Miles Synthetic...Specs Provided
Originally Posted By: Virtus_Probi
I'm not seeing any specs, to be honest...
Me neither. That's just general product info.
Until I see some manf. info like a TDS I don't believe I would use it.
Is it on GM's Dexos1 approved list?
https://images-na.ssl-images-amazon.com/images/I/71BqPYuXUyL.pdf
https://images-na.ssl-images-amazon.com/images/I/71vD5Bvi-EL.pdf
Here we go, amazing what a GOOGLE search provides
I don't have the source but I believe someone did find that it's Dexos g1 approved. I think the trick was that it's listed in the Dexos list under a different name the company uses?
You can get this on amazon and ebay also.
I didn't buy the 5 gallon jug because it looks like it would be a mess without the $40 pail pump.
And with the $40 pail pump it becomes less of a deal
Reliance Fluid Technologies is what the Milesyn stuff is listed as on the API website, all the 'Gas' oils are SN/GF5.
https://engineoil.api.org/Directory/EolcsProductResults?accountId=-1&brandName=milesyn
FWIW I'm currently using their SXR5W20 and have a bucket of 5W30 waiting in the wings. All seems to work just fine, no odd issues to report.
Several of their oils were Dexos listed, but that license has expired and I haven't seen any update to the new spec, but I have no DI cars so it doesn't really matter to me. As for getting it out of the pail, I just tip it off into a Valvoline 5qt jug, very easy, no mess.
If you turn the spout to the top, it's very easy to fill 1-gallon or 5-qt jugs without spilling a drop.
