Royal purple discontinuing 30-1218 ?
by jmj540. 03/19/19 10:02 PM
Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Can I Use Maple Syrup Instead Of Oil ?
by Warstud. 03/19/19 06:09 PM
Should criminals be given a second chance?
by ZZman. 03/19/19 04:28 PM
Oil recommendations for old car
by chromedome. 03/19/19 04:06 PM
Reply Box Window
by das_peikko. 03/19/19 03:45 PM
New plants around the yard
by gregk24. 03/19/19 03:24 PM
New Nissan Titan XD w/5.6l oil choices
by josephp732. 03/19/19 03:20 PM
Gran Prix Tour RS tires
by HangFire. 03/19/19 01:50 PM
mm2020, emepher, headoff93, yahtzee, jmd
67560 Registered Users
88 registered members (01rangerxl, 2015_PSD, aaronc7, 69GTX, ABCarr, 8 invisible), 1,458 guests, and 59 spiders.
Topics286,092
Posts4,902,411
Members67,560
Most Online2,967
Mar 10th, 2019
Transmission Hesitating to Shift into 4th Gear #4620972
01/01/18 07:16 PM
01/01/18 07:16 PM
GA, USA
AnonOIl Offline OP
AnonOIl  Offline OP
GA, USA
Hello all! I drive a 2004 Toyota Highlander FWD 4 Cylinder with now 183k on her. Currently I am facing a problem of the transmission sometimes hesitating to go into it's last gear, 4th I believe. This will happen usually in the morning on the first drive of the day to school or work but it also occurs other times, seemingly at random. My ATF is normal looking, all pink/red, no metallic specks etc. and has been drained and refilled as service, twice as far as I know (I am the third owner, was gifted the car from my mother and father before her). However, I know the transmission filter was NEVER replaced. Could a transmission dump, fill, and filter replacement possibly solve my problem? Also maybe some stop slip additive like the Lucasoil stuff? Please let me know anything that I could do to help. Thanks! Have a great day.
Re: Transmission Hesitating to Shift into 4th Gear [Re: AnonOIl] #4620999
01/01/18 07:37 PM
01/01/18 07:37 PM
WI.
dblshock Offline
dblshock  Offline
WI.
Had a '06 same setup...well, you have to tr a dump and new filter very possible filter was never replaced...Toyota even discourages it for reasons I don't understand..I'd surely use Toyota fluid and filter.
16 Civic Coupe Touring 38k
640:1 TCW-3 E091
Edge 0/40 XG7317
Firehawk Indy 500
06 4Runner SR5 146k
640:1 TCW-3
PP 5/30 XG3614
Falken Wildpeak AT3W
Re: Transmission Hesitating to Shift into 4th Gear [Re: AnonOIl] #4621004
01/01/18 07:40 PM
01/01/18 07:40 PM
Indiana
5AcresAndAFool Offline
Indiana
I dont know if this is the problem or not however I will say this. Toyotas generally delay the shifts into top gear when the engine is still cold. So this is very likely why it is doing this when the vehicle is first driven.
In our 05 sienna it delays the shift into 4th and 5th when its cold. It feels very unnatural when it does this. I believe they do this for emissions purposes.
I would think a drain and fill and filter change would be a good idea at this point.
Re: Transmission Hesitating to Shift into 4th Gear [Re: AnonOIl] #4621011
01/01/18 07:49 PM
01/01/18 07:49 PM
WI.
dblshock Offline
dblshock  Offline
WI.
yes my HL delayed shifts when cold now that you reminded me.
640:1 TCW-3 E091
Edge 0/40 XG7317
Firehawk Indy 500
06 4Runner SR5 146k
640:1 TCW-3
PP 5/30 XG3614
Re: Transmission Hesitating to Shift into 4th Gear [Re: AnonOIl] #4621066
01/01/18 08:30 PM
01/01/18 08:30 PM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
What transmission fluid is in it? is it the correct fluid?
Re: Transmission Hesitating to Shift into 4th Gear [Re: AnonOIl] #4621098
01/01/18 08:52 PM
01/01/18 08:52 PM
Oshawa, Ont. Canada
irv Offline
irv  Offline
Oshawa, Ont. Canada
Has it been colder than normal lately where you live? If so, put your transmission in neutral while the vehicle is idling/warming up and see if that makes a difference when you leave? Put it neutral when you start or enter the vehicle, not just before you leave.
I have been doing that for years now and it works, in my opinion. Just don't forget to use your emergency brake/brake while sitting there nor forget to put it back into park if you have to exit for some reason.
Let us/me know if this makes any difference tomorrow?
2017 Chevy Impala 3.6 L.
2013 Ram 5.7 L Hemi Bighorn QC 4x4
2008 Chevy Malibu 2.4 L Ecotec
Pennzoil Platinum and/or Pennzoil Ultra Platinum in all 3.
Re: Transmission Hesitating to Shift into 4th Gear [Re: 5AcresAndAFool] #4621149
01/01/18 09:40 PM
01/01/18 09:40 PM
GA, USA
AnonOIl Offline OP
AnonOIl  Offline OP
GA, USA
Interesting, thank you for the info! Will do, thank you!
Re: Transmission Hesitating to Shift into 4th Gear [Re: irv] #4621161
01/01/18 09:45 PM
01/01/18 09:45 PM
GA, USA
AnonOIl Offline OP
AnonOIl  Offline OP
GA, USA
It has been old but nothing crazy. I live in Georgia so it is in the 30's or so. Thanks for the info!
Re: Transmission Hesitating to Shift into 4th Gear [Re: AnonOIl] #4621231
01/01/18 11:04 PM
01/01/18 11:04 PM
North of you Idaho
KneeGrinder Offline
KneeGrinder  Offline
North of you Idaho
Its the temp. A lot of older auto transmissions have a delay shift into overdrive till they build some heat. Don't worry about it. My Ford does it.
P.S. It might just be the converter not locking up till it builds enough heat.
08 Tribeca 86k PUP 5w30 wix
06 Accord Hybrid 134k PPHM 0w20 wix
02 Chevy k3500 99k Delvac 1 esp 5w40 wix
00 F350 136k Delvac 1300 15w40 wix
Re: Transmission Hesitating to Shift into 4th Gear [Re: AnonOIl] #4621249
01/02/18 12:15 AM
01/02/18 12:15 AM
Modesto,CA
mehullica Offline
mehullica  Offline
Modesto,CA
Try resetting the leaned Ecu values by disconnecting the battery for 10 minutes. Remove the both cables & touch them together to discharge the capacitors & then reconnect. Let the engine fully warmup in park & then drive in a light to moderate throttle in a stop & go city traffic pattern for 10 miles to start a relearn for the ecu & see if it helps
Re: Transmission Hesitating to Shift into 4th Gear [Re: Rand] #4621281
01/02/18 01:35 AM
01/02/18 01:35 AM
GA, USA
AnonOIl Offline OP
AnonOIl  Offline OP
GA, USA
One change done with Valvoline Maxlife ATF and one done with Castrol Transmax High Mileage. Both compatible with toyota's type T-IV fluid required in my tranny I believe.
Re: Transmission Hesitating to Shift into 4th Gear [Re: mehullica] #4621282
01/02/18 01:39 AM
01/02/18 01:39 AM
GA, USA
AnonOIl Offline OP
AnonOIl  Offline OP
GA, USA
Huh, will give that a shot. Thanks!
Re: Transmission Hesitating to Shift into 4th Gear [Re: irv] #4621283
01/02/18 01:39 AM
01/02/18 01:39 AM
GA, USA
AnonOIl Offline OP
AnonOIl  Offline OP
GA, USA
Sounds like a plan, thank you!
