Matrix totaled
by circuitsmith
06/19/18 08:32 AM
Door rust problems
by Dave Sherman
06/19/18 07:51 AM
2016 Honda Civic problems
by dbias
06/19/18 07:39 AM
Royal purple 75-140 in a subaru rear
by 91camarosRS
06/19/18 07:32 AM
OCI. With short trips. Nissan 4 liter
by Gawardawg
06/19/18 06:52 AM
Approach Watching on the Beach @ St Maarten ...
by LoneRanger
06/19/18 06:41 AM
Honda Accord Needs Shocks; Front, Back, or Both?
by tc1446
06/19/18 05:50 AM
How much oil does your oil filter hold?
by Snagglefoot
06/19/18 05:44 AM
better day
by mx5miata
06/19/18 05:26 AM
BRAVO to Officer Wheeles......
by Sayjac
06/19/18 05:17 AM
People Watching ....Airport style.
by ZZman
06/19/18 04:24 AM
Subaru's at play...
by OneEyeJack
06/19/18 03:50 AM
Treating a 2003 Jetta
by llmercll
06/19/18 01:41 AM
Brakes not working - brake pedal sinks
by tookien
06/19/18 12:42 AM
Dave thinks I can make it 12--15k
by Marco620
06/19/18 12:26 AM
'05 Impala front wheel "squeal". Cost !
by Lee4212
06/19/18 12:16 AM
One Dollar Per Gallon?
by Y_K
06/18/18 11:53 PM
Walmart Tightening up Returns
by John_K
06/18/18 10:21 PM
flare nut wrench set
by spasm3
06/18/18 09:46 PM
Auto trans temperature scanner - help!
by JeffKeryk
06/18/18 09:45 PM
JustaDude, 3horseman, Firedog45, WtsTacoma01, Orion62
65265 Registered Users
84 registered (andyd, BAJA_05, AndyB, 2009Edge, 2004tdigls, ARCOgraphite, 7 invisible), 1499 Guests and 32 Spiders online.
65265 Members
67 Forums
285586 Topics
Page 1 of 5 1 2 3 4 5 >
#4624359 - 01/04/18 10:50 PM Inability to get oil to operating temp
Atomic Offline
Loc: Ohio
Hello,
Last time I stopped by was to get input on what oil I should run in my new Focus RS. I have been on Mobil 1 5w-50 and a Fram Ultra and just completed second oil change at 10.5k (7.5k run).
With the arrival of winter, I am noticing the oil is never exceeding ~170 degrees, even with my 60 mile round trip to work and back, and with my lack of will power to keep from hammering down on it. On a recent 450 Mile road trip, I drove between 80-100 for hours at 3.5k RPM with the oil temp never reaching even 190 degrees.
All said, is this going to have a negative impact on the oil, necessitating a change earlier than the 7.5k I will run normally?
Thanks!
Edited by Atomic (01/04/18 10:50 PM)
1997 Chevrolet Camaro (CAI, Borla Catback, lowered 1.5")- 183k
2016 Ford Focus RS (Stealth Grey)- 15k
#4624362 - 01/04/18 10:51 PM Re: Inability to get oil to operating temp [Re: Atomic]
Alex_V Offline
Loc: Campbellsville, KY
No.
I like Chevy and Valvoline.
'13 Cruze, 1.4T, 112K
'85 GMC C3500, 454, 130K
'82 Mercedes 300CD, OM617 turbo, 167K
'67 Suburban, 350, 331K
#4624373 - 01/04/18 11:10 PM Re: Inability to get oil to operating temp [Re: Atomic]
SandCastle Offline
Loc: Michigan
With the oil struggling to maintain 170F, you obviously don't need 50 weight oil. Even SAE 30 would be too viscous for optimum performance at that temperature. Why not compromise and use 0W-40 year round?
#4624383 - 01/04/18 11:17 PM Re: Inability to get oil to operating temp [Re: Atomic]
Linctex Offline
Loc: Waco, TX
You are seeing "average" temps.
Rest assured, the oil at certain other parts of the engine are seeing well over 212*F.
#4624395 - 01/04/18 11:30 PM Re: Inability to get oil to operating temp [Re: Atomic]
das_peikko Offline
Loc: San Antonio, TX
You sure your thermostat isn't stuck open? What's your water temp say?
#4624402 - 01/04/18 11:44 PM Re: Inability to get oil to operating temp [Re: Atomic]
DoubleWasp Offline
Loc: Fort Lauderdale, FL
Seeing as you have a coolant/oil oil cooler, that is particularly strange. Oil should be close to coolant temps. There should be no issue with it warming up the oil along with the engine.
Coolant temp would be necessary information here.
#4624407 - 01/04/18 11:49 PM Re: Inability to get oil to operating temp [Re: Atomic]
Rolla07 Offline
Loc: MTL, CANADA
My car takes long in winter to show the usual halfway on the temp gauge...cold outside, heat and fans almost at max while idling causes heat gauge to drop to 1/4. Im assuming its normal, as its been like that for years.
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
#4624408 - 01/04/18 11:49 PM Re: Inability to get oil to operating temp [Re: DoubleWasp]
spasm3 Offline
Loc: North Carolina
+1
#4624441 - 01/05/18 12:46 AM Re: Inability to get oil to operating temp [Re: Alex_V]
anndel Offline
Loc: Hawaii, USA
Originally Posted By: Alex_V
No.
+1
#4624445 - 01/05/18 12:54 AM Re: Inability to get oil to operating temp [Re: DoubleWasp]
Linctex Offline
Loc: Waco, TX
Not necessarily.....
oil coolers are always in the "cold" hose (return from radiator to engine)...
and coolant temp sensors are usually near the hottest part (near thermostat housing)
#4624469 - 01/05/18 03:43 AM Re: Inability to get oil to operating temp [Re: Atomic]
KL31 Offline
Loc: South OZ
190F is about 90 Celsius. Sounds normal. The engine will have an oil cooler to help maintain it's preferred operating temp. For most cars that have an oil temp gauge that I've seen, 80-90 Celsius is normal for oil.
In winter my engine struggled to get over 70 celsius. Of course, as others have pointed out, there will be spots in your engine where the oil does indeed far exceed that, the oil circulates and cools down.
Temp gauge location plays a big part. If it's in the sump, it's going to be lower. I have mine in an oil galley plug location. I have no idea why there was a removable galley plug screw in the block. Thanks very much Mazda engineers, you knew I wanted a spot for an oil temp sensor. Otherwise, most people tap into the sump. Good for sump temp, but doesn't tell you what the pistons or heads are seeing.
Also, this is a DI turbo car. If ford recommend 50 grade, it's probably for a reason. If anything, if your winters are not cold, you could switch to 15W50, which might be better for NOACK. 5W50 will probably have more VII and prone to shear more. I'm betting the RS engine would be good at that too.
95 MX-3 2.5L|Shell Helix Ultra 5W40|Wix 51356
04 Focus 1.8L|Wesfil Cooper WZ63|Valvoline MST 5W30
05 Kluger 3.3L|Wesfil Cooper WZ418|Magnatec 10W30 Semi Syn
#4624486 - 01/05/18 05:00 AM Re: Inability to get oil to operating temp [Re: Atomic]
dlundblad Offline
Loc: Indiana
I am just going to say it. 5w50 is too thick with the weather you are experiencing.
Does your owners manual give you a range of weights. Current EB engines require 5w30.
*I would also check the location of your oil temp sensor and see if that plays a roll in what you're seeing.
Edited by dlundblad (01/05/18 05:03 AM)
03 Jeep WJ 4.0 199k Castrol Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 177k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 145k Rotella T5 10w30 Fram TG3980
#4624500 - 01/05/18 05:33 AM Re: Inability to get oil to operating temp [Re: dlundblad]
bbhero Offline
Loc: Virginia
The W the winter rating. So a 5w is just fine. The 50 part I agree with you on.
Edited by bbhero (01/05/18 05:34 AM)
Nissan Altima 3.5 Coupe Valvoline Advanced Full Synthetic 5w30 Federated Auto 4612ex
"Treat your family like your friends and treat your friends like your family."
#4624504 - 01/05/18 05:41 AM Re: Inability to get oil to operating temp [Re: Atomic]
Ethan1 Offline
Loc: 'murica
Ford traditionally specs 5W50 in their track-oriented cars such as the GT and GT500. If you're driving on the street, 5W50 is probably not for you. I would use whatever they spec for the same engine in a different vehicle.
#4624562 - 01/05/18 07:11 AM Re: Inability to get oil to operating temp [Re: Atomic]
ThankYouma Offline
Loc: New York City
50-grade oil seems to be a thing with the new Focus RS, a la new Ford GT which also said 5W-50. As noted, new Mustangs call for 5W-20. (2014 Mustang GT does)
Some quick searching, and I found that many are running Shell Rotella T6 5W-40 in their new Focus RS. http://www.focusrs.org/forum/9-focus-rs-discussions/980-rs-oil-requirements.html#/topics/980?page=2
