flat roof weight bearing support
by henni. 09/24/18 06:29 AM
ADD A MARBLE - Make Life Easier
by MasterSolenoid. 09/24/18 06:17 AM
Mobile 1 ESP @ Dowler Karn St. Thomas Ont
by RogerBacon. 09/24/18 05:40 AM
Mobile 1 ESP @ Dowler Karn St. Thomas Ont.
by RogerBacon. 09/24/18 05:37 AM
Direct Injection Valve Cleaning Maintenance
by RayCJ. 09/24/18 05:20 AM
Chattanooga tn ,cycling
by CourierDriver. 09/24/18 04:42 AM
Sunrise, Sunset
by csandste. 09/24/18 02:39 AM
Adding fuel filter- Generator built with no filter
by rubberchicken. 09/23/18 09:57 PM
Clutch Engaging too low
by Spetz. 09/23/18 09:41 PM
SMA - Krown previously, Fluid Film Application
by StevieC. 09/23/18 09:21 PM
First Paint Correction
by RayCJ. 09/23/18 08:33 PM
2011 Dodge Caliber
by dogememe. 09/23/18 07:48 PM
Mixing transmission fluids - partial change
by spk2000. 09/23/18 07:31 PM
Counterfeit MANN filter???
by IllinoisSparky. 09/23/18 06:54 PM
The smell of an oil: VME adds?
by fdcg27. 09/23/18 06:48 PM
Classic road brake pads
by buck91. 09/23/18 06:18 PM
Air up your vehicle's tires
by Papa Bear. 09/23/18 06:07 PM
Lilshady, SevenDu, sigpro, RayCJ, yellow97tt6spd
66055 Registered Users
54 registered members (BeerCan, Atesz792, bullwinkle, asiancivicmaniac, 7 invisible), 1,001 guests, and 35 spiders.
Topics290,927
Posts4,852,595
Members66,055
Most Online3,590
Jan 24th, 2017
When It Rains it Pours #4627647
01/08/18 12:51 AM
01/08/18 12:51 AM
NY, NY
NYEngineer Offline OP
NY, NY
So in another thread, I'm having an ongoing issue with my wife's Kia's charging system. This past Friday, my hour and twenty minute railroad commute turned into 3 1/2 hours to work and three home. While on the train going home, my wife texts me a pic of the dash in my Suburban and says what does this mean? The CEL was lit but all of the gauges were perfect. I asked was it running ok? She replied yes, so I said I'd put the code reader on it when I get home.
I got home, hook up to it and it says something about the TPS. I figured since I have a spare throttle body in the back for breakdowns while traveling, I'd swap it out so the CEL goes out and the truck will remote start since it's been 8 degrees out.
I swapped the throttle body with the new one, reconnected the battery, started the truck for three minutes, off for one minute and on for three again. This was supposed to teach the computer to idle the new TB. Seemed fine. I then drove about ten miles to a friend's house to look at the gas burner and then to see my dad. On the way home, the truck was acting funny and the rpms were up a little but if I braked, it would idle down to 600 where it belonged. I got home, put it in Park and the idle shot up to 3000.
I disconnected the battery again and tried the three minutes on, one off, three on. Never went below 3000.
Out of desperation, and this is our only vehicle until I get yet another new alternator for the Kia, I put the old throttle body back on.
Runs like a champ. No CEL.
Anyone have any idea how to make the computer learn the new part? I would hate to have done this on the road and then try to get it into gear screaming at 3000 rpm. That wouldn't do my trans any favors.
Oh yeah... I did all of this with a raging cold.
Re: When It Rains it Pours [Re: NYEngineer] #4627698
01/08/18 03:46 AM
01/08/18 03:46 AM
North Carolina
rooflessVW Offline
rooflessVW  Offline
North Carolina
Next time try connecting the battery terminals together to discharge any capacitance.
Could be that when you installed the new TB it was cocked slightly and you had an air leak.
Could be that you just needed to drive the truck around longer.
"Zed's dead baby, Zed's dead."
Re: When It Rains it Pours [Re: NYEngineer] #4627759
01/08/18 07:05 AM
01/08/18 07:05 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
The new/old throttle body parts (TPS, IAC if applicable) may be stuck inside from sitting also.
Re: When It Rains it Pours [Re: NYEngineer] #4627831
01/08/18 08:53 AM
01/08/18 08:53 AM
NY, NY
NY, NY
Thanks, Roofless. Hadn't thought of that.
Re: When It Rains it Pours [Re: NYEngineer] #4649301
01/28/18 05:31 PM
01/28/18 05:31 PM
NY, NY
NY, NY
Ok... The CEL started coming up again so I tried this again. Disconnected both cables and touched them together. Also kept them off the battery for about twenty minutes. Installed the new throttle body assembly, reconnected everything, did the three on, one off three on thing. Truck idles nice and has no CEL.
Took it on a few errands, seems fine. Thanks for the advice, Roofless.
Re: When It Rains it Pours [Re: NYEngineer] #4649326
01/28/18 05:58 PM
01/28/18 05:58 PM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
What is the DTC number? Pxxxx
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: When It Rains it Pours [Re: SHOZ] #4649417
01/28/18 07:29 PM
01/28/18 07:29 PM
NY, NY
NY, NY
I don't remember. Sorry It was like a month ago. I didn't put the code reader on it again.
Re: When It Rains it Pours [Re: NYEngineer] #4649437
01/28/18 07:57 PM
01/28/18 07:57 PM
North Carolina
rooflessVW Offline
rooflessVW  Offline
North Carolina
thumbsup
Glad it worked!
