power company merged and I got the shaft
by motor_oil_madman. 12/13/18 07:19 PM
Space heater burnt smell
by BossMoss. 12/13/18 07:13 PM
Shell Helix Ultra Maserati 10W-60
by wemay. 12/13/18 06:53 PM
Cox Modem Info???
by Gebo. 12/13/18 06:39 PM
How are these Road Force values?
by mclasser. 12/13/18 05:19 PM
Finally broke down a bought a trailer
by BeerCan. 12/13/18 04:25 PM
What oil for '19 Subaru WRX?
by TKNY. 12/13/18 04:12 PM
Splitting wedges
by buck91. 12/13/18 04:00 PM
Avoiding rust in the rust belt states?
by Chris B.. 12/13/18 03:00 PM
Joey Logano and the 2019 Mustang
by Malo83. 12/13/18 02:40 PM
BMW LL01FE Spec
by The Critic. 12/13/18 02:03 PM
I Tried and Failed to Not Buy a New Car
by badtlc. 12/13/18 01:49 PM
OEM Brand Coolant by Rocochem
by NumbersGuy. 12/13/18 01:15 PM
lordcheeto, WondrousBread, slickoo9, turntable_life, Poles19
66670 Registered Users
103 registered members (andyd, alcyon, ad244, Astro_Guy, AdditiveOCD, 97K15004WD, 11 invisible), 1,788 guests, and 40 spiders.
Topics295,042
Posts4,926,555
Members66,670
Most Online2,553
Oct 27th, 2018
'94 Ranger charging at 15.1 volts is this bad? #4623772
01/04/18 12:01 PM
01/04/18 12:01 PM
Marshfield , MA
andyd Online content OP
andyd  Online Content OP
Marshfield , MA
Freaken Rat. Currently reduced to yard duty. The battery is from my last 528e and about a yr old I plug in the 1/2 A floater at least monthly. Cables are clean and tight. When the truck has warmed up for 10 minutes, idle is down to 900RPM. I put a meter across the power port. 15.1 V. A couple hrs, later I checked the battery voltage, 12.67 V. That is nearly a 100% charge. Resting draw is <25.mA. so the floater is definitely not really necessary if the Rat was used more. Should I be checking the water level in the cells? I want to keep the battery as long as possible. I hope to put it into another old BMW in a yr or so. grin2
Thick oil is better grin2
Re: '94 Ranger charging at 15.1 volts is this bad? [Re: andyd] #4623780
01/04/18 12:06 PM
01/04/18 12:06 PM
New Jersey
JHZR2 Offline
JHZR2  Offline
New Jersey
its cold out, the voltage regulator is temperature compensated to some point. Im not seeing an issue if the rested battery is showing 12.67.
A maintenance charge is always prudent.
Re: '94 Ranger charging at 15.1 volts is this bad? [Re: andyd] #4623786
01/04/18 12:09 PM
01/04/18 12:09 PM
Toronto
PeterPolyol Offline
PeterPolyol  Offline
Toronto
^He's right. We get 15V too, but only below freezing and for only a few minutes from a cold start before it scales down to about 14.2V, this is all controlled by the BCM.
Scambling for solutions is a hopelessly futile endeavour and potentially dangerous, without first coming to a solid, personal understanding of the problem. Beware riding the ideological hobby horse.
Re: '94 Ranger charging at 15.1 volts is this bad? [Re: andyd] #4623801
01/04/18 12:18 PM
01/04/18 12:18 PM
Onondaga County
Miller88 Offline
Miller88  Offline
Onondaga County
That's normal after a cold start on a cold morning
18 Forester 2.5I 6M
00 Jeep Cherokee
01 Ford F-350 XL 4x4 5M
Re: '94 Ranger charging at 15.1 volts is this bad? [Re: andyd] #4624072
01/04/18 04:45 PM
01/04/18 04:45 PM
Arizona
Kawiguy454 Offline
Kawiguy454  Offline
Arizona
13.8 - 14.5 max, More than that constantly and you'll cook the battery. Voltage is pressure and too much forces too much current into the cells. If you rev the engine does the voltage go up? if it does bad regulator.
