Stick with WSS-M2C946-A?
by BlueFog. 12/14/18 01:42 PM
How engine capacity affects fuel consumption?
by NICAT. 12/14/18 01:12 PM
Pep Boys
by Zee09. 12/14/18 12:41 PM
How early in engines life can I start to extend OCI
by Doublehaul. 12/14/18 12:33 PM
EFB and AGM batteries charge faster?
by slybunda. 12/14/18 11:20 AM
97.5 Regal GS climate control illumination
by 71Chevyguy. 12/14/18 11:04 AM
Cool train site for Canadians
by Papa Bear. 12/14/18 10:09 AM
Putting together a groups 3/4/5 synthetic list
by MrWideTires. 12/14/18 10:02 AM
VW Atlas V6 Oil
by motech. 12/14/18 09:32 AM
Great shakes, it's Yahtzee... or a Taurus
by redhat. 12/14/18 09:03 AM
MWI Micro Wave Ignition
by Danno. 12/14/18 08:52 AM
8k Miles on M1 EP 2017 Subaru 3.6
by BISCUT. 12/14/18 08:47 AM
Wrong ATF Fluid in my 07 Chevy Impala
by CM613. 12/14/18 08:39 AM
Hyundai motor oil
by pbm. 12/14/18 08:16 AM
Which Exhaust Manifold Should I Buy
by Miller88. 12/14/18 08:10 AM
Rotella T5 10w30 Ford 6.7L anyone?
by sw99. 12/14/18 07:49 AM
Advice on spark plugs for 90,000 mile Accord
by Chris B.. 12/13/18 11:24 PM
Elec star kit for predator engine...
by SmokeyBear. 12/13/18 11:07 PM
Mecredes Bosch vs Ngk sparks plug
by Rohan. 12/13/18 09:48 PM
jcr1293, maxwellk, BlueFog, Frank_G35, captobvious
66681 Registered Users
93 registered members (Anduril, 71Chevyguy, 4WD, andyd, 2004tdigls, 15 invisible), 1,883 guests, and 41 spiders.
Topics295,064
Posts4,927,131
Members66,681
Most Online2,553
Oct 27th, 2018
New Rear Sway #4621213
01/01/18 09:44 PM
01/01/18 09:44 PM
Canton, Ohio
Throt Offline OP
Throt  Offline OP
Canton, Ohio
Got a new rear sway bar on order for my Sonata, am I going to need to have this thing aligned afterwards? And do you think I can change these out without jacking the car up? I can back it up on ramps but I currently donít have a jack.
https://www.progressauto.com/products/sfID1/12/sfID2/37/sfID3/165/productID/808
'18 Honda Accord Touring, 1.5T, Factory Fill/Filter
'17 Elantra, 2.0L, 22,500, QS Ult. 0w20 w/ FU, hers (lease)
Re: New Rear Sway [Re: Throt] #4621219
01/01/18 09:51 PM
01/01/18 09:51 PM
Northern Ontario, Canada
Danno Offline
Danno  Offline
No need for an alignment and ramps should be fine. Your end links may give you trouble in getting them off, be prepared to buy new links.
I assume you are going stiffer? What handling change are you going after?
Good suspension pictures here.
https://www.edmunds.com/car-reviews/track-tests/2011-hyundai-sonata-gls-suspension-walkaround.html
2016 Sorento SX V6 AWD
2015 KIA RIO SX
2010 Mazda 3 2.0L
2009 Venza V6 AWD
2013 Sonata 2.4L RIP in write-off crash
Re: New Rear Sway [Re: Throt] #4621240
01/01/18 10:26 PM
01/01/18 10:26 PM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
No alignment needed, use the jack in the trunk and slide the tires under the car for safety. Might be able to lower the car's pinch weld onto a ramp to use as a jack stand.
2015 Hyundai Sonata 2.4L 88k Motorcraft Synthetic Blend 5w30 & OEM
2000 Toyota Camry 2.2L 231k Valvoline 5w30 & Fram Ultra
1996 Jeep Cherokee 4.0L 147k Mobil 1 HM 10w40 & Fram Ultra
Re: New Rear Sway [Re: Throt] #4621254
01/01/18 11:20 PM
01/01/18 11:20 PM
Toronto
dgunay Offline
dgunay  Offline
Toronto
You can change it without jacking it up.
Progress customer service sucks. Their sway bar bushings are [censored], one of the bushings was shot less than 1 month / 2k miles. They give me [censored] excuses not to send a replacement. They claimed/guessed that I had an aftermarket exhaust (which they were wrong), and they blamed me for not using a "heat shield" for a friggin rear sway bar. I sent my OE exhaust pics, eventually they admit it's their fault and sent me the replacement. They tried so hard not to accept their fault for selling a defective bushing which costs less than $10. I can't imagine if it was an expensive part, I would have been on my own.
I'd get another aftermarket sway bar, or get some energy suspension universal bushings and keep them as a spare set.
2009 Acura CSX - PUP 0w20 / Fram XG7317 / Maxlife ATF
2018 Kawasaki Z650 - Motul 4T 5100 10w40 / OEM Oil Filter
Re: New Rear Sway [Re: Throt] #4621340
01/02/18 05:42 AM
01/02/18 05:42 AM
PV Az
AZjeff Offline
AZjeff  Offline
PV Az
Curious for the need to put a new larger anti-sway bar on a '17 Hyundai?
86 Samurai 1.3 leftovers
14 RAV4 2.5 5W-20 PP
16 Silverado 1500 4.3, DI, AFM 5W-30 PP
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: New Rear Sway [Re: AZjeff] #4621358
01/02/18 06:28 AM
01/02/18 06:28 AM
Sunny Florida
SteveSRT8 Online content
SteveSRT8  Online Content
Sunny Florida
Likewise. I have only met a couple of qualified folks who tune suspensions at the track, never seen anyone do much in a driveway except change their handling. For better or worse?
Pretty hard to beat the factory at that game for overall safe handling without risks.
And I also note that my sig car has elaborate little shields over the sway bar bushings. If any are within a few inches of exhaust components they may be a good idea...
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
Re: New Rear Sway [Re: Throt] #4621374
01/02/18 06:59 AM
01/02/18 06:59 AM
Pennsylvania
bugeye Offline
bugeye  Offline
Pennsylvania
A larger sway bar will reduce body roll during turning. I have changed a few cars rear bars for improved handling, reduced understeer. Poly bushings are available from energy suspensions for a "tighter" feel
Re: New Rear Sway [Re: bugeye] #4621441
01/02/18 08:32 AM
01/02/18 08:32 AM
PV Az
AZjeff Offline
AZjeff  Offline
PV Az
Thanks, I'm well aware of what a stiffer rear A/S bar does. Still not sure the need of a new bar on a '17 Hyundai in day to day driving. Is the OP going to track days? A Sonata isn't really know as a car for spirited driving. Just curious what the OP's needs are.
Re: New Rear Sway [Re: SteveSRT8] #4621442
01/02/18 08:33 AM
01/02/18 08:33 AM
Ontario, Canada
IndyIan Offline
IndyIan  Offline
Ontario, Canada
I would sure start on the soft setting atleast. Seems 17mm is stock and jumping to 22mm seems a bit excessive with no other changes, but do some reading on a sonata forum and see what other guys have found that works.
Adding a rear sway bar will reduce understeer, but not do all that much for reducing body roll overall(a front bar will help that), but if you just want to have more fun autocrossing a fwd car, a rear sway is a good way to get the option to rotate the car more. Just respect that the car is not idiot proof anymore and jerky steering inputs at high speeds may be more exciting than you want!
07 Focus ZXW, 5spd manual, 218km M1 5W30
18 Outback 2.5 CVT 15km 0W20
Re: New Rear Sway [Re: Throt] #4621546
01/02/18 10:02 AM
01/02/18 10:02 AM
Canton, Ohio
Throt Offline OP
Throt  Offline OP
Canton, Ohio
Goal is merely to reduce the body roll to any degree possible, even if marginal. New rear sway was really the only way without changing out the springs. Definitely may add a strut tower brace at some point or a lower body brace. If I were to change the front sway Iíd probably just order the factory one off of the sport trim. I got the Progress because I like itís ability to be adjusted, but for sure will start on the soft setting. Thatíll probably be enough for what Iím wanting.
Glad to know that I can change this out without a jack. Besides, if I end up not liking it I can always put the OEM one back. This isnít a huge permanent difficult change.
Re: New Rear Sway [Re: AZjeff] #4621553
01/02/18 10:05 AM
01/02/18 10:05 AM
Canton, Ohio
Throt Offline OP
Throt  Offline OP
Canton, Ohio
Yea itís for sure not a spirited driving car but itís the car I bought and I want it to handle a little better is all.
Re: New Rear Sway [Re: Throt] #4621565
01/02/18 10:12 AM
01/02/18 10:12 AM
Canton, Ohio
Throt Offline OP
Throt  Offline OP
Canton, Ohio
Now you guys have me thinking I shouldíve just ordered the Sport trim front sway and skipped the rear sway. Well too late now, it already shipped and I donít think I wanna pay return shipping on it.
Tried to find the specs on the Sport trim sway bar and I can't find it anywhere. So I'm not sure they are in fact larger, but they'd almost certainly have to be with being a Sport model, right? A front sway from the Sport would be $100 vs the $170 I spent on the rear sway. Hmmmmm.....
Re: New Rear Sway [Re: Throt] #4621649
01/02/18 11:21 AM
01/02/18 11:21 AM
Ontario, Canada
IndyIan Offline
IndyIan  Offline
Ontario, Canada
Front sways can require a few things to be removed to change out. Can you find out the spring rates for the sport trim struts? IF they are stiffer than yours, maybe find some front struts at the wreckers to swap in?
Anyways, if you've ordered the rear sway, try it out and if it makes the back end too loose, put the stock one back in and sell the sway bar for a cheap lesson learned.
Re: New Rear Sway [Re: Throt] #4621677
01/02/18 11:50 AM
01/02/18 11:50 AM
Central Virginia
Silverado12 Offline
Silverado12  Offline
Central Virginia
Just remember to have the wheels the same height off the ground if you're jacking up the car. Don't just jack up one side or you'll never get the sway bar installed.
12 Chevy Silverado ext. cab LS, 2WD 4.3 auto
18 Mustang GT 5.0 auto
07 Harley Dyna Street Bob 96 c.i. 6 sp.
00 Mustang GT auto
Re: New Rear Sway [Re: Throt] #4621680
01/02/18 11:53 AM
01/02/18 11:53 AM
Toronto
dgunay Offline
dgunay  Offline
Toronto
Do not skip rear sway bar.
I used Progress 22 mm rear sway bar in my Civic SI, and OE sway bar is 17 mm. So I guess it's very similar with your situation. Let me tell you, it makes a night and day difference.
You need to get rear sway bar first if it's a FWD, rear end must be stiffer than the front. It will reduce understeering, as the other guys mentioned. Don't worry, rear sway bar will reduce body roll as well.
You wouldn't want to reduce roll in the front with aftermarket sway bar. Front wheels need to stay on ground when cornering, especially if you don't have a limited slip. So that's why aftermarket FSB is not the best option if you are looking for best grip. Even some FWD track cars have thinner / no front sway bar to get better traction. You should get a thicker FSB (with thicker RSB, of course) on FWD car only if you do autocrossing, as it would increase initial turn in feedback and steering response.
If you buy FSB and skip the rear, you feel like there is less body roll, but you will have less grip on the front and will have to deal with more understeering.
Check if you have any OE alternatives for rear. I currently have 2015+ Honda Civic SI 20 mm rear sway bar on my Acura (OE RSB diameter is 11 mm). The reason why I went with OEM is $$$$$. I bought it for $50 at the dealer, whereas the Progress is 200$+ Canadian.
