'65 Mini.
by Silk. 03/19/19 02:08 AM
Our trash guy is getting on my nerves.
by Chris142. 03/19/19 01:20 AM
Ecogard trans filter
by pda1122. 03/19/19 12:11 AM
4.3 vortec issues
by mobilaltima. 03/18/19 09:17 PM
Recommendation for filter for Alfa Romeo 4C?
by phaphaphooey. 03/18/19 09:17 PM
What's the new wonder elixir?
by Yuk. 03/18/19 08:32 PM
Direct Injection Engines
by Al. 03/18/19 08:31 PM
Which mobil 1 for 19 versa?
by jahwarrior1423. 03/18/19 08:07 PM
RIP Dick Dale
by Donald. 03/18/19 08:06 PM
Found some rust on the roof of my car
by DreamerGT. 03/18/19 07:37 PM
What coolant would you run in a 1997 Dodge Ram?
by zfasts03. 03/18/19 07:11 PM
Is 10k miles too long for tire rotations?
by Nicasio. 03/18/19 06:47 PM
S-Oil Seven $14.88 on Amazon
by Nickdfresh. 03/18/19 06:41 PM
Power Steering Fluid - 07 Tahoe
by Plimbob. 03/18/19 06:38 PM
Oil / filter change 2015 Chevy Sonic 1.8l Automatic
by WyrTwister. 03/18/19 06:36 PM
drsoils, Gbear, MadMikesMech, Indyfordfan, toplscuda
67551 Registered Users
32 registered members (Coventry, billt460, Bailes1992, ChrisD46, aba4430, 3 invisible), 367 guests, and 49 spiders.
Topics286,049
Posts4,901,479
Members67,551
Most Online2,967
Mar 10th, 2019
Filter Replacement and Fluid Exchange #4624077
01/04/18 05:50 PM
01/04/18 05:50 PM
GA, USA
AnonOIl Offline OP
AnonOIl  Offline OP
GA, USA
Hello all! Hope you are doing well. I drive a 2004 Toyota Highlander 4cyl with ~183k miles on her now. I have done 2 transmission drain and refills in the past, relatively close to each other in order to get all the old fluid out when I got the car. They were done with Valvoline Maxlife ATF + Lucas Stop Slip and Castrol High Mileage ATF + Lucas Stop Slip respectively. The transmission is still having some delay going into gears, and I think the transmission filter may be a problem as it has NEVER been changed. Am I on track with this? I was thinking about doing a service soon, draining the pan, dropping the pan entirely and cleaning it, tightening any bolts on the transmission valve body, replacing the filter, reinstalling the pan w/ new gasket, then adding appropriate amounts of Castrol High Mileage ATF + Lucas Stop Slip. Would this help do y'all think? Any fluid and filter recommendations? Also, new drain plug gasket (size?)? Thanks! Have a good day.
Re: Filter Replacement and Fluid Exchange [Re: AnonOIl] #4624102
01/04/18 06:20 PM
01/04/18 06:20 PM
MTL, CANADA
Rolla07 Offline
Rolla07  Offline
MTL, CANADA
Not sure about Lucas Stop Slip, but guessing some folks might be able to recommend a better product to use. Usually they dont drop pans on some Toyota's, not sure if yours is one (my corolla is one) they usually just do drain and fills. If I were you, I would drop the pan, clean the magnet and replace the filter and fill with fresh fill of Synthetic ATF. I prefer Mobil 1 syn ATF, but Maxlife ATF might also be a great fit for you.
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
Re: Filter Replacement and Fluid Exchange [Re: Rolla07] #4624110
01/04/18 06:28 PM
01/04/18 06:28 PM
GA, USA
AnonOIl Offline OP
AnonOIl  Offline OP
GA, USA
Perfect, thank you so much for the advice!
Re: Filter Replacement and Fluid Exchange [Re: AnonOIl] #4624127
01/04/18 06:47 PM
01/04/18 06:47 PM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
Dropping the pan is a good idea. You might be amazed at what stays behind in a transmission that a drain does not remove.
Re: Filter Replacement and Fluid Exchange [Re: AnonOIl] #4624157
01/04/18 07:10 PM
01/04/18 07:10 PM
Florida
gotnogunk Offline
gotnogunk  Offline
Florida
To all you automotive engineer types. Why can't the manufacturers make it a little easier to service a transmission??? I am sure that even the techs would be grateful. We could have a filter that is efficient and easy to change and please a .50 drain plug.
Re: Filter Replacement and Fluid Exchange [Re: DoubleWasp] #4624223
01/04/18 08:25 PM
01/04/18 08:25 PM
Rio Rancho, NM
Pajero Offline
Pajero  Offline
Rio Rancho, NM
Echo DoubleWasp sentiment! Drop the pan and clean. When your next service is due, consider a valvoline flush. I wouldn't do a flush unless you clean and/or replace the screen. You don't want it to get clogged. Good luck sir~!
Respectfully,
Pajero!
Always remember "Planned obsolescence."
1994 Montero SR 3.5 DOHC, 133,xxx
Fram Ultra/ Snorkel with Pre-filter
K-9-Co-pilot
Re: Filter Replacement and Fluid Exchange [Re: gotnogunk] #4624340
01/04/18 11:25 PM
01/04/18 11:25 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Most cars owners never utilize that feature....
we are the III%, really...
Also - the manufacturer only really cares about getting the car past warranty.
99.999% of cars make it past warranty without any transmission issues.
Re: Filter Replacement and Fluid Exchange [Re: AnonOIl] #4624393
01/05/18 12:29 AM
01/05/18 12:29 AM
5600 feet elevation, Arizona
double vanos Offline
I just dropped the pan on my 110k mile F150 6R80 for the first time a couple of days ago. Over the years itís had 3-4 qts pulled and replaced probably 4 or 5 times. I was pleasantly surprised when I inspected the pan to find it clean and free of debris. I cleaned the magnet and even it was relatively clean - Iíve had other jobs where the pan magnet was buried under a lump of metallic mud. Iím trying to figure out why things looked so good: was it a superior fluid (Mercon LV ought to be superior as much as it costs) or a excellent transmission design, or perhaps the filter is so good it catches it all.
The gist is that my experience was a clean pan at change time with minimal fuss over the years.
Sabine Schmitz is the Queen of the 'Ring; Svetlana Kapanina is the Queen of the SKIES...
Re: Filter Replacement and Fluid Exchange [Re: AnonOIl] #4624415
01/05/18 01:00 AM
01/05/18 01:00 AM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
The ZF designed 6R80 is a really really good transmission is why.
Re: Filter Replacement and Fluid Exchange [Re: gotnogunk] #4624493
01/05/18 06:20 AM
01/05/18 06:20 AM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
I think the plan is for us to drive the car untill it quits & then sell you a new car ?
Wyr
God bless
Wyr
God bless
Re: Filter Replacement and Fluid Exchange [Re: DoubleWasp] #4624496
01/05/18 06:22 AM
01/05/18 06:22 AM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
What is ZF ?
Thanks , :-)
Wyr
God bless
Re: Filter Replacement and Fluid Exchange [Re: WyrTwister] #4624503
01/05/18 06:38 AM
01/05/18 06:38 AM
Margate England
Claud Offline
Claud  Offline
Margate England
What is ZF ?
Thanks , :-)
ZF Friedrichschafen AG, is a German based company specialising in the manufacture of drivetrain products, and more recently active and passive automobile safety technology.
They supplied automatic transmissions for many German and French car manufacturers, and much more besides.
Claud.
Re: Filter Replacement and Fluid Exchange [Re: double vanos] #4624886
01/05/18 01:15 PM
01/05/18 01:15 PM
Buffalo, NY
JTK Offline
JTK  Offline
Buffalo, NY
My guess would be the units where you find the pan magnet under a lump of goo never had the fluid refreshed. Every drain and refill removes some solids from the system.
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
Re: Filter Replacement and Fluid Exchange [Re: double vanos] #4638778
01/18/18 01:48 PM
01/18/18 01:48 PM
southwest Mo.
wtd Offline
wtd  Offline
southwest Mo.
What was your procedure for pulling and replacing the fluid without dropping the pan? I have this transmission in my Mustang and want to do drains and refills without dropping the pan.
I assume yours has the short dipstick that you have to access from under the vehicle like mine does. Did you just replace the same amount of fluid that you took out? I've heard that these transmissions have an internal thermostat that makes checking the fluid level kind of difficult. Thanks.
2014 Mustang GT
1998 Chevy K3500
1998 Chevy K1500
(2) 1992 Cavaliers
1970 Monte Carlo
