Denso Oil filter - outsourced / quality changed
by 92saturnsl2
06/22/18 02:37 PM
Bench Drill Press
by Propflux01
06/22/18 02:30 PM
IAT Sensor
by artbuc
06/22/18 02:26 PM
2013 Nissan Rogue, 5,100 miles, Supertech Conv
by TheOilWizard
06/22/18 01:46 PM
NC License Plates
by Zee09
06/22/18 01:31 PM
BITOG Hotline!
by Duffyjr
06/22/18 01:30 PM
Switching Additives: Flush/Rinse?
by Phishin
06/22/18 12:46 PM
increasing viscosity
by VQLT
06/22/18 12:31 PM
Who's up on their metallurgy?
by earlyre
06/22/18 11:56 AM
Replaced halogen headlight with LED
by gman2304
06/22/18 11:18 AM
Web Archive
by Duffyjr
06/22/18 10:25 AM
Sonoma This weekend!
by racin4ds
06/22/18 10:22 AM
low water pressure on new kitchen faucet
by Joe1
06/22/18 09:40 AM
Flashing third tail light
by Brigadier
06/22/18 08:59 AM
Intermittent AC Cooling
by Gebo
06/22/18 08:59 AM
Who includes full size spare in tire rotation?
by Parlay_Slow
06/22/18 08:45 AM
Crude and foul behavior
by mjoekingz28
06/22/18 08:31 AM
Best Off The Shelf Car Wash Liquid ?
by ChrisD46
06/22/18 08:30 AM
Wrecking Yards
by Snagglefoot
06/22/18 08:26 AM
F1 - 2018 French Grand Prix
by gofast182
06/22/18 08:14 AM
Fatbrowndog0822, DRNJR, ZEK, Dudewayne, kmdz
65294 Registered Users
88 registered (Astro14, Atesz792, Al, andyd, 92saturnsl2, 12 invisible), 1568 Guests and 31 Spiders online.
65294 Members
67 Forums
285781 Topics
#4626965 - 01/07/18 01:39 PM 2017 Subaru Legacy how to drive
lucerne06 Offline
Loc: northeast
Im a new legacy owner, never a subaru before...anyway...on practically very start up unless completely warmed up the engine revs to 1600 rpms ish and stays there for a few minutes before it starts to come down below 1000 to 750 rpms...so my question is , Number 1. Is this a normal thing ? number 2. Is it better to let it warm up a bit and lower rpms before shifting into gear? also when the gears are shifted a slight delay occurs before it goed from reverse to drive about 1.5 seconds(CVT( transmission) ...Im used to my lucerne starting up and dropping down to idle in 15 seconds, not racing like the subaru...so bottom line what is the BEST Preferred way to drive these cars.. ? thanks
#4626983 - 01/07/18 01:53 PM Re: 2017 Subaru Legacy how to drive [Re: lucerne06]
gregk24 Offline
Loc: FL, USA
It has slightly higher RPM on cold start up to warm up the cats for emissions. On a cold start I will try to let it idle down before taking off, but the oil is everywhere it needs to be within seconds. Just be gentle until it fully warms up.
2012 Honda Accord EX-L K24z3
53,xxx miles
PPPP 0w20 / Fram Ultra
2014 VW Jetta SE 1.8T ea888
37,xxx miles
Castrol Edge 0w40 / OEM filter
#4626985 - 01/07/18 01:54 PM Re: 2017 Subaru Legacy how to drive [Re: lucerne06]
Bandito440 Offline
Loc: NEUS
Yes, itís normal. 1600 rpm is not racing.
I donít know where in the Northeast you are, so warmup time will vary depending on whether youíre living in New Jersey or Maine, and also if itís garaged in a heated space.
If your carís engine is below 30į, warm it up for a minute. If itís much colder, perhaps two or three. Other than that, get in and drive.
'14 Grand Cherokee EcoDiesel
Rotella T6 5w-40 & OEM filter
#4626989 - 01/07/18 01:56 PM Re: 2017 Subaru Legacy how to drive [Re: lucerne06]
GravelRoad Online   content
Loc: Virginia
All normal, rpm's start dropping at 122f coolant (takes 3 to 4 seconds to drop). I wait until 100f coolant (added gauge) then shift to neutral, rpm's drop to idle, then engage drive/reverse. I don't like dropping an auto into gear at high rpm's.
These CVT's are a bit slower to engage from park to drive/reverse, than previous autos I've owned, other than that, I like the way it operates.
2016 Subaru Outback Premium. PUP 5w30 oem filter
2013 Hyundai Elantra loaded. lifetime free oil/filter change
#4627000 - 01/07/18 02:09 PM Re: 2017 Subaru Legacy how to drive [Re: lucerne06]
gathermewool Offline
After the emissions system lights off the cat you can shift to neutral prior to Drive or Reverse and RPM will lower to <1,000. The time to wait for < 1,000 RPM will be similar if you shift immediately to Neutral after starting the engine.
I start my 2015 in the garage and roll it out in neutral. By the time the garage door is shut, RPM has fallen to less than 1,000 and I shift to Drive.
#4627047 - 01/07/18 02:56 PM Re: 2017 Subaru Legacy how to drive [Re: lucerne06]
JTK Offline
Loc: Buffalo, NY
It's exactly how my 3 Subarus (2012, 2014 and 2016) have always cold started. I start it and go. Pretty much never have time or care to start it and let it sit there doing nothing but burn fuel.
If you want to wait for the engine to warm to the point the RPMs will drop on their own, it takes a few minutes of run time in COLD temps.
Edited by JTK (01/07/18 02:58 PM)
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
#4627067 - 01/07/18 03:14 PM Re: 2017 Subaru Legacy how to drive [Re: lucerne06]
NO2 Offline
Loc: Michigan
Just accelerate gently until the engine is warm. It might take a few miles, the 2.5 is really slow to warm up.
#4630842 - 01/10/18 07:35 PM Re: 2017 Subaru Legacy how to drive [Re: JTK]
Nope. Shift to neutral after 10-15 seconds and the RPM drops. Our Forester is not the same and shifting at 1500 RPM can't be helped without sitting for forever.
