2011 Chevy equinox overheating
by hardcore302
06/18/18 06:00 PM
Are my rotors warped?
by Dylan1303
06/18/18 05:44 PM
Ultimate Fast Finish on sale at CDN tire.
by irv
06/18/18 05:23 PM
96 Civic 5w20 Castrol GTX Ultraclean UOA
by researcher
06/18/18 04:52 PM
VOA Castrol Magnatec D1G2, 5w30
by researcher
06/18/18 04:38 PM
Unused dented silicone Fram PH8316 cut open
by slacktide_bitog
06/18/18 04:28 PM
Bring back Merkava_4
by mjoekingz28
06/18/18 04:28 PM
Same grade with differing low start temps
by mjoekingz28
06/18/18 04:24 PM
Self defense
by Camprunner
06/18/18 03:13 PM
Any apple experts here?
by maverickfhs
06/18/18 02:50 PM
Cost-no-object 75W-90 GL-5 for a differential?
by d00df00d
06/18/18 02:34 PM
Pittsburgh Dad, this guy is a trip
by Rat407
06/18/18 02:06 PM
14 Jeep GC 5.7, PP 5w20 & 0w20
by Vigg
06/18/18 01:52 PM
Sell me on a SSD drive...........
by ZZman
06/18/18 01:07 PM
need some ideas on my issue
by matrass
06/18/18 12:36 PM
Put Pennzoil Platinum Euro L in a Honda.
by dunlop0078
06/18/18 12:36 PM
BMW V8 Oil Consumption Fix
by doc540
06/18/18 11:25 AM
More info on Valvoline Modern Engine Oil
by buster
06/18/18 11:07 AM
Shelf life of synthetic 2 stroke engine oil ?
by ScottMill
06/18/18 10:34 AM
Oil sample extraction
by Tikka
06/18/18 10:30 AM
WtsTacoma01, Orion62, Revd, blinky1041, mostdecent
65262 Registered Users
100 registered (4WD, Astro14, 555, 1JZ_E46, Aero540T, aquariuscsm, 11 invisible), 1565 Guests and 43 Spiders online.
65262 Members
67 Forums
285535 Topics
#4623361 - 01/04/18 05:42 AM Moving higher and lower from recommended viscosity
KL31 Offline
Loc: South OZ
I'm seeing UOAs with massive fuel dilution and still very acceptable wear metals. 20 and 30 grades turning into 16 grades where the manual calls for 20 or 30 grade, not 0W16.
Other people combating the dilution by using 40 grade oil in car that specs 0W20. No issues.
I have to part my MX-3 out and put the 2.5L 200HP engine into a better condition mx-3 (that I am still on the hunt for). The one that I will eventually find will have a 1.8L V6 130'ish HP engine. It specs 10W30. My thought is (before swapping to the 2.5L engine) to run 50 grade on it because 30 and 40 are widely tried and tested on this engine. And then some 20 grade. And then some 0W16. I'd probably drain the oil, then run desired weight, then drain that and refill after 1000kms or something silly. Just to normalize the viscosity if that makes sense. Would log fuel consumption and note the feel of the engine during tests. Could and should UOA too, to see if there's actually a discernible difference.
Also, I have such a silly oil stash right now, some of which is 10L of 20W50 and 5L of 5W20 so it's a good way to lessen the load in the name of [censored] science.
95 MX-3 2.5L|Shell Helix Ultra 5W40|Wix 51356
04 Focus 1.8L|Wesfil Cooper WZ63|Valvoline MST 5W30
05 Kluger 3.3L|Wesfil Cooper WZ418|Magnatec 10W30 Semi Syn
#4623412 - 01/04/18 06:52 AM Re: Moving higher and lower from recommended viscosity [Re: KL31]
aquariuscsm Online   content
Loc: Dallas,Tx USA
I tried 20W50 in my gf's old 4 cyl Probe (1990 maybe?) many years ago because it burned oil so bad. It REALLY bogged that engine down. I drained it and went back to 10W30 and all was good again.
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Pennzoil Platinum 0W20
#4623429 - 01/04/18 07:21 AM Re: Moving higher and lower from recommended viscosity [Re: KL31]
FermeLaPorte Offline
Loc: Texas (south)
I wouldn't go so high. I would try 0w40
Always Mobil 1
2014 1.6L Nissan Versa Sedan, 5 spd, 5k OCI.
2011 3.5L Chevrolet Impala, Automatic, 5k OCI.
#4623457 - 01/04/18 07:49 AM Re: Moving higher and lower from recommended viscosity [Re: FermeLaPorte]
SR5 Online   content
Loc: Down Under
This is Australia, 20W50 is always an acceptable grade, it's in the constitution or something.
Penrite Vantage 10W40 SN & A3/B4 + Wesfil-Cooper Z154
#4623467 - 01/04/18 08:03 AM Re: Moving higher and lower from recommended viscosity [Re: SR5]
BobsArmory Offline
Loc: Michigan
LOL
Keeping the forces of evil at bay
2016 Chevy Malibu LT 1.5 Liter Turbo
2017 Chevy Equinox LT 2.4 Liter
#4623468 - 01/04/18 08:03 AM Re: Moving higher and lower from recommended viscosity [Re: KL31]
Piston_slap Offline
Loc: Va.
My '94 302ci calls for 10W-30. I investigated viscosity measurements for the high end and decided I would run 10W-40. Big change centipoise-wise in 30vs40. I want the extra cushioning at operating temperature.Oil pressure gauge indicates no change so it must flow unrestricted.
1994 Ford Econoline w/302 & 4R70W
Valvoline 10W-40, Motorcraft FL1
Isotope U235
#4623543 - 01/04/18 09:09 AM Re: Moving higher and lower from recommended viscosity [Re: KL31]
Linctex Offline
Loc: Waco, TX
You won't hurt the engine, but it will feel a little sluggish.
#4623578 - 01/04/18 09:34 AM Re: Moving higher and lower from recommended viscosity [Re: Piston_slap]
tig1 Offline
Loc: Illinois
When my 1990 Tempo had about 140K I tried one fill with M1 15-50. Bogged my engine down as well. I left in one week and went back to M1 10-30.
2007 Ford Fusion 227,000 miles
M1 0-20 EP
2017 Ford Fusion 49K
M1 0-20 EP
M1 ATF and MC LV
M1 10-30 in all OPE
MC filters
#4623765 - 01/04/18 11:54 AM Re: Moving higher and lower from recommended viscosity [Re: KL31]
Serge Offline
Loc: Minnesota, USA
My rule is if the engine is starting to use or leak oil then switch to the next highest grade. I have a 07 mazda3 that i used 0w20/5w20 for 120k miles then swiched to 5w30/10w30. 180k on it now, no leaks and doesnt burn oil. As soon as i see any sign of burning or leaking i will switch to 5w40/10w40. Been doing this for over 15yrs. Works for me.
On the other side if motor calls for say 5w30 then i wouldnt go a grade lower 5w20 unless you have an oil pressure gauge and know its 100% safe.
08 135i (600hp) 60k Redline 5w40
13 X3 28i (375hp) 50k Castrol 0w40
07 Mzd3 2L 185k 10w30
11 Mzd6 2.5L 115k 10w30
14 Mzd3 2L 30k 0w20
16 Yukon XL 15k 0w20
#4623949 - 01/04/18 02:51 PM Re: Moving higher and lower from recommended viscosity [Re: Serge]
tig1 Offline
Loc: Illinois
The engine in my 2007 Ford Fusion is the 2.3. Probably the same engine that you have in your Mazda. I now have 218K all on either 5-20, but mostly on 0-20. No leaks, or oil weeping, or oil consumption at 10K OCIs.
M1 0-20 EP
M1 0-20 EP
M1 ATF and MC LV
M1 10-30 in all OPE
MC filters
#4624015 - 01/04/18 03:43 PM Re: Moving higher and lower from recommended viscosity [Re: KL31]
KL31 Offline
Loc: South OZ
Oil pressure gauge is on the list. Already have coolant and oil temp. Would be good to see start up pressure and hot pressure on a 0w16. I'm. Not afraid to run much lower viscosity as the test engine will be pulled eventually anyway. Can't stand the 1.8L power, sounds amazing but it's all bark no bite.
#4624290 - 01/04/18 08:58 PM Re: Moving higher and lower from recommended viscosity [Re: KL31]
lawrencerd Offline
Loc: NC
I've gone up a grade to 5w30 and down a grade to 5w30 in two vehicles lately and I can't say I gained or lost anything of statistical relevance. I thought my Audi was a little quieter on 0w40 but I also went from flagship euro oil to a dexos blend. My conclusion is that I'll go back to the mfg. spec when I resupply but I won't be afraid to use my clearance oil. My Jeep feels like a dog with 40 grade though so I like your idea of trying it in the particular vehicle, especially if you already plan to move on from that engine.
