KFE brake pads?
by deoxy4. 09/25/18 01:16 AM
GM Marine Engine wont start
by Gito. 09/24/18 11:59 PM
New TV bad picture some channels part2
by raaizin. 09/24/18 10:46 PM
Another Bad PCM on a Buick 3.8L!
by clinebarger. 09/24/18 10:17 PM
Funny pictures thread
by JLTD. 09/24/18 08:40 PM
Redline 15w40: Low or Mid Saps?
by SavagePatch. 09/24/18 06:59 PM
What are these cables to?
by 99Eclipse. 09/24/18 06:44 PM
Help with parasitic draw?
by buck91. 09/24/18 05:57 PM
Costco Car Buying Program
by dkryan. 09/24/18 05:39 PM
Glass Scrub?
by buck91. 09/24/18 05:03 PM
Loosing coolant from somewhere
by NICAT. 09/24/18 03:47 PM
2010 or so Ford Fusion Sport thoughts?
by ZZman. 09/24/18 03:35 PM
My boss killed his jeep.
by Chris142. 09/24/18 02:40 PM
Moly question about walmart oils
by jayjr1105. 09/24/18 02:33 PM
Questions About 9011 Bulbs
by knerml. 09/24/18 02:23 PM
Lubricant Additives - A Practical Guide
by wemay. 09/24/18 01:39 PM
fortim, albert001, LG_Electronics, TCam, OzFrog
66063 Registered Users
23 registered members (ArrestMeRedZ, Bailes1992, 2015Corolla, alcyon, 1WildPig, 2 invisible), 786 guests, and 38 spiders.
Topics290,965
Posts4,853,483
Members66,063
Most Online3,590
Jan 24th, 2017
2006 Acura TSX ATF Change? #4626269
01/06/18 07:56 PM
01/06/18 07:56 PM
VA
maverickfhs Offline OP
VA
Finally bought 2006 Acura TSX today with ~175k miles and let's just say 'stole' it legally smile
ATF is brownish in color and definitely planning to do 3x drain and refill, no apparent issues in shifting or anything.
First, should I do drain and refill? I believe it has never been done, would I damage anything?
Thanks for all advice and help.
2006 Civic EX 202K/AT
2006 Acura TSX 180K/AT
Re: 2006 Acura TSX ATF Change? [Re: maverickfhs] #4626293
01/06/18 08:11 PM
01/06/18 08:11 PM
Florida
Artem Offline
Artem  Offline
Florida
How would new oil damage anything? That's just silly.
I recommend you start by doing one drain n fill and see how she shifts. If there's improvement in shift quality, proceed with another flush.
2014 Mazda 3 Hatch 2.0L & 6spd - Idemitsu 0w20 Synthetic @ $0.75 a quart. (thanks Advance Auto Parts for the awesome deal)
Re: 2006 Acura TSX ATF Change? [Re: Artem] #4626297
01/06/18 08:14 PM
01/06/18 08:14 PM
VA
VA
Makes sense, I have done similar on 8th Gen Civic(155k) and after 3rd drain and refill it's shifting flawlessly...
But wanted to check before I proceed... smile
Re: 2006 Acura TSX ATF Change? [Re: maverickfhs] #4626383
01/06/18 09:40 PM
01/06/18 09:40 PM
Staten Island, NY
michaelluscher Offline
Staten Island, NY
I strongly suggest you wait a while (and some miles) between services
I've heard of several Honda transmissions clogging there internal (can't change without a teardown) filters due to rapid cleaning
D&F, drive it maybe 5K, and repeat
'06 Toyota Camry SE V6 3MZ-FE 100k
'01 Mercury Villager Estate VG33E 52k
'06 Ford Taurus SE Vulcan 60k
'13 Chrysler 300 3.6 Pentastar 230k
Re: 2006 Acura TSX ATF Change? [Re: maverickfhs] #4626395
01/06/18 09:54 PM
01/06/18 09:54 PM
Oshawa, Ontario Canada
JC1 Offline
JC1  Offline
Do a drain and fill now and then do another in March or April. Then do another one in summer.
2015 Grand Caravan SXT Plus 5w-20 PPPP/Fram Ultra Filter
1997 Honda Civic CX 5w-30 Shell Conventional/Fram Ultra Filter
Re: 2006 Acura TSX ATF Change? [Re: maverickfhs] #4626405
01/06/18 10:03 PM
01/06/18 10:03 PM
USA
slacktide_bitog Offline
USA
It's easy to drain and fill since you have a drain plug, so no reason not to. In fact, it's even easier than an oil change because you don't even need to put a socket on the 3/8 bar smile
Maxlife is a great synthetic ATF at a good price.
Re: 2006 Acura TSX ATF Change? [Re: maverickfhs] #4626438
01/06/18 10:38 PM
01/06/18 10:38 PM
midwest
JamesBond Offline
JamesBond  Offline
midwest
Our 03 rsx and 05 accord 4cyl 5sp automatics have an external transmission filter. Itís about $20 for the Honda part. Order some aluminum transmission drain plug washers and a case of dw-1 while youíre at it.
Re: 2006 Acura TSX ATF Change? [Re: maverickfhs] #4626518
01/07/18 12:36 AM
01/07/18 12:36 AM
Dallas,Tx USA
aquariuscsm Offline
aquariuscsm  Offline
Dallas,Tx USA
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Quaker State Ultimate Durability 5W20
Re: 2006 Acura TSX ATF Change? [Re: maverickfhs] #4626643
01/07/18 08:48 AM
01/07/18 08:48 AM
The Old North State
Sayjac Offline
Sayjac  Offline
The Old North State
Sounds like a respectable plan for the 06 TSX. Personally, I wouldn't do the 3x d&f procedure in any hurry. I'd do one d&f, put some miles on it, (~5-10k miles), then do another. But that's your call.
TSX specs Z1. I've been using MaxLife in two Hondas specing Z1, 7th gen Civic/3.0L V6 Accord original trans, 100k+ miles between the two using it. Both original trans, just single d&f's at 25-30k mile intervals. ML inexpensive when ordered online through Walmart, generally 2-3 business day store pick up.
As an aside, I really like that the first generation TSX, before they bloated it. If I could find a relatively low miles one in good shape, I'd be very tempted to buy one.
Re: 2006 Acura TSX ATF Change? [Re: maverickfhs] #4626670
01/07/18 09:18 AM
01/07/18 09:18 AM
VA
VA
Thanks Sayjac and everyone.
I have many ATF quarts laying around(Acura ATF - DW-1) so will use them.
You are right, I plan to do 1 D&F, then drive for 1-2 weeks in stop and go traffic, as well as highway driving. Do a 2nd D&F and then finally 3rd one, if all goes well at next oil change.
Re: 2006 Acura TSX ATF Change? [Re: maverickfhs] #4626887
01/07/18 01:10 PM
01/07/18 01:10 PM
Florida
Artem Offline
Artem  Offline
Florida
I Service a lot of cars and always do either multiple drain n fills with quick sprints around the block or a proper oil pan drain and then drain the remaining thru the radiator oil cooler line. I obviously can't have people come back to me over the course of many months to complete a simple tranny fluid change. Haha.
If it's still the original Lube in there, definitely go easy with the flushes just to be safe but I can't imagine anything happening from fresh fluid. If the transmission has a good design and isn't caked with build up, new fluid will not shock it.
I agree with your plan of leaving the new fluid in for a few weeks to give it some time to maybe clean up the internals as it cycles thru.
If it was mine though, I'd replace all the old Lube instantly and then take it easy for a few hundred miles, not revving it high and slowly raise the revs as the clutches settle in with the fresh Lube and added "slippery-ness".
Re: 2006 Acura TSX ATF Change? [Re: Sayjac] #4627384
01/07/18 08:51 PM
01/07/18 08:51 PM
Dallas,Tx USA
aquariuscsm Offline
aquariuscsm  Offline
Dallas,Tx USA
That's how I did mine. I did a drain/refill. Did another in two weeks.
Re: 2006 Acura TSX ATF Change? [Re: maverickfhs] #4627464
01/07/18 09:35 PM
01/07/18 09:35 PM
Ottawa, Ont CANADA
2K2AcuraTL Offline
2K2AcuraTL  Offline
Ottawa, Ont CANADA
I did a trans OCI with Castrol synth AFT for Japanese imports..
my 02 TL was just screaming with that ATF... I couldn't get it out fast enough..
Opted for Petro-Can Duradrive Synth AFT.. and never looked back
J.
02 Acura TL-P
13 Acura MDX-Elite
Both on PP and PP Ultra & Petro-Can Duradrive synth ATF
Re: 2006 Acura TSX ATF Change? [Re: maverickfhs] #4628528
01/08/18 07:28 PM
01/08/18 07:28 PM
Freehold, nj
iluvhonda Offline
iluvhonda  Offline
Freehold, nj
Iím surprised this was not mentioned. Drain and refill, then drive it around and go through all gears for a couple of seconds then drain and refill. Repeat before 1000 miles. There is your 3x.
'99 Prelude 264k Penn Plat Euro 5w-30/Honda A01
'17 Civic Hatch EX 5dr Penn Plat 0W-20 15k Honda A02
Re: 2006 Acura TSX ATF Change? [Re: maverickfhs] #4630585
01/10/18 03:27 PM
01/10/18 03:27 PM
GTA, Ontario, Canada
gogozy Offline
gogozy  Offline
congratulate on the purchase! we have a 2004 TSX is still in love with it!! we love how it drove. enjoy your 2006 TSX I believe it has some internal change that make the engine more lively than 20004/5 model.
I like the way my 2004 TSX drive with Maxlife ATF in it, crisp and precise. nothing wrong with Honda ATF-DW1, just as precise but not as crisp we currently having ATF-DW1 in the TSX (I can not find Maxlife ATF near where I live for over a year now.)
