Sam_Julier
$50 Site Donor 2024
I have an 8kw GE backup generator. Engine is a Briggs&Stratton Model 310000, 500cc, single cylinder. I don't know if the engine is Intek or Vanguard model. The engine has 30.5 hours total time. Engine would not start at 5 degrees and shut off the exercise cycle. Attempts to start in Manual mode were successful but only on the second or third try. Spark plug was changed from the OE (Champion RC12YC) to the Briggs&Stratton Premium Platinum 5066K plug. At 0 degrees this morning the engine started the first time but after 33 seconds of roughness. But it started on its own. I am thinking of having a service call to check the fuel regulator. Are these engines running on NG typically harder to start than gasoline? I've noticed that when the temp is < 10 degrees the engine stumbles for 10-20 seconds before catching. Thanks in advance for any suggestions.
Sam
Sam
