Synthetic motor oil in a gun
by Yuk. 03/26/19 01:07 AM
air suspension on a towed trailer?
by columnshift. 03/25/19 11:57 PM
AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
33 registered members (carlprop, das_peikko, alcyon, clinebarger, csandste, Ag76), 715 guests, and 67 spiders.
Topics286,442
Posts4,908,224
Members67,622
Most Online2,967
Mar 10th, 2019
Page 1 of 4 1 2 3 4
.300 AAC Blackout #4622299
01/02/18 11:17 PM
01/02/18 11:17 PM
Douglas County, Colorado
bigj_16 Offline OP
bigj_16  Offline OP
What is the reason behind the popularity of this round, other than it fitting on an AR platform?
Re: .300 AAC Blackout [Re: bigj_16] #4622317
01/02/18 11:48 PM
01/02/18 11:48 PM
Wet side WA
JohnnyJohnson Offline
Wet side WA
Sub sonic 200 Gr bullets make it really quite with a suppressor.
2004 Corolla 130035
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 74725
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: .300 AAC Blackout [Re: JohnnyJohnson] #4622415
01/03/18 05:52 AM
01/03/18 05:52 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Hog hunting (with suppressor).
You can just lay the hogs over with very little sound.
Otherwise, one loud band and the whole group scatters.
Re: .300 AAC Blackout [Re: bigj_16] #4622435
01/03/18 06:50 AM
01/03/18 06:50 AM
Glendale, Arizona
billt460 Offline
billt460  Offline
Glendale, Arizona
The whole .300 AAC Blackout craze was built around suppressed weapons. It works much better in that capacity than the .223 / 5.56 MM standard AR-15 chambering's, because it is a subsonic round. Or can be with the right load. Yet it still contains some downrange punch because of the much heavier .30 caliber bullets it utilizes. If you try to reduce the velocity of the .223 / 5.56 MM to subsonic levels, the round loses far too much ballistic effectiveness.
That, along with the fact it can utilize standard 5.56 MM, AR-15 bolt carrier groups and magazines, make it very adaptable to anyone who is already shooting a standard .22 caliber centerfire AR-15. Basically change the barrel and you're good to go. But if you are not interested in shooting suppressed, there really isn't much advantage in going to it over a 7.62 X 39 MM AK-47, or AR-15 weapon. Some will argue it feeds better in a AR platform weapon than the 7.62 X 39 MM does. And as I mentioned it doesn't require separate magazines. But 7.62 X 39 MM ammo is much cheaper, and far more available. And ballistically if you are already shooting a AK-47, there isn't enough difference between the two, that would bring any advantage to going to the .300 AAC Blackout. Some might argue it has better accuracy than a AK. But it's really not a long range round in the first place.
Re: .300 AAC Blackout [Re: bigj_16] #4622457
01/03/18 07:47 AM
01/03/18 07:47 AM
Port Orange, Florida
Panzerman Offline
Panzerman  Offline
Billt460 has said it all and said it well.
I pretty much think it's a gimmicky round myself.
Ballistically same as a AK-47 round which most AR shooters consider obsolete then build a cartridge the same and it's all the rave.
2006 Dodge Ram 2500 Hemi 4x4
2016 Dodge Challenger Scat Pack
Re: .300 AAC Blackout [Re: bigj_16] #4622486
01/03/18 08:33 AM
01/03/18 08:33 AM
Michigan
BobsArmory Offline
BobsArmory  Offline
Michigan
I have 2 300 Blackouts in the AR platform and another in an Encore single shot pistol. 1 set up as an AR pistol (registered as a pistol) with an 8.5 inch barrel and another set up for hunting with a 16 inch barrel and I absolutely love both. The pistol, since it's registered as such is legal to carry loaded with a 30 round mag in my vehicle at all times. Very handy for impromptu varmint control. The pistol is also very quick for clearing a home being so short. The 16 inch rifle, like I said is set up for hunting and is good out to 200 yards on deer sized game with 110 or 120 grain Barnes TAC-TX ammo and very little recoil.
Bilt460 is mainly on point but I would like to add a couple points.
1. 300 BLK round can be much more accurate than the 7.62x39. An inch or less groups at 100 yards is not uncommon with quality ammo.
2. As a rule you can get higher quality ammo in 300 BLK than what is normally available in 7.62x39.
3. 300 BLK is very efficient in short barrels. I don't lose tons of velocity in my 8.5 inch barrel.
4. When suppressed, the 300 is a dream to shoot. It's so quiet that you can often hear the bullets impact the game you are hunting. Even better in a bolt action rifle.
It doesn't have the power of a 30-06 or the low cost ammo of an AK but it does some things that other rounds can't do.
Keeping the forces of evil at bay
2016 Chevy Malibu LT 1.5 Liter Turbo
2017 Chevy Equinox LT 2.4 Liter
Re: .300 AAC Blackout [Re: bigj_16] #4622489
01/03/18 08:40 AM
01/03/18 08:40 AM
bigj_16 Offline OP
bigj_16  Offline OP
Thanx for all the input, guys. I have a little more insight now.
Re: .300 AAC Blackout [Re: bigj_16] #4622587
01/03/18 11:24 AM
01/03/18 11:24 AM
Glendale, Arizona
billt460 Offline
billt460  Offline
Glendale, Arizona
To me the absolute biggest drawback to this round is cost. It's phenomenally expensive for what it is. This place is just down the road from me, and they're charging $542.00 and $592.00 a case of 1,000 rounds for S&B and Magtech. (Pull the scroll bar on the right about 2" down). That's almost DOUBLE for what most 5.56 MM is going for. And close to what you can buy bulk .308 for. And when you consider it's basically just a modified cut down .223 case with a larger bullet, and about the same amount of powder, the cost makes even less sense.
https://www.unammo.com/
Sure you can get around that by handloading. But the cases are still a PITA to make in the kind of quantity you'll need to do the same amount of shooting with as you would with a 5.56 MM. Not to mention it's time consuming to cut and trim them to length. You can buy .300 AAC Blackout brass ready to go. But again it's cost prohibitive when compared to 5.56MM.
When you compare this added cost, and it's ballistics to the AK round, it's just too expensive. At least to do any kind of high volume shooting with.
Re: .300 AAC Blackout [Re: bigj_16] #4622591
01/03/18 11:27 AM
01/03/18 11:27 AM
Santa Barbara, CA
bdcardinal Offline
bdcardinal  Offline
Santa Barbara, CA
I have one and am looking forward to getting it all together soon. I have been cleaning Wal-Mart out of the Remington .300 Blackout every-time I go. I also have a .458 SOCOM upper to try out also. Just need to wait for all the ranges to open, they are all closed due to fire danger.
The downside that I have seen is people brain [censored] and load a magazine of .300 Blackout into an AR with a .223/5.56 upper. I have different color magazines that I know are for certain calibers.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: .300 AAC Blackout [Re: bigj_16] #4622671
01/03/18 12:57 PM
01/03/18 12:57 PM
New Jersey
JHZR2 Offline
Global Moderator
JHZR2  Offline
Global Moderator
New Jersey
Have you shot it? Suppressed? Do so and you'll see why.
Re: .300 AAC Blackout [Re: bigj_16] #4622741
01/03/18 02:13 PM
01/03/18 02:13 PM
Canada
i_hate_autofraud Offline
Canada
Yrs back I used to go regularly to the Knob Creek MG shoot in Kentucky, right next to Fort Knox!
They shoot a lot of suppressed stuff. They have a separate range in the back so you can really
enjoy suppressors with ear plugs out. My pal had a pre-'86 2-stamp MP5SD we used to run on the
"jungle walk" course in the back - nice! smile
Key issue: It's the hi volume hi speed gas at the muzzle that make the suppressor less
effective in .223, etc. Flight noise from a supersonic round doesn't carry that far, more like
a fast whizzing sound, not a bang. Any bang you hear is the unsuppressed portion of the blast,
not the sound of the actual bullet.
The heavy .300 blackout round delivers decent energy with way less chamber pressure acting on a
larger sectional area of the bullet then the much smaller .223!
Locally up here a few weeks back, cops where at the range using small muzzle cans on ARs, reduced
the .223 blast to a light .45 report, looks like their guns were set up for CQB use. Compact cans
(suppressors) only do so much, I'd rather have the MP5SD, way quieter, the action sound you hear
thru your cheek bone (cheek weld to the stock) is a bolt 'clunk' rather then a "skretchy screen
door" sound of an AR bolt carrier and buffer spring cycling! LOL (But I'll still keep the AR!)
Re: .300 AAC Blackout [Re: BobsArmory] #4622840
01/03/18 03:52 PM
01/03/18 03:52 PM
The land of USA-made Subies!
SubieRubyRoo Online happy
SubieRubyRoo  Online Happy
The Rifle Dynamics AK-47 with a Sharps Bros. milled receiver printed 0.5-0.7" groups at 100 yards (with steel-cased Brown Bear ammo, 124gr HPs). I'm pretty sure most off the shelf 300 BLKs can't do 0.5" groups. Don't compare Eastern Bloc mass-produced AKs to precision 300 BLK rifles made in the USA... compare apples to apples.
AK's are not long-range tactical weapons. I saw a recent report that said over 96% of ALL shooting encounters happen inside of 150 yards, whether police snipers, personal protection, or even hunters. Inside this 150-yard window, an AK is just as lethal as any other long gun in 30 cal range. "Deader than dead" doesn't get you any extra points. AKs make great Stuff Hits The Fan weapons because they are plenty accurate to stop people-sized targets, and they don't care about abuse or lack of cleaning. You pull the trigger, it goes BANG. To me that's more important than subsonic performance or anything else. smile
Re: .300 AAC Blackout [Re: SubieRubyRoo] #4622912
01/03/18 05:08 PM
01/03/18 05:08 PM
Glendale, Arizona
billt460 Offline
billt460  Offline
Glendale, Arizona
Agree 100%. There is far too much made over accuracy in regards to battle and hunting rifles. None of these weapons when used in the field are required to be anymore accurate than the shooter can fire them from field positions. These suppressed .300 Blackout rifles are CQB battle weapons, not National Match target rifles on the 600 yard firing line at Camp Perry.
Re: .300 AAC Blackout [Re: billt460] #4623258
01/04/18 12:03 AM
01/04/18 12:03 AM
Michigan
BobsArmory Offline
BobsArmory  Offline
Michigan
I would disagree. When taking game a hunter wants the best shot placement available. Battlefield "Pray and Spray" idea is not ethical in any way shape or form while hunting game. Hunters want to be able to retrieve the animal and at the same time make an ethical kill quick and clean. An accurate rifle is a must when killing game. In my humble opinion anyone that tells you different has to rethink their hunting ethics and has hunted game at any range beyond 75 yards. Again, in my humble opinion.
Re: .300 AAC Blackout [Re: bigj_16] #4623263
01/04/18 12:15 AM
01/04/18 12:15 AM
Michigan
BobsArmory Offline
BobsArmory  Offline
Michigan
A rifle dynamics AK will cost you $2,000 or more with no optics. I can't find a guarantee of accuracy that states .5 to .7 MOA on their website. Subie, can you find that info for us?
Page 1 of 4 1 2 3 4
