Tire leak with new wheels. What would YOU do?
by Lolvoguy. 04/25/19 04:20 PM
Red battery light came on, Ford E150.
by laserred96gt. 04/25/19 03:34 PM
2019 NFL Draft
by JustN89. 04/25/19 03:10 PM
Crabgrass!!!!
by gregk24. 04/25/19 03:06 PM
Drain and fill 08 Kia Rio.
by Jetsfan421. 04/25/19 02:59 PM
Cut Open - Mazda OEM @ 7,000kms
by mcwilly. 04/25/19 02:50 PM
Fender bender...headache!
by gregk24. 04/25/19 02:44 PM
Cerwin Vega 10" Subwoofers - $14.37 Each
by Greg L. 04/25/19 01:53 PM
Blain's Farm & Fleet synthetic oil $2.19/qt.
by BrewCityR. 04/25/19 01:24 PM
F1 - 2019 Azerbaijan Grand Prix
by gofast182. 04/25/19 12:00 PM
Installing an additional fuel filter?
by Ed_Flecko. 04/25/19 11:46 AM
Honda self propel only spining left wheel
by Tundragod. 04/25/19 11:38 AM
Cabin Filter Pics (15k miles)
by DoubleWasp. 04/25/19 11:30 AM
LiquiMoly Jectron Fuel Injection Cleaner
by Ddub. 04/25/19 11:12 AM
servicing a 2018 GM 6speed transmission
by gotnogunk. 04/25/19 10:23 AM
Went 100% debt free today
by BeerCan. 04/25/19 10:04 AM
1st Oil Change.....Break In Oil?
by Whalstib. 04/25/19 09:51 AM
Thoughts on 2005 Pilot
by maverickfhs. 04/25/19 09:41 AM
Nissan Matic-S alternatives
by Shakenbake. 04/25/19 09:29 AM
Wood9913, Lydia, jdar805866, PreludeDenarius, Ayodejidj
67902 Registered Users
101 registered members (2009Edge, 01rangerxl, 28oz, 14Accent, 1978elcamino, 11 invisible), 2,308 guests, and 23 spiders.
Topics288,042
Posts4,939,779
Members67,902
Most Online2,967
Mar 10th, 2019
Formula Shell conventional #4621484
01/02/18 10:14 AM
01/02/18 10:14 AM
MA.
Camprunner Offline OP
MA.
Just a comment about Formula Shell conventional and cold starting. I run FS in several service cars here in Western Massachusetts and it's been below zero for about a week now and I find no starting issues running there 5w30 and 5w20 oils. It seems to start just fine even at -10F in several car makes. I usually get it on sale at HD in 5 quart cantainers and I have run several cars on this oil for several hundred thousand miles without issue.
Re: FS conventional [Re: Camprunner] #4621486
01/02/18 10:16 AM
01/02/18 10:16 AM
WI
HoosierJeeper Offline
WI
I'm running it in my '15 Cherokee in 5W20 and it seems a little less ticky when I first start it in the cold. Got 12 qts of it at Menards for like $15 this summer.
15 Jeep KL Limited V6: Formula Shell 5W20
07 LR3 SE V8: Maxlife 5W30
05 Jeep KJ Limited: PHM 5W30
96 Jeep XJ Country: STP HM 5W30 (winter)
Re: FS conventional [Re: Camprunner] #4621499
01/02/18 10:25 AM
01/02/18 10:25 AM
New England
Virtus_Probi Offline
New England
5W20 and 5W30 conventional oils have to pass the same -30C CCS and -35C MRV tests that synthetics of those grades do.
Given that -10F is only -23C, you're a long way from those test points and the oil is probably more than twice as thin at that temp than at -30C.
The only difference is that many 5WXX synths will beat the test limits by wide margins while the conventionals tend to bunch up closer to the upper viscosity limits...I do like to pick 5W30s that do especially well in the cold tests, although anything that is good enough to pass 0W30 tests at -35C CCS/-40C MRV must be labelled as a 0W30. Might run a 0W30 next winter when I can find some d1G2 examples of that grade and it is worth noting that there are no conventional 0W30s!! (not sure about 0W20)
2014 Forester XT, 100000 miles
Last Change;
M1 10W30 HM SN+
Tokyo Roki 15208AA170 filter
Re: FS conventional [Re: Camprunner] #4621547
01/02/18 11:02 AM
01/02/18 11:02 AM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
Yep, if it meets 5W, it's a 5W regardless of anything else.
1994 BMW 530i, 241K
1996 Honda Accord, 267K
1999 Toyota Sienna, 410K
2000 Toyota ECHO, 280K
Re: FS conventional [Re: Camprunner] #4621699
01/02/18 01:11 PM
01/02/18 01:11 PM
Toronto Canada
WobblyElvis Offline
WobblyElvis  Offline
Toronto Canada
Formula Shell 5W30 passes the -30 ccs specs by a wide margin. Upper limit is 6600 where as FS measures 4300. Good oil.
Re: FS conventional [Re: WobblyElvis] #4621722
01/02/18 01:32 PM
01/02/18 01:32 PM
New England
New England
I think you're referencing the synthetic version here, the test results are a bit old but the PQIA had the synth 5W30 around 4000 cP for CCS at -30C with the conventional a bit above 6100 cP. Confusing to look up on their site as some oils are under Formula Shell and others are under Shell Formula.
Last Change;
M1 10W30 HM SN+
Re: FS conventional [Re: Camprunner] #4621749
01/02/18 01:55 PM
01/02/18 01:55 PM
Toronto Canada
WobblyElvis Offline
WobblyElvis  Offline
Toronto Canada
This is the information I am using. Says Conventional. My wife says I've been wrong before.
http://oilmart.com/data/products/pds/385/PDS%20FormulaShell%20Engine%20Oils.pdf
Re: FS conventional [Re: Virtus_Probi] #4621751
01/02/18 01:58 PM
01/02/18 01:58 PM
Champlain/Hudson Valley
Kira Offline
Kira  Offline
I bought 6 cases of Formula Shell 10W-30 on clearance.
It saw:
my sister's '99 Jeep (XJ)
an '89 K1500 (SBC)
a '97 F-150
2 lawn tractors
an old Saab
other applications
Every engine loved it. It made Sis' Jeep quieter....did the same for the gardening tools.
Re: FS conventional [Re: WobblyElvis] #4621773
01/02/18 02:22 PM
01/02/18 02:22 PM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
That PDS is from 2010....
Current PDS is from 2015 and can be found here:
http://www.shell-livedocs.com/data/published/en-US/89daf838-4f18-4d02-9967-02436a4731fc.pdf
It lists CCS at 6,110cP.
2016 Grand Cherokee SRT - Ravenol SSL 0w-40, FRAM Ultra
