Originally Posted By: BHopkins
When doing a brake fluid job, you don't really drain all the old fluid before adding the new. Instead, you push the old out with the new.
That said, typically 1 qt is enough for a complete change on most cars and small/medium SUVs. But 2 quarts will assure you that there is plenty.
This ^^^.
