Toyota 2TR-FE 2.7 questions
by Doublehaul. 12/12/18 12:32 AM
Anybody used Eurolub?
by FordCapriDriver. 12/12/18 12:18 AM
Micro-Green Cut Open
by David1. 12/11/18 11:45 PM
Witch way does this valve work?
by Dylan1303. 12/11/18 11:42 PM
Santa came early..
by leoblack9. 12/11/18 11:22 PM
dropped a zip tie in my prius trans
by eljefino. 12/11/18 09:54 PM
2 Cello's - Some talented fellows right here.
by StevieC. 12/11/18 09:49 PM
Something different for sure - Punjabi Celtic
by StevieC. 12/11/18 09:40 PM
Honda eu200i hiccuping @ low idle - fixed
by Jmoney7269. 12/11/18 09:34 PM
Your dealer is here - Humor
by StevieC. 12/11/18 08:46 PM
1994 Honda Civic LX Main Relay-solder
by Gito. 12/11/18 08:43 PM
Winter/Summer Fuel Economy
by RayCJ. 12/11/18 08:33 PM
0w20 oils - NOACK
by superangrypenguin. 12/11/18 08:19 PM
Liqui Moly Special Tec AA 5w20 API SN
by Johnny248. 12/11/18 08:15 PM
Buy a brand new 1966-1977 Ford Bronco
by StevieC. 12/11/18 07:50 PM
2012 Accord,QSUD 5W20,WIX 57356 filter,3K miles
by aquariuscsm. 12/11/18 07:05 PM
Check out this awsome work!
by Chris142. 12/11/18 06:47 PM
200,000 miles
by Marco620. 12/11/18 06:29 PM
tcoffin014, Schm1d, EagleC, Dinka, MechanicGuy
66654 Registered Users
48 registered members (alarmguy, benhen77, BadMonkey, 97K15004WD, 69Torino, 8 invisible), 986 guests, and 35 spiders.
Topics294,964
Posts4,924,981
Members66,654
Most Online2,553
Oct 27th, 2018
5.9 Dodge Magnum oil advice #4626185
01/06/18 05:35 PM
01/06/18 05:35 PM
California
mbacfp Offline OP
mbacfp  Offline OP
California
2003 Dodge Durango 5.9...94,500 miles. Concerned about oil consumption. 1.5 quarts every 3,000 miles or so. Using Pennzoil Platinum 10w-30, yearly OCI. Should I try a high mileage 10w-30 or go straight to a 5w-40. No smoke, leaks, etc. Interested in combating oil consumption. Any advice on this motor.
2014 F-550 PSD..........M1 Delvac ESP 5w-40 + OEM
2018 Dodge Charger SRT Hellcat
2012 Toyota Sienna LTD 3.5L V6
2003 Dodge Durango R/T 4x4 5.9L V8
Re: 5.9 Dodge Magnum oil advice [Re: mbacfp] #4626192
01/06/18 05:43 PM
01/06/18 05:43 PM
MN
14Accent Offline
14Accent  Offline
MN
It's a Magnum... they all burn oil. Valve stem seals usually.
A HM 10W-30 might help, but the seals are probably rock hard at this point and no amount of additive will soften them much. However that's a pretty easy engine to work on and valve stem seals can be replaced even with the heads on.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2003 Cadillac Seville STS - The winter "beater", it uses the Volt's fuel
Re: 5.9 Dodge Magnum oil advice [Re: mbacfp] #4626195
01/06/18 05:48 PM
01/06/18 05:48 PM
California
mbacfp Offline OP
mbacfp  Offline OP
California
Oh ok. Thanks. Thinking Plenum...but none of the symptoms other than oil consumption. Appreciate the info.
Re: 5.9 Dodge Magnum oil advice [Re: mbacfp] #4626452
01/06/18 10:00 PM
01/06/18 10:00 PM
Indy
69Torino Online sleepy
69Torino  Online Sleepy
Indy
Take the air inlet off the throttle body, open the throttle by hand and shine a flashlight down into the plenum. You may see a puddle of oil in the bottom of the intake. If you do, the paper gasket for the plenum cover on the bottom of the intake has failed and gotten sucked in by engine vacuum. Best solution is to reseal it using oil compatible RTV sealant like Permatex Ultra Gray. Ditch the paper gasket all together. Intake manifold will have to be removed for this repair.
1969 Ford Torino GT 390 Auto
2003 Mercury Marauder
1992 Mercury Capri Convertible
2005 Ford Freestyle
2008 Hyundai Santa Fe
2015 Kia Optima
1947 Ford 2N
1978 Honda XL75
Plus Other Stuff...
Re: 5.9 Dodge Magnum oil advice [Re: 69Torino] #4626512
01/06/18 11:28 PM
01/06/18 11:28 PM
MN
14Accent Offline
14Accent  Offline
MN
Not bad advice either. Doesn't hurt to check, and it doesn't take long.
Re: 5.9 Dodge Magnum oil advice [Re: mbacfp] #4626592
01/07/18 05:04 AM
01/07/18 05:04 AM
NE
VNTS Offline
VNTS  Offline
NE
If you have maintained it, it is probably the plenum, but the valve cover gaskets can leak.
I run 5w-30 PUP in mine but any synthetic should work well.
Re: 5.9 Dodge Magnum oil advice [Re: mbacfp] #4627127
01/07/18 03:57 PM
01/07/18 03:57 PM
Bucks, PA
zfasts03 Offline
zfasts03  Offline
Bucks, PA
Wow! That is clean inside!
03 Corvette Z06
-Amsoil 5w-30 SS
07 Honda Accord 2.4L
-Amsoil 5w-20 SS
16 Suburban 5.3L
-M1 0w-20, XG10575
18 4Runner TRD Off Road
- Amsoil 0w-30 SS, TRD filter
Re: 5.9 Dodge Magnum oil advice [Re: mbacfp] #4627182
01/07/18 04:46 PM
01/07/18 04:46 PM
NE
VNTS Offline
VNTS  Offline
NE
Had about70k at the time with mostly Amsoil xw-30 sig series changed yearly. Have some PUP from cheap deals and been running that recently.
5.9 are easy on oil,valve cover was leaking so replaced it, keep an eye on the plenum, have a Hughes kit ready if it needs it but it doesnt use any oil.
Re: 5.9 Dodge Magnum oil advice [Re: mbacfp] #4627210
01/07/18 05:14 PM
01/07/18 05:14 PM
California
mbacfp Offline OP
mbacfp  Offline OP
California
Thanks VNTS. WI'll look into those things.
Re: 5.9 Dodge Magnum oil advice [Re: mbacfp] #4627279
01/07/18 06:09 PM
01/07/18 06:09 PM
Florida
SilverSnake Offline
SilverSnake  Offline
Florida
Had the 5.9L in my 2001 Ram 2500 which I bought new and had for 14 years. Best truck I every owned. Engine flawless. No leaks, smoke or any other issues ever. Ran M1 10W-30 for fist 75K miles and then M1 HM 10W-30 until I traded it at about 140K miles. Oil and filter changed every 3,000 miles religiously. Used about 1/2 quart between OCIs. I would give M1 HM a try. Can't hurt.
2016 Charger, 6.4L-485 HP (PUP 0W-40)
2017 BMW 330i, 2L-248 HP (BMW 0W-20)
2018 Jeep GC, 5.7L-360 HP (PP 5W-20)
2008 20KW Generac (Amsoil 10W-30/30)
