The entire rear end depends on the diff lube; gears, limited-slip, wheel/axle bearings, pinion bearings. Do I use what's best for one component (LSD) at the expense of the rest of the components?
As I understand it, the synthetic lube does not hurt the Tru-Track, it just doesn't allow it to lock up as readily....which should, in theory anyway, make it last longer.
