Ford 4.6L Durability?
by Auae85
Yesterday at 11:00 PM
Mercedes Benz High Mileage Badges
by Snagglefoot
Yesterday at 10:46 PM
Lawn Tractor Tire Sealer
by 97K15004WD
Yesterday at 10:01 PM
Fireworks Stores
by Warstud
Yesterday at 09:36 PM
1994 Ranger fuel tank/frame cleanup & NOS part
by 01rangerxl
Yesterday at 09:27 PM
Koreans top J.D. Power qlty; Ford, GM, FCA make strides
by wemay
Yesterday at 09:18 PM
How Fast to Run a ZeroTurn Mower
by Gebo
Yesterday at 09:10 PM
Bosch 3300 C&P Yamaha FZ-07
by bmwpowere36m3
Yesterday at 08:49 PM
My FIL in hospice
by fdcg27
Yesterday at 08:41 PM
Spraying Polyurethane
by Texican
Yesterday at 08:37 PM
Dehumidifier icing
by Kestas
Diesel lube in Petrol Engine
by Ducked
Yesterday at 07:46 PM
New key programming cost
by 92saturnsl2
Yesterday at 07:27 PM
When you help someone and its time to walk away
by RazorsEdge
Yesterday at 07:09 PM
Sightly overfilled oil..ok or drain?
by flinter
Yesterday at 07:08 PM
Wheel says 50 mph max
by pda1122
Yesterday at 06:54 PM
15w40 Maxlife in Motorcycle
by Brian553
Yesterday at 06:39 PM
BITOGer in Ottawa/Orleans Canada area ? ...
by Papa Bear
Yesterday at 06:36 PM
Old Engine SOUND
by MasterSolenoid
Yesterday at 06:06 PM
ProMotive PH 2500 CUT OPEN
by car51
Yesterday at 04:54 PM
yamahaboy125, Turboholic, TrpNY, bcj, Ilia
65282 Registered Users
26 registered (citationxeleven, Char Baby, clinebarger, Black, bbhero, ctechbob, 3 invisible), 888 Guests and 32 Spiders online.
65282 Members
67 Forums
285683 Topics
#4621247 - 01/01/18 11:05 PM high pressure fuel pump on GDI
joel95ex Offline
Loc: texas
anyone change one of these on a hyundai or kia? i got a code p0087 low fuel system/rail pressure. the car idles fine but when under load/acceleration it stumbles. everything i read indicates it is this pump. i don't trust the local dealership and my mechanic who i use for things i won't do like a head gasket --and always does a good job, says they haven't had to change one before. that doesn't make me feel very good. thinking about doing it myself and was wondering if anyone has changed one--- i've changed regular fuel pumps before but not one of these--cam driven on the head--new to me
95 Accord 4cyl Vtec. 500,000+miles. RIP 😢
2013 sonata 117k miles
PP, QSUD,10w-30 fram ultra filter
07 civic SI 132k miles PP, M1 10w-30 fram ultra
#4621253 - 01/01/18 11:19 PM Re: high pressure fuel pump on GDI [Re: joel95ex]
Silk Online   content
Loc: New Zealand
Most common problem with the old Mitsubishi GDI was the fuel filter blocking at the pump. These are just a small filter same as used in an injector. I don't know if they carried that sort of technology over to Hyundai, but it'd be the first place I'd look before pulling a pump.
1987 BMW R65 - Penrite V Twin 20/50
2005 Nissan Expert - Gulf Western 10W-40
1996 Volvo T5 - Penrite HPR15 - 15W-60. Ryco syntec filter.
#4621261 - 01/01/18 11:26 PM Re: high pressure fuel pump on GDI [Re: joel95ex]
gabriel9766 Offline
Loc: Missouri
Alldata calls for .5hr to do the job. Sits right on top the motor.
2015 Chevy Malibu 1LT DI 2.5L I4- PPPP 0w20 and a napa gold 7060 39,829K
2007 Ford Escape XLT FWD 3.0 V6 motorcraft 5w30 bulk and a motorcraft FL500s 109,944K
#4621275 - 01/02/18 12:08 AM Re: high pressure fuel pump on GDI [Re: joel95ex]
MuzzleFlash40 Offline
Loc: SE Ohio
On the 2.4 it is right under the plastic engine cover on the back side of the engine toward the firewall.
18 Sonata SEL 2.4-6k
HK Syn 5w30 & OEM
16 Santa Fe Sport AWD 2.4-60k
Cam2 SynBlend 5w30 & OEM
09 Silverado LT 4x4 4.8-100k
Castrol GTX HM 5w30 & Fram
#4621288 - 01/02/18 01:05 AM Re: high pressure fuel pump on GDI [Re: joel95ex]
14Accent Offline
Loc: MN
Looks pretty easy reading the service manual. I wouldn't be afraid to tackle the job, I'm sure your mechanic can handle it.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
#4621359 - 01/02/18 06:29 AM Re: high pressure fuel pump on GDI [Re: joel95ex]
SteveSRT8 Offline
Loc: Sunny Florida
C'mon, fuel pumps were mechanical and ran off the cam in cars for decades before GDI.
It's a simple swap, looks downright easy...
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
#4622126 - 01/02/18 07:31 PM Re: high pressure fuel pump on GDI [Re: joel95ex]
dblshock Offline
Loc: WI.
lube the fuel with TCW-3 for a week, then decide.
16 Civic Coupe Touring
640:1 TCW-3 E091
Edge 0/40/XG7317
Firehawk Indy 500
06 4Runner SR5 135k
640:1 TCW-3
M1 0/40 XG3614
Falken Wildpeak AT3W
#4623031 - 01/03/18 06:26 PM Re: high pressure fuel pump on GDI [Re: joel95ex]
Thax Offline
Loc: VA
It is a pretty simple job. The high pressure fuel pump normally put out 500-650psi at idle and 1300-1800psi under load. P0087 and your symptoms match a failed GDI fuel pump. To replace its easy , relieve the fuel pressure by pulling pump relay, undo 19mm barrel nut on fuel pump. Lastly two 10mm bolts hold the pump in place , evenly remove these . Installation is pretty much the reversal , just make sure to tighten down the 10mm bolts holding the pump to the head evenly.
97 Grand Prix GTP
11 Jetta 2.5 SE
ASE P2 Parts Specialist
AIA Import Part Specialist
KIA certified Senior Technician, Hybrid certified.
