Originally Posted By: BlackBeard
There’s many car engines that run even higher temperature turbos, bearing loads, you name it. I’m asking for anyone that is familiar with the oil composition. Not people just reading out of an owners manual. I run many different oils in different applications based on ad packs with no ill effects, this has a high TBN and high anti wear additives so unless you can provide an educated response please leave the opinions out
OK, sure. To me though, the educated person is the one who knows what specification his engine requires and then finds an oil that carries that specification. The reverse is coming on an Internet chat board and asking if an oil that does not carry the specification is acceptable for use. I don't know about you, but I am incapable of determining whether an oil meets a certification standard via spec sheet data or a VOA, but perhaps you are able to do so. I only know that when an oil states it meets the spec then it meets the spec. Maybe that's just me.
Based on your response above I think you've already made up your mind, right? Is the problem that the majority of the responses here didn't agree with what you wanted to hear?
