Michelin's New All-Weather Tire for HD Pickups
by SubLGT. 03/18/19 04:36 PM
Interesting FaceBook argument
by ad_infinitum. 03/18/19 04:36 PM
2000 Silverado Power Steering Pump
by Gito. 03/18/19 04:35 PM
New Full Synthetic Oil from Dollar General
by TheLawnRanger. 03/18/19 04:31 PM
Supertech VS Redline - Project Farm
by StevieC. 03/18/19 03:01 PM
How to fix swollen deckwood
by RazorsEdge. 03/18/19 01:52 PM
Which is more important: Oil or Filter?
by RDY4WAR. 03/18/19 01:45 PM
Dishonest car dealership?
by aquariuscsm. 03/18/19 01:21 PM
Phillips 66 Shield Choice $1.99 @ Orscheln
by Pat in Speedway. 03/18/19 12:41 PM
Barely there back seats
by y_p_w. 03/18/19 11:47 AM
should i be afraid of the DCT ?
by WhyMe. 03/18/19 11:28 AM
Friction modifiers
by Truckedup. 03/18/19 10:57 AM
Sometimes, choices are made for you!
by addyguy. 03/18/19 10:30 AM
I Hope This Amuses You Guys Like It Did Me
by NYEngineer. 03/18/19 10:27 AM
New Exmark Lazer Z / Oil ?
by johnD2. 03/18/19 10:13 AM
First welder recommendation
by Astro14. 03/18/19 09:55 AM
Amsoil Burning
by ridgerunner. 03/18/19 09:38 AM
2007 Sonata Pinging + DTCs
by F24Sonata. 03/18/19 09:31 AM
Indyfordfan, toplscuda, swrve, TomRx, Ozdave
67548 Registered Users
123 registered members (addyguy, AandPDan, 1978elcamino, ABerns, 17 invisible), 2,417 guests, and 58 spiders.
Topics286,020
Posts4,900,960
Members67,548
Most Online2,967
Mar 10th, 2019
Ram Whining in 4WD?? #4624746
01/05/18 11:17 AM
01/05/18 11:17 AM
BerksCounty/Pa.
thorromig Offline OP
BerksCounty/Pa.
Took my Ram out last nite to get groceries with the snow we had & the blustery wind/cold that we have been experiencing. Roads where still covered in good amounts of snow from drifting soo I decided to take the Ram in signature instead of my Acura. Now, the average high for the last two weeks has been mid 20s & with the wind chill -- in the single digits or below zero. I used the truck in the summertime to gather some fire wood at my one buddies house where there was lots of mud to go & from. The Ram never made a noise then or before. Like a whining noise you would hear being in low gear or low 4wd mode im assuming. I had it in high 4wd mode at all times. My fill in the transfer case is Mobil One LS 75W90 gear oil as recommended from a mechanic friend years back to help with that big chain slugging around. Like I said, never made that noise before when I did use it in past winters. I was only going about 45mph max. As soon as I put it back into 2wd mode -- the whining went away completely. When I did engage the 4wd mode to start off, I was stopped & had it in park like I do any other time?? What could or would make that whining noise? Being super cold for a long period of time or what?
00 Dodge Ram 5.2L 4x4 Edge 10W30 FU (91K)
08 Acura TL Type S 3.5L PUPP 5W20 FU (101K)
17 Jetta TSI SE 1.4L Turbo - Edge 0W40 FU (Hers) (4K)
Re: Ram Whining in 4WD?? [Re: thorromig] #4624754
01/05/18 11:25 AM
01/05/18 11:25 AM
Central NY
Miller88 Offline
Miller88  Offline
Central NY
I've never had or been in a 4wd that didn't whine with 4wd engaged and more than 5 or 10 mph.
Normal.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Ram Whining in 4WD?? [Re: thorromig] #4624771
01/05/18 11:35 AM
01/05/18 11:35 AM
Michigan
stockrex Offline
stockrex  Offline
Michigan
Does it whine only under load?
Ridgeline, Dmax, Ford 3.5
Oil Whisperer!*Fear the DINO*
Re: Ram Whining in 4WD?? [Re: thorromig] #4624773
01/05/18 11:35 AM
01/05/18 11:35 AM
South Florida
bubbatime Offline
bubbatime  Offline
South Florida
Does your front differential spin all the time, or just in 4 wheel drive? Check the front diff fluid level. Also, what is the specified fluid for the transfer case? That 75W90 might be too thick for low temps?
And I'm sure you are aware that 4wd can only be used on very slippery roads. If the roads were in good condition, with good traction, then you will wind up the transfer case, which could cause whining I suppose. Shift it back into 2wd to cure your whining issue.
17 Chrysler Pacifica Edge Syn 5W30
13 Yamaha XT250 Valv MC 10W40
10 Acura TSX 2.4 SuperTech Syn 5W20
06 GMC Sierra SuperTech 10W30
Re: Ram Whining in 4WD?? [Re: thorromig] #4624847
01/05/18 12:38 PM
01/05/18 12:38 PM
Ontario, Canada
IndyIan Offline
IndyIan  Offline
Ontario, Canada
4 hi has been pretty silent in every 4wd I've driven. Like quiet enough not to notice your in 4 hi until you turn sharply on pavement.
It wouldn't hurt to climb under there and check levels and see if anything is obvious.
07 Focus ZXW, 5spd manual, 230km M1 5W30
18 Outback 2.5 CVT 22km 0W20
Re: Ram Whining in 4WD?? [Re: thorromig] #4624878
01/05/18 01:05 PM
01/05/18 01:05 PM
Jacksonville, FL
FlyNavyP3 Offline
FlyNavyP3  Offline
Jacksonville, FL
I can see a few potential issues. The gear oil in a transfer case that should have ATF is one of them, this is compounded by the fact that it didn't make noise in the summer when the gear oil would have been thinner, but makes noise now when it's cold. The gear oil (hack) in the 231/241/242 cases is a terrible idea and should not be done IMHO due to the inability of the already insufficient pump to move the thicker fluid. I'd focus your initial search at the transfer case and then move on to investigate the front axle.
Luke
Re: Ram Whining in 4WD?? [Re: thorromig] #4624952
01/05/18 02:22 PM
01/05/18 02:22 PM
Port Orange, Florida
Panzerman Offline
Panzerman  Offline
The transfer case should be ATF fluid. ATF +4.
I never put gear oil in there. That and cold temperatures are my guess too.
2006 Dodge Ram 2500 Hemi 4x4
2016 Dodge Challenger Scat Pack
Re: Ram Whining in 4WD?? [Re: thorromig] #4625012
01/05/18 03:18 PM
01/05/18 03:18 PM
PimTac Offline
PimTac  Offline
I am guessing that your transfer case is chain driven? My experience with 4wd vehicles is that all chain driven transfer cases whine or make noise. If it is really loud then there might be an issue with a bearing or something. If you haven’t changed the fluid in a while that might be a good first step, especially if you have driven through water.
Cannot see signatures any longer so it doesn’t matter.
Re: Ram Whining in 4WD?? [Re: thorromig] #4625139
01/05/18 05:21 PM
01/05/18 05:21 PM
Texas
GMBoy Offline
GMBoy  Offline
Texas
My God get the correct fluid in there first!
Re: Ram Whining in 4WD?? [Re: thorromig] #4625588
01/06/18 08:37 AM
01/06/18 08:37 AM
BerksCounty/Pa.
BerksCounty/Pa.
Will change over the transfer case oil to ATF +4 here soon. The front & rear differential both have Mobil One LS 75W90 also with approximately 25 thousand miles on there fills with no leaks or usage.
Re: Ram Whining in 4WD?? [Re: thorromig] #4627974
01/08/18 11:02 AM
01/08/18 11:02 AM
Central NY
Miller88 Offline
Miller88  Offline
Central NY
Yikes! I didn't notice the transfer case had gear oil in it. That's bad, really bad.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Ram Whining in 4WD?? [Re: thorromig] #4628634
01/08/18 08:47 PM
01/08/18 08:47 PM
Oshawa, Ont. Canada
irv Offline
irv  Offline
Oshawa, Ont. Canada
Is that what your manual calls for, both the same weights front and back?
2017 Chevy Impala 3.6 L.
2013 Ram 5.7 L Hemi Bighorn QC 4x4
2008 Chevy Malibu 2.4 L Ecotec
Pennzoil Platinum and/or Pennzoil Ultra Platinum in all 3.
Re: Ram Whining in 4WD?? [Re: thorromig] #4629165
01/09/18 12:24 PM
01/09/18 12:24 PM
Southeast
meep Offline
meep  Offline
Southeast
If you could handle 45mph, there should have been no need for 4wd. It doesn't help you stop any better than 2WD.
If the traction was good enough then, the system could have been binding. Manual 4WD should only be used when traction is poor, which really negates those speeds at all.
So was the traction really good enough to safely drive 45, in which case the system was binding?
-m
2018 F150
2015 crv (wifey!)
