USS Forrestal question
by cjcride. 09/18/18 03:52 PM
Breaker Box
by Throt. 09/18/18 03:00 PM
Honda metal fuel tank seam leak
by wing0. 09/18/18 02:49 PM
Cracked single stage paint
by JHZR2. 09/18/18 01:45 PM
Options versus dealer oil changes
by Schmoe. 09/18/18 01:34 PM
Longevity of Mercon LV in a 2017 Ford Escape?
by mrdctaylor. 09/18/18 01:24 PM
I'm on a Lawn Boy jag
by andyd. 09/18/18 01:13 PM
Old (New) Tires
by ET16. 09/18/18 12:05 PM
iOs 12 for Apple
by madRiver. 09/18/18 12:01 PM
Synthetic oil overrated??
by Ablebody. 09/18/18 12:01 PM
Ferrari Monza SP 1/2
by DeepFriar. 09/18/18 11:58 AM
Any option to "Mark all forums read"
by Rick505. 09/18/18 11:54 AM
1981 280ZX Turbo
by 16HC. 09/18/18 11:12 AM
Muscle car emblems
by Snagglefoot. 09/18/18 10:15 AM
Burn out question
by Fitter30. 09/18/18 10:15 AM
Collector Oil Cans
by Snagglefoot. 09/18/18 10:06 AM
Thoughts on this truck and price.
by ls1mike. 09/18/18 08:39 AM
Canadian Tire Lucas Synthetic Motorcycle Oil 20w50
by Snagglefoot. 09/18/18 07:58 AM
Blast from my past
by 53' Stude. 09/18/18 07:25 AM
tomkat22, tabar2004, SierraMan, Rennmeister, KeithCoates
66004 Registered Users
90 registered members (Ablebody, Astro14, 2oldtommy, 55hambone, 2013ecof150, andyd, 7 invisible), 1,725 guests, and 40 spiders.
Topics290,600
Posts4,847,263
Members66,004
Most Online3,590
Jan 24th, 2017
Page 1 of 3 1 2 3
Motorcraft FL-500 C&P...with a tear! #4626006
01/06/18 02:41 PM
01/06/18 02:41 PM
Washington, USA
Onug Offline OP
Onug  Offline OP
Washington, USA
I hadnít seen many of the FL-500s posted here with tears, so I was really hoping this model wasnít affected by the Purolator quality issues. I actually tried to search and count the various MC posts here to get a ratio of bueno to no bueno...but we all know how limited the search engine is. Iíve cut two others recently and not had any issues, but that record stops today.
The FL-500 I have installed now will be the last Motorcraft filter Iíll use. Even if it doesnít tear, Iíll be batting .250 with these and thatís not acceptable. Guess I should have cut this one open before putting the new filter on...
Somebody can translate the born-on-date...
The ADBV looks great. It flexed without any problems (ignore the dirt on the second picture)
No drama with the spring
Pleats looked nice and straight on the back-side, but...
Then I saw this...
Close up of the tear.
Hard to see in the picture, so I circled it...but even the other end of the torn pleat is starting to show signs of stress.
2016 F-150 3.5L Ecoboost
Current Oil: Castrol Magnatec 5W-30 and Fram Ultra filter
Re: Motorcraft FL-500 C&P...with a tear! [Re: Onug] #4626008
01/06/18 02:42 PM
01/06/18 02:42 PM
Columbus,Nebraska
Yah-Tah-Hey Offline
Yah-Tah-Hey  Offline
Columbus,Nebraska
Call out the National Guard.
Re: Motorcraft FL-500 C&P...with a tear! [Re: Onug] #4626009
01/06/18 02:43 PM
01/06/18 02:43 PM
Idaho
CT8 Offline
CT8  Offline
Idaho
The filters with the tears must be the low restriction racing filters hide
"Don't let your preconceived notions get in the way of facts."
Geoff Metcalf
Re: Motorcraft FL-500 C&P...with a tear! [Re: Onug] #4626019
01/06/18 02:58 PM
01/06/18 02:58 PM
CA
CharlieBauer Offline
CA
How many miles?
It ain't what you don't know that gets you into trouble. It's what you know for sure that ain't so.
- mistakenly attributed to Mark Twain
Re: Motorcraft FL-500 C&P...with a tear! [Re: Onug] #4626020
01/06/18 03:00 PM
01/06/18 03:00 PM
Wet side WA
JohnnyJohnson Offline
Wet side WA
How many miles did you have on that filter when you did your OIC?
2004 Corolla 124642
Out: VML 5w-30 TG4967 OCI 5007 Miles
In: EDGE EP 5W-30 Bosch 3311 122537 7-18-18
2006 Duramax 74277
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 74705 4-22-18
Re: Motorcraft FL-500 C&P...with a tear! [Re: Onug] #4626044
01/06/18 03:30 PM
01/06/18 03:30 PM
Washington, USA
Onug Offline OP
Onug  Offline OP
Washington, USA
Sorry, forgot to add that...4,500 miles/192hrs on this OCI. Iím dropping an oil sample into the mail later today. Should be interesting to see how that fairs.
Re: Motorcraft FL-500 C&P...with a tear! [Re: Onug] #4626085
01/06/18 04:15 PM
01/06/18 04:15 PM
USA
slacktide_bitog Offline
USA
902221713
9 02 22 17 13
Filter was made 2/22/2017
So in other words, they still tear crzy
Next time use Wix, Wix XP, or Fram Ultra smile
Re: Motorcraft FL-500 C&P...with a tear! [Re: Onug] #4626107
01/06/18 04:53 PM
01/06/18 04:53 PM
Jupiter, Florida
Cujet Online content
Cujet  Online Content
Jupiter, Florida
Are you using a high viscosity, or non synthetic oil? Or do you immediately drive off on a very cold engine? I wonder if high oil viscosity is causing the issue.... The modern thought to start driving at 30 seconds warm up on below zero days seems to me to be asking for trouble.
In the piston aircraft world, we use some very viscous oil, but we are cautioned against using any significant RPM until the oil temperature is in the green zone, or about 160 degrees F.
Re: Motorcraft FL-500 C&P...with a tear! [Re: Cujet] #4626116
01/06/18 05:08 PM
01/06/18 05:08 PM
Washington, USA
Onug Offline OP
Onug  Offline OP
Washington, USA
5W-30 (spec for engine) full synthetic. I have remote start for my truck and use it 99.9% of the time. I always give it 3-5 minutes (at least) to warm up, especially when the weather is cold. But where I live (Seattle) it rarely drops below freezing.
Re: Motorcraft FL-500 C&P...with a tear! [Re: Cujet] #4626121
01/06/18 05:13 PM
01/06/18 05:13 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
An oil filter is supposed to protect itself from delta-p damage with its bypass valve. But, it's certainly possible the bypass valve is under designed or can malfunction, especially under very cold start-ups and high engine RPM right after start-up.
We all know that the brittle media combined with large pleat spacing is a good recipe for torn media. I'd say that's also the case here.
Re: Motorcraft FL-500 C&P...with a tear! [Re: Onug] #4626125
01/06/18 05:17 PM
01/06/18 05:17 PM
CA
CA
Thanks for sharing the hours. You've used that filter more than the mileage suggests.
I just did an oil change after 250 hours and left the Fram Ultra on. I'm thinking of leaving it on for another 2 oil changes which will mean 400 to 500 hours more. Based on what I've seen, I think that's not a problem, certainly not in my climate.
You have another FL500 on there. Are you ok with that? I'm personally not touching Purolator filters for the forseeable future.
Re: Motorcraft FL-500 C&P...with a tear! [Re: Onug] #4626129
01/06/18 05:23 PM
01/06/18 05:23 PM
Houston, Texas
WellOiled Offline
WellOiled  Offline
Houston, Texas
Onug - Sorry you had a tear but now we know the 3" OD MC cans are not exempt from tearing. Problem not solved as of 2/22/2017. Thanks for the cut & post. cry
2004 Ford Ranger 4.0L V6
Valvoline Advanced Full Synthetic 5W30 + Fram Tough Guard
Re: Motorcraft FL-500 C&P...with a tear! [Re: Onug] #4626131
01/06/18 05:25 PM
01/06/18 05:25 PM
Georgia
MParr Online content
MParr  Online Content
Georgia
Iím curious. Would priming the oil filter prevent some of these tearing issues that we have seen?
2013 KIA Optima EX 2.4L. Now: QSUD 5W30 & STP S2808ML
2017 Ford Escape SE 2.0T Now: Pennzoil Platinum 5W30 & Motorcraft 910s
Re: Motorcraft FL-500 C&P...with a tear! [Re: MParr] #4626136
01/06/18 05:30 PM
01/06/18 05:30 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
I highly doubt it. If installtng oil filters dry caused tearing you'd see many other brands tearing too.
This is a Purolator problem of combining brittle weak media with wide pleat spacing. We've seen many other filters posted in this forum with wide pleat spacing without tears.
Re: Motorcraft FL-500 C&P...with a tear! [Re: CharlieBauer] #4626139
01/06/18 05:34 PM
01/06/18 05:34 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
Just means the filter saw a lot of low speed driving, which IMO should lead to less overall stress on the media.
What would the resulting tears look like if those miles were all done at high speed driving? shrug Note, don't use weak filters in a race car. grin2
Page 1 of 3 1 2 3
