018 RAM 1500 Big Horn EcoDiesel
2016 Grand Cherokee SRT
Re: Idemitsu or Mobil 1 [Re: nate95023] #4628440
01/08/18 06:17 PM
01/08/18 06:17 PM
Idaho
CT8 Offline
CT8  Offline
Idaho
You will never see a noticible mpg increase or decrease by changing oil brands. M1 is a fine oil.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Idemitsu or Mobil 1 [Re: nate95023] #4628444
01/08/18 06:20 PM
01/08/18 06:20 PM
Soviet State of Washington
PimTac Offline
PimTac  Offline
Idemitsu is a great oil but one just as good would be Mobil 1 AFE. I would go with the M1. Easier to find and cheaper.
2017 Mazda CX-5 Grand Touring
Valvoline Advanced Synthetic 0w20
Mobil 1 M108A EP filter
Re: Idemitsu or Mobil 1 [Re: nate95023] #4628460
01/08/18 06:37 PM
01/08/18 06:37 PM
toronto
PeterPolyol Offline
PeterPolyol  Offline
toronto
You know I'm just givin' [censored] with that much-used argument right? We'd all expect to find it like clockwork in a Redline thread, or a Motul thread but definitely not in a Mobil 1 thread. I actually agree with your point, and have made it many times in the past. As a side, I'd bet the Idemitsu has a higher VI than AFE or EP but that's just a hunch.
The Idemitsu and AFE are different animals than EP 0w20 anyway, and the relatively new segment of purpose-built "extended drain" oils (as marketed in North America, independent of existing ACEA and Euro manufacturers specs) is still quite small.
Page 1 of 3 1 2 3
