VW Passat R36 504 00/ 507 00 oil
by antik. 03/23/19 04:43 AM
Oil for 2015 Ford Explorer
by oilnut12. 03/23/19 12:48 AM
Blains farm and fleet citgo syn
by BTLew81. 03/22/19 10:48 PM
2003 Duramax 208, XXX miles Rotella T4
by TurboJW. 03/22/19 08:11 PM
Turn signals on the freeway?
by das_peikko. 03/22/19 08:05 PM
Running Boards Restored
by kstanf150. 03/22/19 07:38 PM
QSUD at Canadian Tire
by Snagglefoot. 03/22/19 07:29 PM
Camry vs Accord vs ???
by Joe1. 03/22/19 07:26 PM
Fire up
by Matagonka. 03/22/19 07:16 PM
Mobil-1 AFE Discounted at Sam's Club
by ekpolk. 03/22/19 06:20 PM
Test drove a Tesla Model 3
by y_p_w. 03/22/19 05:54 PM
Did i make a mistake? Hilux 3.0 d4dhello
by Anton93. 03/22/19 05:52 PM
WM Valvoline Full Syn Modern Eng Clearance
by Spartanfool. 03/22/19 04:22 PM
Need Moly basic training
by Bill_W. 03/22/19 04:03 PM
P0420 code goes away in warmer weather
by 2010Civic. 03/22/19 03:54 PM
Customer declined new belt
by Chris142. 03/22/19 03:13 PM
How to deep clean back of wheels?
by qdeezie. 03/22/19 02:51 PM
RK oil sale T4 15w40
by 1978elcamino. 03/22/19 01:57 PM
Zahndkile, duradick, Harold1031, Skendread, NGK
67590 Registered Users
44 registered members (4WD, billt460, BobFout, AurionX2, 97K15004WD, BlakeB, 6 invisible), 656 guests, and 55 spiders.
Topics286,268
Posts4,905,538
Members67,589
Most Online2,967
Mar 10th, 2019
lube for Eaton/Detroit Tru-Trac #4621608
01/02/18 11:50 AM
01/02/18 11:50 AM
Great Bend, KS
code5coupe Offline OP
Great Bend, KS
Summit, from whom I bought the unit, says use conventional gear lube. Why not full synthetic? Anyone had bad results using synthetic?
1996 Corvette LT4
2012 Grand Cherokee SRT
Re: lube for Eaton/Detroit Tru-Trac [Re: code5coupe] #4621640
01/02/18 12:17 PM
01/02/18 12:17 PM
Great Bend, KS
Great Bend, KS
Sorry, guys, I forgot I'd already posted this some time ago....
1996 Corvette LT4
Re: lube for Eaton/Detroit Tru-Trac [Re: code5coupe] #4621643
01/02/18 12:19 PM
01/02/18 12:19 PM
Charles City, Iowa
rideahorse Offline
rideahorse  Offline
Charles City, Iowa
bop Because aside from what all the coolade drinkers say. There are places that conventional oil is better than syn oils.
Re: lube for Eaton/Detroit Tru-Trac [Re: rideahorse] #4621656
01/02/18 12:25 PM
01/02/18 12:25 PM
Great Bend, KS
Great Bend, KS
We've established that. The question is "why"?
1996 Corvette LT4
Re: lube for Eaton/Detroit Tru-Trac [Re: code5coupe] #4621700
01/02/18 01:12 PM
01/02/18 01:12 PM
Charles City, Iowa
rideahorse Offline
rideahorse  Offline
Charles City, Iowa
Because conventional allows the true-track to function the way it was designed. Syn has too much drain off. It does not have the right friction properties for it to work right.
Re: lube for Eaton/Detroit Tru-Trac [Re: code5coupe] #4621865
01/02/18 04:05 PM
01/02/18 04:05 PM
The land of USA-made Subies!
SubieRubyRoo Offline
And where's your DATA to support that, rideahorse?
Use what the manufacturer recommends here... which is a good mineral oil, without friction modifiers.
Detroit Truetrac
Q: What kind of oil should I use? Can I use synthetic? Do I need friction additive/modifier?
A: A quality petroleum/mineral based oil works best in the Truetrac units. We do not recommend synthetic oil. Friction additive/modifier is not required.
Re: lube for Eaton/Detroit Tru-Trac [Re: code5coupe] #4621891
01/02/18 04:31 PM
01/02/18 04:31 PM
East Mountains, NM
4wheeldog Offline
4wheeldog  Offline
East Mountains, NM
Huh. I have had a Truetrac in my 4runner for about 100k miles.
I used conventional for breakin, and boy did it get hot!
After 50 miles or so, I put in Redline, (Which immediately ran much cooler) and that is what I have used ever since.
No mention at the time of installation that synthetic was not recommended.
It works great, but maybe it would work even better with mineral?
Who knew?
Re: lube for Eaton/Detroit Tru-Trac [Re: code5coupe] #4664540
02/13/18 08:39 AM
02/13/18 08:39 AM
Great Bend, KS
Great Bend, KS
The entire rear end depends on the diff lube; gears, limited-slip, wheel/axle bearings, pinion bearings. Do I use what's best for one component (LSD) at the expense of the rest of the components?
As I understand it, the synthetic lube does not hurt the Tru-Track, it just doesn't allow it to lock up as readily....which should, in theory anyway, make it last longer.
1996 Corvette LT4
Re: lube for Eaton/Detroit Tru-Trac [Re: code5coupe] #4664906
02/13/18 04:25 PM
02/13/18 04:25 PM
GA
JZiggy Offline
JZiggy  Offline
GA
I have a TrueTrac and I use the Redline NS gear oil. So it is synthetic but does not have the "limited slip" friction modifiers.
I guess if the oil is too "slippery" the torque bias of the unit is reduced.
In the past I have used various other oils with friction modifier and the unit still seemed to work properly. I don't think a friction modified oil would hurt the TrueTrac... I don't see how that could be possible.
Basic,, Simple,
Re: lube for Eaton/Detroit Tru-Trac [Re: code5coupe] #4669783
02/18/18 02:09 PM
02/18/18 02:09 PM
Indianapolis, In.
Darren_L Offline
Darren_L  Offline
Indianapolis, In.
I have been beating on my 12 bolt TrueTrac for 7 years running nothing but Red Line Heavy Shockproof gear lube with zero issues. Power is provided by a 700hp 496 with a Tremec 6 speed and with a set of sticky M/T DOT cheater slicks, it has easily handled all the abuse I've thrown at it. Differential runs cool, quiet, smooth and both rear tires have always locked when tires spin.
71 Chevelle 496BBC Brad Penn 10w30
04 Silverado Valvoline FS 5w30
96 Impala SS Valvoline FS 10w30
99 Civic MaxLife 5w30
96 Ranger MaxLife 5w30
Re: lube for Eaton/Detroit Tru-Trac [Re: code5coupe] #4670850
02/19/18 01:21 PM
02/19/18 01:21 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
There you go - Shock Proof IS #1 for keeping them alive laugh
