2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
How a differential works
by StevieC. 03/25/19 07:37 PM
My first!
by BigMoneyGrip. 03/25/19 07:20 PM
Sizing Rims for 17 inch Light Truck Tires
by Snagglefoot. 03/25/19 06:38 PM
Mobil 1 Cartridge Filters On Clearance at WM
by IndyFan. 03/25/19 06:19 PM
Ford Unibody Pickup
by SubLGT. 03/25/19 05:52 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
86 registered members (alphadog, Aichiguy, agpatel, AdditiveOCD, 77GrandPrix, 11 invisible), 1,422 guests, and 62 spiders.
Topics286,436
Posts4,908,161
Members67,622
Most Online2,967
Mar 10th, 2019
"Window Washer" type program for Mac? #4626193
01/06/18 06:44 PM
01/06/18 06:44 PM
Dallas,Tx USA
aquariuscsm Offline OP
Dallas,Tx USA
I remember all my past Windows computers having my computer wiz friend installing Webroot's Window Washer on them to run every day or so to "clean up" the memory. He said it frees up alot of wasted memory running it on a regular basis. So what I'm wondering,do they make this type of product for Mac?
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Pennzoil Platinum HM 10W30
Re: "Window Washer" type program for Mac? [Re: aquariuscsm] #4626209
01/06/18 07:04 PM
01/06/18 07:04 PM
Windsor, Ontario, Canada
uc50ic4more Offline
uc50ic4more  Offline
A lot of that "wasted memory" was processes and data being cached in order to speed the system up. That data is trivially swapped out if it is ever needed by anything else. Clearing it out and having nothing occupy that memory is the only thing that truly consigns the memory to being "wasted"!
Neither MacOS nor Linux et al. really need much in the way of memory or file system maintenance.
Re: "Window Washer" type program for Mac? [Re: uc50ic4more] #4626227
01/06/18 07:22 PM
01/06/18 07:22 PM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
Exactly thumbsup
2016 Grand Cherokee SRT - Ravenol SSL 0w-40, FRAM Ultra
Re: "Window Washer" type program for Mac? [Re: aquariuscsm] #4626241
01/06/18 07:39 PM
01/06/18 07:39 PM
Dallas,Tx USA
Dallas,Tx USA
So is something like this not beneficial?
https://www.pcmag.com/article2/0,2817,2400840,00.asp
Re: "Window Washer" type program for Mac? [Re: aquariuscsm] #4626274
01/06/18 07:59 PM
01/06/18 07:59 PM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
Not nearly as useful a utility as it is for Windows.
Re: "Window Washer" type program for Mac? [Re: aquariuscsm] #4626431
01/06/18 10:28 PM
01/06/18 10:28 PM
Youngstown, NY
Subdued Offline
Subdued  Offline
Youngstown, NY
Not even very beneficial for Windows, unless you're actually trying to solve some kind of infection.
A system that's running well doesn't need it, and a system that's not running well is probably infected by something and needs more help than these utilities.
2015 Jeep Cherokee 18k
2008 Chrysler Town & Country Touring 149k
2007 Toyota Yaris S 170k
Re: "Window Washer" type program for Mac? [Re: Subdued] #4626444
01/06/18 10:45 PM
01/06/18 10:45 PM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
It's a useful utility on Windows because it allows you to:
- Remove/disable items from startup
- Remove/disable scheduled tasks
- Remove/disable browser add-ons for all major browsers
- Remove the plethora of temp files Windows tends to leave around
I find it a good tool, I just don't use the Registry cleaner part of it. For the other purposes it's a nice single point of access for all of the above functions and puts them in a decent GUI.
Re: "Window Washer" type program for Mac? [Re: aquariuscsm] #4628061
01/08/18 12:21 PM
01/08/18 12:21 PM
US
bunnspecial Offline
bunnspecial  Offline
US
OS X macOS is quite efficient at memory management, and as said you don't really need to worry about it.
Along with other *nix OSs, it works on the philosophy that "unused memory is wasted memory" so it will tend to shift processes to otherwise unused RAM.
In recent versions of OS X/macOS(starting at 10.9) if you go into Activity Monitor, look at the memory tab. There is a graph at the bottom called "memory pressure." As long as it's green, you're fine.
Also, if you do have a burning desire to clear RAM you can open Terminal and type "sudo purge"(without the quotes) and hit enter. It will prompt you for your password(system password-you won't see anything appear on the screen as you type) and will clear out unused memory. Since about 10.10, the value of doing this has been questionable at best. My preferred browser is Firefox, and it's known for memory leaks. I tend to keep sessions open for a long time(basically I only close and reopen it when performance issues start hindering my utility) and I will occasionally execute a purge command in 10.12 for this reason. If you don't use Firefox, or if you do and close it every few days this isn't an issue.
2010 Lincoln MKZ-Mobil 1 5W-30
1970 MG MGB Roadster-Valvoline VR-1 20W-50
