Gift for young Army Cadet
by Snagglefoot. 12/16/18 12:33 AM
Instacart Grocery Delivery
by dogememe. 12/16/18 12:26 AM
My brother bought this...
by miden851. 12/15/18 09:12 PM
Watch out for scammers
by Chris142. 12/15/18 08:45 PM
15K OCI R53 2006 Mini Cooper S 144k
by dx92beater. 12/15/18 08:32 PM
Beneficial clean fuel.injectors in Ultrasonic Cleaner
by JLawrence08648. 12/15/18 06:54 PM
Back to Basics III
by MolaKule. 12/15/18 05:30 PM
Castrol Edge 0W40 vs. 5W40...Liqui Moly?
by TiGeo. 12/15/18 04:56 PM
Schumacher XCS15 voltage
by sweezy722. 12/15/18 04:19 PM
Solar battery tenders?
by slybunda. 12/15/18 04:10 PM
Bad Fuel Pressure Regulator.
by NICAT. 12/15/18 04:07 PM
Misfire = clogged cat
by Eric Smith. 12/15/18 04:00 PM
Cellphone Reliability
by Warstud. 12/15/18 03:29 PM
No email notification of replies anymore?
by atikovi. 12/15/18 03:07 PM
MikeMTL, AJ11, bandito, Spkrdctr, torchredone12
66691 Registered Users
11 registered members (citationxeleven, dogememe, Loi, FordCapriDriver, Kibitoshin, 1 invisible), 896 guests, and 44 spiders.
Topics295,135
Posts4,928,354
Members66,691
Most Online2,553
Oct 27th, 2018
5k mi. OCI - 6 moths or a year? #4621116
01/01/18 08:08 PM
01/01/18 08:08 PM
Idaho
RonRonnster Offline OP
Idaho
Is mileage more important than time, or should I worry about oil degrading sitting in the oil pan? Vehicle in question is a '98 Chevy pickup 5.7L Vortec. Barely put 5k on it a year, and I usually change it with a non-extended drain synthetic, such as Amsoil OE, Mobil1 or Valvoline Synpower. Seems like a waste to drain it with barely over 2k miles each 6 months, but that's what I've been doing. Any harm in pushing this out a year and running the full 5k miles?
- 2007 GMC Yukon XL Denali - 6.2L / 81k mi.
- 1998 Chev K1500 4x4 - 5.7L / 155k mi.
Re: 5k mi. OCI - 6 moths or a year? [Re: RonRonnster] #4621119
01/01/18 08:10 PM
01/01/18 08:10 PM
Ca.
UncleDave Offline
UncleDave  Offline
Ca.
Id leave it in.
As long as you get it hot enough to burn off the moisture when you do run it - sump time is almost meaningless next to run time.
UD
Uncle Dave
Cat 3126/2 MB3500/Titan/RX400H/17 Ridgeline
700HP V10/ 725HP BBC/ Raptor 700/ KFX450/ YZ250/Onan 8K/ Cat3011C
Re: 5k mi. OCI - 6 moths or a year? [Re: RonRonnster] #4621131
01/01/18 08:23 PM
01/01/18 08:23 PM
Lyndhurst NJ
Audios Offline
Audios  Offline
Lyndhurst NJ
5k or one year sounds totally acceptable for something like this.
2002 VW Golf TDI-Mobil 1 5/40 TDT
2007 Mercedes GL320 CDI Fuchs 5/40 GT Pro XTL
2005 BMW M3 BMW Twin Power 10/60
2003 BMW M5-Fuchs 5/40
1998 BMW M3/4/5 Fuchs 5/40
Re: 5k mi. OCI - 6 moths or a year? [Re: Audios] #4621139
01/01/18 08:33 PM
01/01/18 08:33 PM
NY
demarpaint Offline
demarpaint  Offline
NY
That works for me in two of my applications. With a UOA you might even be able to extend it beyond a year.
God Bless Our Troops
Re: 5k mi. OCI - 6 moths or a year? [Re: RonRonnster] #4621146
01/01/18 08:39 PM
01/01/18 08:39 PM
Outer Banks, NC
NormanBuntz Offline
NormanBuntz  Offline
Outer Banks, NC
Are you also changing the Mobil 1 oil filters every 2,000 to 3,000 miles? If so, stretch it out, man. They're designed for much longer mileage.
2017 Honda Odyssey SE, 17K
2013 Honda Accord LX, 58K
2007 Honda Ridgeline RTS, 89K
2007 Infiniti M35, 107K
Re: 5k mi. OCI - 6 moths or a year? [Re: RonRonnster] #4621184
01/01/18 09:10 PM
01/01/18 09:10 PM
New Jersey
JHZR2 Offline
JHZR2  Offline
New Jersey
I do one year OCIs in my low use pickup. They work great. Just make sure to not short trip the truck if you can at all avoid it.... or at least try to get a longer drive on it before putting it away for a while.
Re: 5k mi. OCI - 6 moths or a year? [Re: RonRonnster] #4621278
01/02/18 12:16 AM
01/02/18 12:16 AM
Pocatello, Idaho
compratio10_5 Offline
Pocatello, Idaho
The most important life factor is operating time at low temperature for both oil and filter. In the winter, you need about 15 minutes driving at moderate load to get the oil up to operating temperature if the thermostat is working properly. It is preferable to operate for a minimum of 30 continuous minutes at least once a month if you are only driving it occasionally to allow the oil enough time at a high enough temperature to evaporate the condensed water, acids and fuel. If you can do this and use an upgraded filter that contains synthetic enhanced cellulose filter media (like Wix, Napa Gold or Fram Toughguard for example), then yearly changes are acceptable but watch that dipstick for any signs of moisture. If you cannot do this, better stick with the 6 month intervals. I don't think that synthetic oil helps extend the oil drain interval if it must be dumped because of contamination. As a fellow Idahoan, one more bit of advice, "Never put your horse away hot and never put your car away cold".
It's not what you don't know that hurts, it's what you think you know that ain't so. Will Rogers
Re: 5k mi. OCI - 6 moths or a year? [Re: RonRonnster] #4621279
01/02/18 12:20 AM
01/02/18 12:20 AM
Texas (south)
FermeLaPorte Offline
Texas (south)
It is whatever is first--it's not a buffet that you can just choose.
Always Mobil 1
2014 1.6L Nissan Versa Sedan, 5 spd, 5k OCI.
2011 3.5L Chevrolet Impala, Automatic, 5k OCI.
Re: 5k mi. OCI - 6 moths or a year? [Re: UncleDave] #4621295
01/02/18 01:14 AM
01/02/18 01:14 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
100% correct.
Tons of excellent/amazing UOA's of oil that's been in the engine for multiple years (if you search it out).
Time in service = very little significance
Re: 5k mi. OCI - 6 moths or a year? [Re: RonRonnster] #4621311
01/02/18 03:11 AM
01/02/18 03:11 AM
Down Under
SR5 Offline
SR5  Offline
Down Under
I would do 5k miles or 1 year, whichever comes first.
If you haven't done the distance at 6 months, then keep the oil in the sump and keep going. As long as the car gets properly warm every so often.
Castrol GTX Ultraclean 15W40 A3/B3 + Wesfil-Cooper Z154
Re: 5k mi. OCI - 6 moths or a year? [Re: RonRonnster] #4621409
01/02/18 07:54 AM
01/02/18 07:54 AM
New England
NibbanaBanana Offline
New England
I put about 1000-1500 miles a year on my 1993 E350 that I built into a camper. Use M1 10w-30 and change at 5000 mile OCI's which is about every 4-5 years. No problems so far. My guess is that the motor is not going to be what kills this truck. I do recommend an OEM oil filter.
1993 Ford E350 5.8L, 68K
2002 Ford E150 4.2L, 85K
2006 Chevy Aveo 1.6L 215K
2013 Kia Reo 1.4L, 101K
7500 OCI, M1 5-30 winter, M1 10-30 summer
Re: 5k mi. OCI - 6 moths or a year? [Re: RonRonnster] #4622066
01/02/18 06:30 PM
01/02/18 06:30 PM
Idaho
Idaho
So far it seems the overwhelming consensus is to run out the full OCI even it extends to a full year. I've been leaning towards this for a while - it just seemed like a waste to dump the oil with such little use. Wanted to get some opinions first, just so I could over think it some more! lol.
Re: 5k mi. OCI - 6 moths or a year? [Re: RonRonnster] #4626362
01/06/18 08:18 PM
01/06/18 08:18 PM
South Dakota
otis24 Offline
otis24  Offline
South Dakota
With that low of annual mileage and a good oil/filter, I would go two years.
1991 Chevrolet K1500 (4.3, 4x4, 86k miles)
2016 Dodge Grand Caravan
(3.6 V6) 46500 miles
