Aisin Warner TF-71SC
by Bailes1992. 12/19/18 06:37 AM
on the Fence about giving up Facebook
by Donald. 12/19/18 06:20 AM
Motorcraft Mercon LV, 15k, 15' Ford Fusion 6F35
by ssamaroo01. 12/19/18 06:14 AM
RockAuto AC compressors
by chrismo. 12/19/18 05:38 AM
Fullers Vintage Ale anyone?
by Lolvoguy. 12/18/18 11:23 PM
Got an alignment
by michaelluscher. 12/18/18 11:18 PM
Castrol Edge 0W-40; 9,762 mi; 2016 Ford Fiesta ST
by asiancivicmaniac. 12/18/18 10:50 PM
Windows Defender Error Code
by ZeeOSix. 12/18/18 10:20 PM
UOA Motul 300V, 5w40, 2013 BMW S1000RR
by Sportbiker. 12/18/18 09:53 PM
Under valve cover pics
by barkingspider. 12/18/18 09:47 PM
Kubota Super UDT2? Anything better?
by Jmoney7269. 12/18/18 09:23 PM
Car Door Fabric Glue
by cb450sc. 12/18/18 08:57 PM
Canadian Uber
by StevieC. 12/18/18 08:13 PM
71141 / Lifeguard 5
by chefwong. 12/18/18 07:52 PM
Tested Positive for Flu
by john_pifer. 12/18/18 07:37 PM
Cooper RTX?
by 01rangerxl. 12/18/18 07:25 PM
blkvzgo, AdamJames, Firefighter3244, Sportbiker, trollhattan
66721 Registered Users
76 registered members (aba4430, 2009Edge, ARB1977, Astro14, 4WD, ABomb369, 8 invisible), 1,418 guests, and 38 spiders.
Topics295,254
Posts4,930,973
Members66,721
Most Online2,553
Oct 27th, 2018
Tire pressure gauge suggestion(s) #4627270
01/07/18 06:01 PM
01/07/18 06:01 PM
New Jersey
twouvakind Offline OP
New Jersey
Looking for an accurate 0-100 PSI tire pressure gauge to purchase. I have a Milton aluminum stick gauge and a unknown brand digital, just looking for an accurate analog or digital gauge to update the tool/glove box. Need the high PSI for presta valve bicycle tires using a presta to Schrader adapter.
Re: Tire pressure gauge suggestion(s) [Re: twouvakind] #4627274
01/07/18 06:06 PM
01/07/18 06:06 PM
Upstate NY
Donald Online content
Donald  Online Content
Upstate NY
Round analog gauge is typically the most accurate. Best to get a gauge that is slightly over tire pressure. If tire pressure is 32 best to get 0-50 vs a 0-100.
2015 Ford F250 w/Powerstroke
Re: Tire pressure gauge suggestion(s) [Re: twouvakind] #4627275
01/07/18 06:07 PM
01/07/18 06:07 PM
MIchigan
Warstud Offline
Warstud  Offline
MIchigan
Re: Tire pressure gauge suggestion(s) [Re: twouvakind] #4627290
01/07/18 06:20 PM
01/07/18 06:20 PM
Georgia
GearJammer Offline
GearJammer  Offline
Georgia
PCL makes some of the most accurate gauges I have used. They are made in Sheffield, England so no worries about Chinese garbage.
https://www.pcltireinflation.com/products/tire-pressure-gauges/
Re: Tire pressure gauge suggestion(s) [Re: GearJammer] #4627296
01/07/18 06:30 PM
01/07/18 06:30 PM
East Tennessee
Starman2112 Offline
Starman2112  Offline
East Tennessee
I donít have one but Iíve heard these are the most accurate in the world.
2018 Toyota Tacoma SR5 2.7L, Mobil 1 AFE 0W-20, OEM filter
2010 Toyota Camry LE 2.5L, Mobil 1 AFE 0W-20, OEM filter
1998 Nissan Frontier XE 2.4L, Castrol GTX HM 5W-30, M1 filter
Re: Tire pressure gauge suggestion(s) [Re: twouvakind] #4627324
01/07/18 06:56 PM
01/07/18 06:56 PM
South Carolina
eyeofthetiger Offline
South Carolina
I like the Longacre analog gauge for setting pressure at the autocross, but I keep a Milton pencil gauge in the gloveboxes for normal use.
2017 Ford Fiesta 1.0T - Valvoline SynPower 5W-20, Motorcraft FL910S
1988 GMC K1500 4.3/700R4 - Supertech 15W-40, Fram TG3980
1986 Ford Ranger 2.0 - uhh
Re: Tire pressure gauge suggestion(s) [Re: twouvakind] #4627327
01/07/18 06:58 PM
01/07/18 06:58 PM
Where the wind comes sweepin'
Reddy45 Offline
Reddy45  Offline
Wouldn't you technically want a gauge that goes from 0 to somewhere around 200 psi? Since most gauges are most accurate in the middle, and not on the extreme ends?
Re: Tire pressure gauge suggestion(s) [Re: twouvakind] #4627331
01/07/18 07:06 PM
01/07/18 07:06 PM
New Jersey
New Jersey
Thanks much all! Looking here https://www.ghmeiser.com/
Re: Tire pressure gauge suggestion(s) [Re: twouvakind] #4627332
01/07/18 07:07 PM
01/07/18 07:07 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
0-100 will give good accuracy in the 40~60 PSI range. I just buy liquid filled pressure gauges and add a tire valve inflater. It's just pipe thread. No biggie. Just make your own laugh
Re: Tire pressure gauge suggestion(s) [Re: twouvakind] #4627344
01/07/18 07:18 PM
01/07/18 07:18 PM
USA
slacktide_bitog Offline
USA
The most important thing about a tire gauge is simply that you have one and actually check the tire pressure from time to time smile
I use one of those cheap ones that are like $1 at Walmart
Re: Tire pressure gauge suggestion(s) [Re: twouvakind] #4627357
01/07/18 07:28 PM
01/07/18 07:28 PM
Upper midwest
Mainia Offline
Mainia  Offline
Upper midwest
This has been tested to be on of the top 2 most accurate tire gauges on the market. This one beat out this manufactures more expensive gauge,
https://www.amazon.com/Accutire-MS-4021B...gital+air+gauge
Here is the dual pack I bought
https://www.amazon.com/Measurement-Ms-40...ct_sims?ie=UTF8
Re: Tire pressure gauge suggestion(s) [Re: twouvakind] #4627383
01/07/18 07:50 PM
01/07/18 07:50 PM
NJ
JLawrence08648 Online content
JLawrence08648  Online Content
NJ
I'd get a good bicycle pump. It will have both Presta and Schraeder. Don't get the kind you have top trust the lock lever, get the kind you pull back on. I prefer Blackburn, Planet Bike, Specialized, Pedro's, Silica.
Re: Tire pressure gauge suggestion(s) [Re: twouvakind] #4627385
01/07/18 07:52 PM
01/07/18 07:52 PM
A Highway Near You
PiperOne Offline
PiperOne  Offline
A Highway Near You
The thing to remember with the pencil style gauges is if you drop them once...they will not be accurate again. I worked (briefly) at a fleet that was ISO certified for every stupid little thing. Everyone in the shop had to send their tire gauges out for testing every 6 months...and no pencil one ever came back as within spec. I agree with the mechanical analog dial gauges..as well as maybe some of the higher end digital ones. We use the digital ones from Haltec (they make all sorts of tire service goodies) but I find myself going back to the analog if I really want to be accurate.
HDEO in Diesel Engines. No spark plugs here.
Re: Tire pressure gauge suggestion(s) [Re: twouvakind] #4627418
01/07/18 08:10 PM
01/07/18 08:10 PM
New Jersey
New Jersey
Pulled the trigger, Accu-Gage...lifetime warranty on parts and re-calibration($3 service charge)
Re: Tire pressure gauge suggestion(s) [Re: twouvakind] #4627536
01/07/18 09:31 PM
01/07/18 09:31 PM
New England
NibbanaBanana Offline
New England
I sent them a money order so the change wouldn't show up on my credit card. I didn't want the charges to show up because the gage was supposed to be a gift for my wife. Never received the gage. Emailed a number of times and no response. They cheated me. Accu Gage cheated me.
1993 Ford E350 5.8L, 68K
2002 Ford E150 4.2L, 85K
2006 Chevy Aveo 1.6L 215K
2013 Kia Reo 1.4L, 101K
7500 OCI, M1 5-30 winter, M1 10-30 summer
