Interior "quick detailer"
by Redright9. 03/25/19 08:21 AM
Seafoam For Last 100 Miles Before Oil Change ?
by ChrisD46. 03/25/19 07:56 AM
WIX 57151XP factory filled with synthetic oil
by Donald. 03/25/19 06:58 AM
BMW Buying Guide: Every Model, Explained
by wemay. 03/25/19 05:43 AM
Double Din Android Auto Advice
by JeffKeryk. 03/24/19 11:25 PM
VW mk5 a/c intermittently works
by ram_man. 03/24/19 11:01 PM
DIY alignment done right?
by tookien. 03/24/19 10:03 PM
Cell phone privacy question
by loneryder. 03/24/19 10:00 PM
Ride quality between 45 and 35 sidewall
by bowlofturtle. 03/24/19 09:23 PM
FRAM TG 7317 - 12K miles opened
by crazy_raccoon. 03/24/19 09:01 PM
2014-2017 Toyota Corolla CVT Quiet Recall
by StevieC. 03/24/19 08:11 PM
Finally Found Factory Ammo my 308 Bolt Gun Likes
by Fastzntn. 03/24/19 08:10 PM
Umarex Glock 19 Co2
by Sonic. 03/24/19 07:57 PM
I put in 2 1/2 qts, damage?
by JLawrence08648. 03/24/19 07:21 PM
How to dispose / recycle Li-Ion batteries?
by 92saturnsl2. 03/24/19 06:16 PM
New member of the (automotive) family!
by addyguy. 03/24/19 06:04 PM
sonusfaber, Rollo, Drifted, Jcar516, gregjr7
67614 Registered Users
88 registered members (ARCOgraphite, Bailes1992, avi1777, 240_Ed, 2010Civic, 97prizm, 8 invisible), 1,707 guests, and 61 spiders.
Topics286,387
Posts4,907,349
Members67,614
Most Online2,967
Mar 10th, 2019
Napa/Gates/Dayco Radiator hoses #4625691
01/06/18 10:32 AM
01/06/18 10:32 AM
Colorado Springs
Drew99GT Offline OP
Drew99GT  Offline OP
Colorado Springs
I'm in the process of replacing the radiator in my Corolla; top plastic tank got a pinhole leak that turned into a geyser. Went with a Denso replacement. Car has a tick over 200K; the factory radiator hoses still look good but since it will all be apart, I figure I'll do the hoses since I plan on driving the car into the ground.
The title says it all; those are my local choices for hoses. I've read Napa = Gates. What should I use??? I'm leaning towards the Napa since they are cheaper. My main concern is fitment and total diameter being equal to the factory hoses so I can reuse the factory spring clamps.
Thoughts? Thanks!
Re: Napa/Gates/Dayco Radiator hoses [Re: Drew99GT] #4625701
01/06/18 10:43 AM
01/06/18 10:43 AM
OH
SatinSilver Offline
SatinSilver  Offline
OH
I'd probably go on Amazon and shop for some OEM hoses. Maybe even just leave them alone if they aren't soft or leaking. They can last the life of the car and are designed that way.
Re: Napa/Gates/Dayco Radiator hoses [Re: Drew99GT] #4625710
01/06/18 10:53 AM
01/06/18 10:53 AM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
Throw those factory clamps in the trash! They are generally a 1 time use. Once removed they often let the hose leak. I work at a radiator shop and hate spring clamps with a passion! Get a quality screw clamp. Recheck it after a few weeks and your good to go.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Napa/Gates/Dayco Radiator hoses [Re: Drew99GT] #4625720
01/06/18 11:02 AM
01/06/18 11:02 AM
Colorado Springs
Drew99GT Offline OP
Drew99GT  Offline OP
Colorado Springs
I knew you'd say that Chris! I value your opinions, but in my experience, the factory spring clamps are the bomb. They never leak or need re-tightening. I always try and reuse them.
Do you have any input on the hoses?
Re: Napa/Gates/Dayco Radiator hoses [Re: Drew99GT] #4625748
01/06/18 11:22 AM
01/06/18 11:22 AM
Staten Island, NY
michaelluscher Offline
Staten Island, NY
Toyota hoses weren't particularly expensive for my Camry
Maybe $20 each
I like OEM on things that can jeopardize an engine (radiator cap)
Consider a variant of the worm clamp, the constant tension clamp
Available on Rockauto for reasonable $
'06 Toyota Camry SE V6 3MZ-FE 100k
'01 Mercury Villager Estate VG33E 52k
'06 Ford Taurus SE Vulcan 60k
'13 Chrysler 300 3.6 Pentastar 230k
Re: Napa/Gates/Dayco Radiator hoses [Re: Drew99GT] #4625807
01/06/18 12:16 PM
01/06/18 12:16 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
+1 screw clamps with the exception of constant tension belleville spring types are one of the worst things ever foisted on an industry.
When you start getting down below freezing they loose tension and leak requiring constant retightening and consequently damage the hose, its common to see the hose poking through the slits on screw clamps.
I prefer Gates or OE to Dayco aftermarket, one trick to reusing the spring clamps is to put them on the neck first then put the hose in the clamp as its going on. Getting the clamp over the hump is the most common problem when using aftermarket hoses.
Re: Napa/Gates/Dayco Radiator hoses [Re: Chris142] #4625815
01/06/18 12:24 PM
01/06/18 12:24 PM
Trav Offline
Trav  Offline
Originally Posted By: Chris142
I work at a radiator shop in sunny California where the temp rarely if ever drops below freezing
Fixed it for ya. You experience with screw clamps does not reflect their performance in other parts of the country especially where the temps drop below freezing and worse. If you worked in up here in skunk hollow you would have a trash barrel full of them.
Re: Napa/Gates/Dayco Radiator hoses [Re: Drew99GT] #4625832
01/06/18 12:39 PM
01/06/18 12:39 PM
Colorado Springs
Drew99GT Offline OP
Drew99GT  Offline OP
Colorado Springs
Yea Trav; we get seriously extreme temperature swings throughout the year. If you installed a regular worm gear clamp in July when it's 95 degrees, come January when it's 10 below, it will be very loose.
Re: Napa/Gates/Dayco Radiator hoses [Re: Drew99GT] #4625860
01/06/18 01:04 PM
01/06/18 01:04 PM
Staten Island, NY
Staten Island, NY
For reference, this is the type of constant tension clamp that you DO want
And this is the one you Don't want to reuse
If your willing to buy new at the dealer, they're great
Not so great as they age and get R&Red during repairs
Re: Napa/Gates/Dayco Radiator hoses [Re: Drew99GT] #4625867
01/06/18 01:10 PM
01/06/18 01:10 PM
MIchigan
Warstud Offline
Warstud  Offline
MIchigan
The OP wanted opinions on hoses.
Re: Napa/Gates/Dayco Radiator hoses [Re: Warstud] #4625876
01/06/18 01:15 PM
01/06/18 01:15 PM
Illinois
javacontour Offline
javacontour  Offline
Illinois
This is BITOG, you always get more than you asked for here.
network down, IP packets delivered via UPS -BOFH
Re: Napa/Gates/Dayco Radiator hoses [Re: Drew99GT] #4625937
01/06/18 01:50 PM
01/06/18 01:50 PM
Chris142 Offline
Chris142  Offline
Dayco,napa/gates are good hoses. Dayco is often smaller diameter. Back to spring clamps. We stopped reusing them due to all the combacks when we reused one.
Re: Napa/Gates/Dayco Radiator hoses [Re: Drew99GT] #4625941
01/06/18 01:51 PM
01/06/18 01:51 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Same here.... I once was a skeptic, but now I love factory hose clamps.
Re: Napa/Gates/Dayco Radiator hoses [Re: Drew99GT] #4625990
01/06/18 02:27 PM
01/06/18 02:27 PM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
I prefer Dayco over Gates anyday. They usually are thicker. Don't waste your money for OEM hoses..
The "thinking" man's friend.
Re: Napa/Gates/Dayco Radiator hoses [Re: Drew99GT] #4626040
01/06/18 03:24 PM
01/06/18 03:24 PM
IL
Vern_in_IL Offline
Vern_in_IL  Offline
IL
Hoses should be good whatever you get..... As long as they stay dry and no oil contact, they are so good.
