Quality Lug Nuts
by jcartwright99. 03/20/19 10:56 AM
More than one Reality
by beanoil. 03/20/19 10:50 AM
Reusable Oil Storage Container
by BamaE92. 03/20/19 10:37 AM
Bank 1 on an Equinox
by Washoe_Mark. 03/20/19 08:47 AM
How do you pronounce the word Vehicle?
by ZZman. 03/20/19 08:21 AM
Inline Fuel Filter
by CCI. 03/20/19 08:08 AM
Are All Douglas Tires USA Made?
by Miller88. 03/20/19 07:30 AM
Turn signal bulbs for '15 BMW?
by Benzadmiral. 03/20/19 07:02 AM
Drain/refill vs diy flush?
by Back40. 03/20/19 05:59 AM
Valvoline 5w30 Synpower HSTS?
by avi1777. 03/20/19 05:05 AM
Castrol Edge 5W50 "Supercar Titanium FST"
by Berto. 03/20/19 02:43 AM
The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
91 E-free, or 91 "up to 10%" for GDI?
by Ws6. 03/19/19 11:12 PM
Ford 2019 F350 oil
by arowbat. 03/19/19 11:04 PM
Royal purple discontinuing 30-1218 ?
by jmj540. 03/19/19 10:02 PM
Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Saxman657, Maxxforce, Washoe_Mark, CG_BrianM, TBF
67565 Registered Users
122 registered members (addyguy, 1978elcamino, 2015_PSD, 69Torino, 2K2AcuraTL, 15 invisible), 1,853 guests, and 55 spiders.
Topics286,116
Posts4,902,933
Members67,565
Most Online2,967
Mar 10th, 2019
Old Ratchet #4626877
01/07/18 01:05 PM
01/07/18 01:05 PM
Tennessee
SWS Offline OP
SWS  Offline OP
Tennessee
I have a Craftsman 3/8 Ratchet that I bought in 1972. Nothing special / well cared for / occasional use / sentimental value exceeds actual value. The internals are getting draggy / sticky on direction selection and it even drags a lot in the 'free' direction (either way). It appears I can take it apart by removing a C clamp, and my idea is to simply clean and lubricate it.
Any suggestions on the task? And what to use for lube? I was thinking something light M1 0W-20, sparingly.
Thanks for your thoughts!
SWS
Re: Old Ratchet [Re: SWS] #4626883
01/07/18 01:08 PM
01/07/18 01:08 PM
Chicago, IL
EdwardC Offline
EdwardC  Offline
Chicago, IL
One common option, if you want to try the lazy way, just dunk the head in ATF and let it soak a while.
Re: Old Ratchet [Re: SWS] #4626885
01/07/18 01:10 PM
01/07/18 01:10 PM
Where the wind comes sweepin'
Reddy45 Offline
Reddy45  Offline
It's not uncommon to service a ratchet. I think the internals need grease, not oil, though. I would disassemble it over a bowl just in case parts fly out smile
Re: Old Ratchet [Re: SWS] #4626899
01/07/18 01:16 PM
01/07/18 01:16 PM
Columbus,Nebraska
Yah-Tah-Hey Offline
Yah-Tah-Hey  Offline
Columbus,Nebraska
Take it apart,clean with brake cleaner or mineral spirits and grease with a moly grease. I have three and service them about once every two years. Last forever if used for intended purpose. No cheater bars please.
Re: Old Ratchet [Re: SWS] #4626909
01/07/18 01:23 PM
01/07/18 01:23 PM
MN
14Accent Offline
14Accent  Offline
MN
That's what I do with my fine tooth gearwrench brand ratchet. It's an extended handle, flex head that I abuse the snot out of. I take it apart and lube it every few months, and I've rebuilt it 3 or 4 times. I'll be sad when the flex joint finally let's go.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2003 Cadillac Seville STS - The winter "beater", it uses the Volt's fuel
Re: Old Ratchet [Re: SWS] #4626921
01/07/18 01:36 PM
01/07/18 01:36 PM
Oshawa, Ontario Canada
JC1 Offline
JC1  Offline
SWS
Do you mean snap ring instead of a C clamp? As others have save take apart, clean and use grease to get it back in top shape.
2015 Grand Caravan SXT Plus 5w-20 Valvoline SynPower/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: Old Ratchet [Re: EdwardC] #4626932
01/07/18 01:51 PM
01/07/18 01:51 PM
Georgia
AVB Offline
AVB  Offline
Georgia
Can use any oil really. My automotive instructor told us that he had a coworker one time that stored his ratchets in a ice cube tray filled with oil.
Re: Old Ratchet [Re: SWS] #4626936
01/07/18 01:59 PM
01/07/18 01:59 PM
VA
Thax Offline
Thax  Offline
VA
Take it down and clean it , relube with Super Lube. It works great on coarse tooth ratchets.
2000 Ford Explorer Limited 5.0L AWD
2018 KIA Soul EX 2.0L
ASE P2 Parts Specialist
AIA Import Part Specialist
KIA certified Senior Technician, Hybrid certified.
Re: Old Ratchet [Re: SWS] #4626952
01/07/18 02:17 PM
01/07/18 02:17 PM
out there
spasm3 Offline
spasm3  Offline
out there
Check the number on your wrench, but you may can use a rebuild/repair kit.
https://www.ebay.com/itm/CRAFTSMAN-3-8-DRIVE-TORQUE-RATCHET-REBUILD-KIT/332511727242?epid=1528232994&hash=item4d6b3e4e8a:g:IMoAAOSwC6dZrZRt
13 elantra 75k 5w30 QSUD
03 chevy avalanche 80k synpwr 5w30
17 mazda cx-5 9500 miles m1 0w30
Re: Old Ratchet [Re: SWS] #4626969
01/07/18 02:41 PM
01/07/18 02:41 PM
San Antonio, TX
das_peikko Offline
das_peikko  Offline
San Antonio, TX
Re: Old Ratchet [Re: SWS] #4626997
01/07/18 03:06 PM
01/07/18 03:06 PM
Charlotte, NC
Oldmoparguy1 Offline
Charlotte, NC
I have 2 of those, both 3/8" and 1/2". Bought around 1962 I think. I had to do the 1/2". Take it apart, clean and dry it, the lube lightly with some chassis grease. I used a grease with moly in it. They both still work great.
thumbsup
A Randomly Selected Thought For The Day:
If Noah had used Zip, he could have used a smaller boat.
Re: Old Ratchet [Re: SWS] #4626998
01/07/18 03:07 PM
01/07/18 03:07 PM
Charlotte, NC
Charlotte, NC
dupe
Re: Old Ratchet [Re: SWS] #4627004
01/07/18 03:15 PM
01/07/18 03:15 PM
Canada
i_hate_autofraud Offline
Canada
When you take it apart watch out for tiny stiff springs that'll jump out,
often they are behind ratchet balls inside, once you lose those, you'll
have a hard time replacing them.
Lube with grease, stays in place and won't run out like oil!
Re: Old Ratchet [Re: SWS] #4627250
01/07/18 06:44 PM
01/07/18 06:44 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
I just toss them in a can half full with ATF when I am done for the weekend. Been doing this since trade school 40 odd years ago and never had one apart to clean yet (had to rebuild a few for tooth damage or slop though, not related to cleaning or lube).
Re: Old Ratchet [Re: SWS] #4627409
01/07/18 09:04 PM
01/07/18 09:04 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Oil works fine for a (frequent) lube, but grease or STP lasts longer.
