First Time Hyundai Owner - Coolant Confusion
by tony1679. 09/25/18 05:16 AM
European Formula: Supertech and Mobil 1
by Snagglefoot. 09/25/18 02:19 AM
KFE brake pads?
by deoxy4. 09/25/18 01:16 AM
GM Marine Engine wont start
by Gito. 09/24/18 11:59 PM
New TV bad picture some channels part2
by raaizin. 09/24/18 10:46 PM
Another Bad PCM on a Buick 3.8L!
by clinebarger. 09/24/18 10:17 PM
Funny pictures thread
by JLTD. 09/24/18 08:40 PM
Redline 15w40: Low or Mid Saps?
by SavagePatch. 09/24/18 06:59 PM
What are these cables to?
by 99Eclipse. 09/24/18 06:44 PM
Help with parasitic draw?
by buck91. 09/24/18 05:57 PM
Costco Car Buying Program
by dkryan. 09/24/18 05:39 PM
Glass Scrub?
by buck91. 09/24/18 05:03 PM
Loosing coolant from somewhere
by NICAT. 09/24/18 03:47 PM
2010 or so Ford Fusion Sport thoughts?
by ZZman. 09/24/18 03:35 PM
My boss killed his jeep.
by Chris142. 09/24/18 02:40 PM
Moly question about walmart oils
by jayjr1105. 09/24/18 02:33 PM
Questions About 9011 Bulbs
by knerml. 09/24/18 02:23 PM
fortim, albert001, LG_Electronics, TCam, OzFrog
66063 Registered Users
46 registered members (AndyB, 87sammy, Bailes1992, 77GrandPrix, 2015_PSD, 2013ecof150, 6 invisible), 811 guests, and 32 spiders.
Topics290,968
Posts4,853,530
Members66,063
Most Online3,590
Jan 24th, 2017
Oil recommendation for LS swapped Miata #4621572
01/02/18 11:16 AM
01/02/18 11:16 AM
FL
Ace_Protege Offline OP
FL
I have a 95 miata with an L33 LS based engine(5.3 from 2005 silverado, alum. block, 10.5 compression, mild camshaft, roller lifters, Stock rotating assembly with new bearings and pistons/rings) Obviously the car is a weekend car and sees <5000 Miles per year, but it does see drag racing and other hard driving. The tune is a bit on the rich side so it likely has some contamination, this will be the second oil change after break in. I will be sending a sample in to Blackstone for analysis from this drain. For break in I used SAE30 with a break in additive for 100 miles, then I used the bulk oil we have at our shop (amalie 5w-40 elixir) for 2500 miles, both times I used an OE ACDelco filter.
I live in Central Florida where the climate is pretty hot. I'd like to use a high quality oil to offer the most protection possible, within reason of course.
Thanks in advance for all your suggestions.
Re: Oil recommendation for LS swapped Miata [Re: Ace_Protege] #4621594
01/02/18 11:40 AM
01/02/18 11:40 AM
North Carolina
rooflessVW Online content
rooflessVW  Online Content
North Carolina
Mobil 1 0W-40 should serve you well.
"Zed's dead baby, Zed's dead."
Re: Oil recommendation for LS swapped Miata [Re: Ace_Protege] #4621619
01/02/18 12:00 PM
01/02/18 12:00 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I see you are in Florida.
All I have ever run in my drag cars is 15W-40 (Rotella, Delo, Delvac etc)
That's a VERY tough engine that doesn't need any type of "boutique" oil.
Re: Oil recommendation for LS swapped Miata [Re: Ace_Protege] #4621698
01/02/18 01:09 PM
01/02/18 01:09 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
+1 laugh
Re: Oil recommendation for LS swapped Miata [Re: Ace_Protege] #4621706
01/02/18 01:19 PM
01/02/18 01:19 PM
Jupiter, Florida
Cujet Offline
Cujet  Offline
Jupiter, Florida
A synthetic 10W-30 or 5W-40 is a good choice for a mild engine in Florida. 15W-50 synthetic is the right choice for track days.
Re: Oil recommendation for LS swapped Miata [Re: Ace_Protege] #4621799
01/02/18 02:49 PM
01/02/18 02:49 PM
Vienna, VA
TinyVoices Offline
TinyVoices  Offline
Vienna, VA
Most of my LS buddies turbo or NA run an hdeo 5w40
1993 Toyota MR2 Hardtop N/A - 160k miles - Valvoline Max Life 5w30
2006 Toyota Matrix XR AWD (Fiancee) - 130k miles - Valvoline Max Life 5w30
Re: Oil recommendation for LS swapped Miata [Re: Ace_Protege] #4622098
01/02/18 08:04 PM
01/02/18 08:04 PM
Georgia
Charlie2015 Offline
Charlie2015  Offline
Georgia
Castrol GTX 20w50
1998 Honda Accord EX 2.3L Auto
2009 Scion TC Manual
Re: Oil recommendation for LS swapped Miata [Re: Ace_Protege] #4622125
01/02/18 08:27 PM
01/02/18 08:27 PM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
M1 0w-40. It's what GM uses in their race program Corvettes IIRC.
2018 RAM 1500 Big Horn EcoDiesel
2016 Grand Cherokee SRT
Re: Oil recommendation for LS swapped Miata [Re: rooflessVW] #4622188
01/02/18 09:27 PM
01/02/18 09:27 PM
New England
jdavis Offline
jdavis  Offline
New England
end of thread
Re: Oil recommendation for LS swapped Miata [Re: OVERKILL] #4622206
01/02/18 09:48 PM
01/02/18 09:48 PM
Chicago, IL
dparm Offline
dparm  Offline
Chicago, IL
Never heard that before, but GM is switching over to a new M1 0w40 variant as the FF/service fill for Corvettes starting in 2019 MY. Details are still a bit hazy.
2017 Chevrolet Corvette Grand Sport
Re: Oil recommendation for LS swapped Miata [Re: dparm] #4622239
01/02/18 10:25 PM
01/02/18 10:25 PM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
In trying to find it, I discovered that it is the recommended service fill for the Z06 when sold in Europe as per this thread.
Re: Oil recommendation for LS swapped Miata [Re: Ace_Protege] #4622258
01/02/18 10:37 PM
01/02/18 10:37 PM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
Also, somewhat amusing, Mobil 1 5w-30, 0w-40 and 15w-50 show up on the Mobil 1 Racing product website. M1 0w-40 carries the following description:
Quote:
Used as factory fill in many production road car models and continues to win in the IMSA WeatherTech SportsCar Championship and multiple Porsche Customer Racing series.
Porsche Customer Racing series doesn't sound overly spectacular, however the former includes two Corvette Race teams and two Porsche GT teams.
The Corvette teams have some pretty good records in the 12 and 24hr races. They are presently in 1st place in GT Le Mans.
Re: Oil recommendation for LS swapped Miata [Re: Ace_Protege] #4622420
01/03/18 06:04 AM
01/03/18 06:04 AM
South OZ
KL31 Offline
KL31  Offline
South OZ
If you're in warm weather 15W40 would never be an issue either so up to you really. But on a more serious note, how fast would that thing be? Vids? grin
95 MX-3 2.5L|Shell Helix Ultra 5W40|Wix 51356
04 Focus 1.8L|Wesfil Cooper WZ63|Valvoline MST 5W30
05 Kluger 3.3L|Wesfil Cooper WZ418|Magnatec 10W30 Semi Syn
