MANNOL ATF Multivehicle
by Ether. 03/25/19 01:17 PM
Welcome to Dusseldorf... err... Edinburgh.
by Quattro Pete. 03/25/19 01:07 PM
1NZ-FE Under Valve Cover - 280,000 Miles
by kschachn. 03/25/19 12:44 PM
Coolant Leak '06 300C
by Redright9. 03/25/19 12:40 PM
New truck
by double vanos. 03/25/19 12:26 PM
What pressure washer should I buy?
by wallyuwl. 03/25/19 11:27 AM
Natural Gas from Ohio Valley
by SubLGT. 03/25/19 11:18 AM
CVT Reliability and Durability
by raffy. 03/25/19 11:00 AM
comfortable seats
by redhat. 03/25/19 10:29 AM
walmart evinrude tcw-3 clearance score
by 1978elcamino. 03/25/19 10:15 AM
Mixing SN/d1G1 with SN+/d1G2?
by doyall. 03/25/19 10:14 AM
Best 2nd Phone Number App ?
by LoneRanger. 03/25/19 09:56 AM
Crud! Wix jacking up prices again! :(
by SubieRubyRoo. 03/25/19 09:53 AM
Interior "quick detailer"
by Redright9. 03/25/19 08:21 AM
Seafoam For Last 100 Miles Before Oil Change ?
by ChrisD46. 03/25/19 07:56 AM
WIX 57151XP factory filled with synthetic oil
by Donald. 03/25/19 06:58 AM
BMW Buying Guide: Every Model, Explained
by wemay. 03/25/19 05:43 AM
Double Din Android Auto Advice
by JeffKeryk. 03/24/19 11:25 PM
VW mk5 a/c intermittently works
by ram_man. 03/24/19 11:01 PM
sonusfaber, Rollo, Drifted, Jcar516, gregjr7
67614 Registered Users
131 registered members (69Torino, 2012AccentSE, 4WD, 97K15004WD, 64bawagon, 2009Edge, 12 invisible), 2,210 guests, and 68 spiders.
Topics286,400
Posts4,907,633
Members67,614
Most Online2,967
Mar 10th, 2019
Help with garage door problem #4620745
01/01/18 04:02 PM
01/01/18 04:02 PM
NorthEast
Vikas Offline OP
Vikas  Offline OP
NorthEast
The garage door(9-feet) wide) has started making bang sound while opening and also while closing but NOT at the same point. I went through every roller and hinge to see if I could determine what was going on. After disconnecting from the automatic opener, I saw that it was hanging just off the floor (about 6 inches). At first I thought top rollers were not perfectly aligned. So fiddled with them. Eventually I kept them loose to see if they were the cause of the problem. Alas, that was not it. After doing little bit more research, it seems that the top most panel has slight buckle at the top of the door. I can feel it by running my finger. I compared it to the other door which does not have that crease. I also noticed that where the opener bracket connects to the door at the top, there is in/out moment when I push/pull on the bracket and makes the similar banging sound. The bolts to the brackets are solid. What exactly is keeping those bolts there? It almost feels as if the bolts are hooked up only to the skin of the panel and no structural metal underneath?
To be able to put garage door strut (aka stiffener) all the way across the top, I will need to have support in the center but I don't feel there is anything for it to grab. But the bracket is obviously connected there! I am not understanding the mechanics completely yet.
The garage has weathered 17 New England years. Is it time just to open the checkbook and have somebody put a new door in?
Lowes sells 10 foot section for the bracing strut. Assuming, I can have them chop in to 9 feet and assuming my Odyssey can fit it diagonally from the back to front, I am willing to try if you guys think I have a chance.
But remember, the door panel has permanent crease and I don't think bracing will get rid of it. I might have damaged the panel beyond salvage. I think the manual track lock was accidentally engaged and I did not realize it and tried to force up/down the door couple of time before giving up on it yesterday and took the other car. Only after coming back I noticed the activation of manual track lock which must have been knocked sideways while unloading the vehicle. I wish I should have instantly recognized the symptoms and had not tried to force the door to open against that lock. This might have caused the crease.
Re: Help with garage door problem [Re: Vikas] #4620753
01/01/18 04:07 PM
01/01/18 04:07 PM
Phoenix
dishdude Offline
dishdude  Offline
Phoenix
Sounds like it's time for a new door. I installed one a few years ago and it was pretty straightforward.
https://www.homedepot.com/p/Clopay-Value...r-HDS/100037677
2018 Challenger SRT 392 PUP 0w-40 Wix 57899XP
2018 GTI
Re: Help with garage door problem [Re: Vikas] #4620761
01/01/18 04:12 PM
01/01/18 04:12 PM
NH
supton Online content
supton  Online Content
NH
How long do garage doors last?
2011 Toyota Camry, base, 2.5L/6MT, 179k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 147k, ours
1999 Toyota Camry LE, 2.2L/4AT, 203k, his
Re: Help with garage door problem [Re: supton] #4620764
01/01/18 04:14 PM
01/01/18 04:14 PM
Phoenix
dishdude Offline
dishdude  Offline
Phoenix
Until they rot or get bent!
2018 GTI
Re: Help with garage door problem [Re: supton] #4620777
01/01/18 04:36 PM
01/01/18 04:36 PM
The Garden State
Whimsey Online content
Whimsey  Online Content
The Garden State
Mine is 27 years old so far. It needed new door springs and an electrical solenoid for the motor. To be honest mine is not used every day otherwise I'm sure the motor would have been worn out by now. The door itself looks new. Old quality made American product, made to last.
Whimsey
Re: Help with garage door problem [Re: Vikas] #4620877
01/01/18 06:02 PM
01/01/18 06:02 PM
Upstate NY
Donald Online content
Donald  Online Content
Upstate NY
I would see if you can disconnect the top panel. Remove it, see if you can bend it to remove the buckle and maybe reinforce that area and reinstall the panel. Trying to deal with it while its in place may not work well.
Maybe a new door.
2015 Ford F250 w/Powerstroke
Re: Help with garage door problem [Re: Vikas] #4620945
01/01/18 06:59 PM
01/01/18 06:59 PM
NorthEast
Vikas Offline OP
Vikas  Offline OP
NorthEast
The door is made in USA, by Windsor Door Model 575. Replacing it will be just putting more money in to Chinese coffer. I think I should try bracing before calling uncle.
Re: Help with garage door problem [Re: Vikas] #4620984
01/01/18 07:27 PM
01/01/18 07:27 PM
Atlanta
DuckRyder Offline
DuckRyder  Offline
Atlanta
It may be possible to buy and replace only the damaged panel - at least worth giving the manufacturer a call.
Robert
  • 2005 Honda Civic Sedan
  • 1972 F100 Ranger XLT (390/C6/9” 3.50 Truetrac)
  • 2002 Ford Ranger XLT 4D Supercab 3.0L
Re: Help with garage door problem [Re: Vikas] #4620985
01/01/18 07:27 PM
01/01/18 07:27 PM
Cloquet Mn.
bobbobtar Offline
bobbobtar  Offline
Cloquet Mn.
I had a garage door panel damaged and was able to replace just the one panel, easy fix.
2017 Toyota Highlander
2018 John Deere 2032R
2014 CanAm Spyder
1981 Chevy Malibu 355cu 425hp
Re: Help with garage door problem [Re: supton] #4620988
01/01/18 07:30 PM
01/01/18 07:30 PM
British Columbia, Canada
ecotourist Offline
ecotourist  Offline
When we sold our house in Winnipeg it still had the original garage door. The house with attached garage was built between 1929 and 1932. I replaced the bottom "board" because it was getting a little rotten.
2000 BMW 528i 5MT
2007 Honda Accord EX-L 4Door V6 6MT
Re: Help with garage door problem [Re: Vikas] #4621003
01/01/18 07:39 PM
01/01/18 07:39 PM
MIchigan
Warstud Offline
Warstud  Offline
MIchigan
I would stand on a ladder overlooking the door and observe as some one manually lifts the door.
Re: Help with garage door problem [Re: Vikas] #4621028
01/01/18 08:01 PM
01/01/18 08:01 PM
Kevil,Ky
vwmaniaman Offline
vwmaniaman  Offline
Kevil,Ky
You could always screw a 2 X 4 into the cavity behind the metal lip to see if that was a lack of reinforcement problem. If that helps to stop the bang noise they buy the brace and do it right.
Don't waste your time on a slipshod repair.
Re: Help with garage door problem [Re: Vikas] #4622758
01/03/18 02:32 PM
01/03/18 02:32 PM
Chicago,IL,USA
pandus13 Online content
pandus13  Online Content
Chicago,IL,USA
3 Pictures?
-1 from middle, 2 from sides and a bit up to see the torque/spring set-up you have?
I'm 6'2" and about 250# (at the time):
I de-installed the damaged door, and installed a Menards door, panel by panel + new springs by myself
-safety first!!!!!!!!!
-sustain door from under in 2-3 points
Are the tracks plus walls/wood holding them in good condition and leveled?
Is the steel wire cable route free of obstructions?
do the rollers "slip"? what is their condition?
16 Golf SportWagen
13 Mazda5
08 Yaris
04 Elantra
95 accent
95 mystique
97 concorde
