1NZ-FE Under Valve Cover - 280,000 Miles
by kschachn. 03/25/19 12:44 PM
Coolant Leak '06 300C
by Redright9. 03/25/19 12:40 PM
New truck
by double vanos. 03/25/19 12:26 PM
What pressure washer should I buy?
by wallyuwl. 03/25/19 11:27 AM
Natural Gas from Ohio Valley
by SubLGT. 03/25/19 11:18 AM
CVT Reliability and Durability
by raffy. 03/25/19 11:00 AM
comfortable seats
by redhat. 03/25/19 10:29 AM
walmart evinrude tcw-3 clearance score
by 1978elcamino. 03/25/19 10:15 AM
Mixing SN/d1G1 with SN+/d1G2?
by doyall. 03/25/19 10:14 AM
Best 2nd Phone Number App ?
by LoneRanger. 03/25/19 09:56 AM
Crud! Wix jacking up prices again! :(
by SubieRubyRoo. 03/25/19 09:53 AM
Interior "quick detailer"
by Redright9. 03/25/19 08:21 AM
Seafoam For Last 100 Miles Before Oil Change ?
by ChrisD46. 03/25/19 07:56 AM
WIX 57151XP factory filled with synthetic oil
by Donald. 03/25/19 06:58 AM
BMW Buying Guide: Every Model, Explained
by wemay. 03/25/19 05:43 AM
Double Din Android Auto Advice
by JeffKeryk. 03/24/19 11:25 PM
VW mk5 a/c intermittently works
by ram_man. 03/24/19 11:01 PM
sonusfaber, Rollo, Drifted, Jcar516, gregjr7
67614 Registered Users
124 registered members (AndyB, 64bawagon, 2009Edge, 4WD, 240_Ed, 2015_PSD, 8 invisible), 2,192 guests, and 67 spiders.
Topics286,399
Posts4,907,622
Members67,614
Most Online2,967
Mar 10th, 2019
Page 1 of 8 1 2 8
0 oil pressure for 10 seconds #4620415
01/01/18 10:52 AM
01/01/18 10:52 AM
Northeastern Vermont
littleant Offline OP
Happy New Year. Well had to use the 02 jeep this morning. It was -32. Nose of jeep was pulled in the garage a little. Went to start and it turned over slow but did start. Was watching oil gauge and it showed O for about 10 seconds. Then a light came on beeping check gauges. Then the gauge started showing pressure and light went out. Never knew this light was even there in 6 years. Jeep has the 4.0. Just serviced about a month ago with valvoline maxlife 5w30 SB and added a little zinc and 1/4 bottle of lubro moly mos2 and motorcraft FL-1A. Does it sound like the adbv did not open quick enough. This is a top thread adbv. Your opinions are appreciated.
I can't prevent getting old but I REFUSE to grow up.
2010 Mountaineer 4.0
2002 Jeep Wrangler TJ 4.0
Re: 0 oil pressure for 10 seconds [Re: littleant] #4620426
01/01/18 11:01 AM
01/01/18 11:01 AM
PimTac Offline
PimTac  Offline
At those temps I would be using a block or pan heater. How was the engine noise on startup and for the first moments?
Cannot see signatures any longer so it doesn’t matter.
Re: 0 oil pressure for 10 seconds [Re: littleant] #4620433
01/01/18 11:08 AM
01/01/18 11:08 AM
Indiana
dlundblad Online happy
dlundblad  Online Happy
Indiana
I had the same thing with my Jeep in -27*F. 10w30 PYB and a Mopar filter.
First time I heard the check gauges chime too.
I am assuming you mean the bypass as opposed to the ADBV. I am sure both functioned properly given the conditions. -32* (be it *F or *C) is cold!
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 186k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 153k Synpower 5w30 Supertech ST3980 (Ecore)
Re: 0 oil pressure for 10 seconds [Re: littleant] #4620446
01/01/18 11:17 AM
01/01/18 11:17 AM
Illinois
tig1 Offline
tig1  Offline
Illinois
This is an example of slow oil flow in extreme cold temps. Perhaps changing to a 0-30 would help.
2007 Ford Fusion 239,000 miles
M1 0-20 EP
2017 Ford Fusion 67K
M1 0-20 EP
M1 ATF and Valvoline LV
M1 10-30 in all OPE
MC filters
Re: 0 oil pressure for 10 seconds [Re: littleant] #4620447
01/01/18 11:19 AM
01/01/18 11:19 AM
Dallas, Texas
SuperDave456 Offline
Dallas, Texas
Maxlife is a synthetic, but it's pour point is -40 degrees F if I remember correctly.
-32 F is getting close to that.
+1 for some kind of block heater.
BTW, Even if it is just a shop lamp with an old school 60 watt incandescent bulb placed under the oil pan 20 minutes before driving, I've heard of such measures significantly helping at such temperatures.
Re: 0 oil pressure for 10 seconds [Re: littleant] #4620453
01/01/18 11:23 AM
01/01/18 11:23 AM
Costa Rica
CostaCaptain Offline
Costa Rica
-32f is exactly freezing point and as the Jeep was with the nose in the garage engine temp was probably a tad higher.
I would exclude something frozen excepth the oil pressure sensor get stuck for some seconds.
The ADBV (Anti Drain Back Valve)avoid that the oil drain back to the sump and should keep the oil in some parts of the upper part of the engine.
If the valve would be stuck close then the oil pressure would rise fast, if she is stuck open then all the oil drians back in the sump and
the oil pump has to fill all oil conducts after every start.
However, if the oil pressure is really near zero for 10 seconds than that's not a good thing!
As long the oil pump is good and sucking oil she should build up pressure much quicker.
Chris
Re: 0 oil pressure for 10 seconds [Re: littleant] #4620458
01/01/18 11:27 AM
01/01/18 11:27 AM
The jeep always had a light piston slap when I purchased 6 years ago with 55,000 now have 168,000 miles. Once engine is warm no slap at all. This morning there was no more noise then usual (actually a little less). Dead quite when warm and driving. Use to run maxlife 5w30 conventional or Quaker state defy 5w30 conventional. Now both are synthetic blend and was a little more noisy. That is why I add the little zinc and moly.
Re: 0 oil pressure for 10 seconds [Re: PimTac] #4620461
01/01/18 11:28 AM
01/01/18 11:28 AM
Re: 0 oil pressure for 10 seconds [Re: littleant] #4620464
01/01/18 11:30 AM
01/01/18 11:30 AM
Central Coast California
RedOakRanch Offline
RedOakRanch  Offline
At that temp I'm pretty sure you had no oil for those 10 seconds.
1994 Ford Crown Vic 207k-Frankenbrew 0w20,30,40!
2005 Chevy 1500 Crewcab 4X4 180k-BC 0w30 $2/qt
2016 Outback 2.5 Limited 60k-shop brand?
Re: 0 oil pressure for 10 seconds [Re: littleant] #4620490
01/01/18 11:55 AM
01/01/18 11:55 AM
missouri
ragtoplvr Online content
ragtoplvr  Online Content
missouri
What oil you did have on the bearings would be more the consistency of a very light grease. It is doubtful anything was harmed. The anti drainback valve probably did not seal and allowed the oil galleys to drain. You would have had some flow to the bearings before the gauge could respond. Cold weather is hard on equipment, and the automakers test for it. I have heard they test at -40 if the winter lets them.
Rod
Re: 0 oil pressure for 10 seconds [Re: littleant] #4620504
01/01/18 12:14 PM
01/01/18 12:14 PM
Jupiter, Florida
Cujet Online content
Cujet  Online Content
Jupiter, Florida
Way too cold for that oil. There is no telling whether damage happened or not. Might depend on the last shutdown and how hot it was. Remember even with pressure indicated, many components may not have flow. Such as the bearings farthest from the filter. As the rod bearings get flow through the main bearings and drilled passages on the crank.
Re: 0 oil pressure for 10 seconds [Re: tig1] #4620506
01/01/18 12:15 PM
01/01/18 12:15 PM
PimTac Offline
PimTac  Offline
Tig1 has a good suggestion here. Being that the OP is in Vermont, cold winters are the norm perhaps not this cold but nonetheless. Having a heater just helps the engine.
Someone else mentioned that -31F is just freezing. I would rethink that.
Re: 0 oil pressure for 10 seconds [Re: PimTac] #4620516
01/01/18 12:27 PM
01/01/18 12:27 PM
Agree Tuesday will look for a block heater. These temps will continue through this and next week. Heck we haven't even gotten to the cold months yet
Re: 0 oil pressure for 10 seconds [Re: littleant] #4620532
01/01/18 12:44 PM
01/01/18 12:44 PM
SC, USA
Bxnanaz Offline
Bxnanaz  Offline
SC, USA
You really should also look into some full syn 0w-30 as well.
Re: 0 oil pressure for 10 seconds [Re: littleant] #4620538
01/01/18 12:48 PM
01/01/18 12:48 PM
Costa Rica
Costa Rica
sorry but i may missunderstood, you are talking of -32F and that is -35 celsius.
Yes, this is cold and may explain the low oil pressure.
If temp drops frequently so low then a block heater would be a good solution, and a 0W-40 oil will aso help with cold start.
Chris
Page 1 of 8 1 2 8
