battery tester. Does the type of battery matter ?
Normally these testers have an option to select the type of battery. Are you sure it does not have that option? It says it covers several different types of batteries.
nope. only thing that can be adjusted is the cca
This type of tester gives you a general idea if your battery is failing. This one shows the internal resistance on the plates, regardless of the type of battery. For a basic battery tester, it looks OK. The one I have cost more and most of the functions I have only used a few times.
Return that one and get a $50 one that has the needed features.
yeah probably gonna do that
