Sentra manual fluid ?
Salt Lake City Utah
Any other fluid I can use beside OEM ? I went to a few stores and the only have gear oil GL-5, is for a 2012 Nissan Sentra manual
If Genuine NISSAN Manual Transmission Fluid (MTF) HQ Multi 75W-85 is not available, API GL-4, Viscosity SAE 75W-85 may be used as a temporary replacement. However, use Genuine NISSAN gear oil as soon as it is available.
Originally Posted By: sirgerman
$18 for a qt ? is there any other choices ? how many qt do I need ?
I researched it for you just now,and man that Nissan oem stuff got expensive!
Pennzoil synchromesh is available at most parts stores for$8-10 per qt. It works well in everything I’ve used it in.
