DIY alignment done right?
by tookien. 03/24/19 10:03 PM
Cell phone privacy question
by loneryder. 03/24/19 10:00 PM
Ride quality between 45 and 35 sidewall
by bowlofturtle. 03/24/19 09:23 PM
FRAM TG 7317 - 12K miles opened
by crazy_raccoon. 03/24/19 09:01 PM
2014-2017 Toyota Corolla CVT Quiet Recall
by StevieC. 03/24/19 08:11 PM
Finally Found Factory Ammo my 308 Bolt Gun Likes
by Fastzntn. 03/24/19 08:10 PM
Umarex Glock 19 Co2
by Sonic. 03/24/19 07:57 PM
I put in 2 1/2 qts, damage?
by JLawrence08648. 03/24/19 07:21 PM
How to dispose / recycle Li-Ion batteries?
by 92saturnsl2. 03/24/19 06:16 PM
New member of the (automotive) family!
by addyguy. 03/24/19 06:04 PM
6.2 f250 6.4 ram 2500 towing with a gasser
by FLORIDA. 03/24/19 05:55 PM
T5 15w40 for my bike?
by Degreaser. 03/24/19 05:47 PM
Studded tires in warm weather
by y_p_w. 03/24/19 05:28 PM
ST 15W40
by mobilaltima. 03/24/19 05:02 PM
I need a filter cutter person
by Marco620. 03/24/19 03:21 PM
VIRGIN BOSCH D+ 3421 CUT OPEN
by 53' Stude. 03/24/19 02:45 PM
My first cut. Donaldson P502503
by BeerCan. 03/24/19 02:25 PM
Rollo, Drifted, Jcar516, gregjr7, daveed
67613 Registered Users
91 registered members (2015_PSD, 4WD, 2010Civic, aleneros, ammolab, Ag76, 10 invisible), 1,703 guests, and 60 spiders.
Topics286,361
Posts4,907,079
Members67,613
Most Online2,967
Mar 10th, 2019
Lifting a 1 1/2 Ton Counter Weight off a Forklift #4620372
01/01/18 10:10 AM
01/01/18 10:10 AM
Toronto, Canada
George7941 Offline OP
Toronto, Canada
The muffler rusted out and the power steering cylinder developed a leak. The counter weight has to be taken off to access both components.
Checking the internet and Youtube in particular only resulted in instructions to use a second forklift to lift off the counterweight. However we only have this one Toyota forklift. What to do?
So we fabricated this structure, with the four posts being 10' long 4x4s. The two chain hoists are 1 ton Speedway brand units from Home Depot, for $55 each. I used 3/4 in eyebolts rated at 6000 lbs each and extended them with coupling nuts and 3/4 threaded rod.
The whole operation went pretty smoothly.
2006 GMC Sierra 4.3l, NV3500,G80 , Mobil 1 5W30, Dexcool.
1987 BMW R80 - sold
2015 Honda CBR300R
Staying out of the right lane a lot.
Re: Lifting a 1 1/2 Ton Counter Weight off a Forklift [Re: George7941] #4620382
01/01/18 10:16 AM
01/01/18 10:16 AM
central ga
urrlord Offline
urrlord  Offline
central ga
pretty good thinking.
Re: Lifting a 1 1/2 Ton Counter Weight off a Forklift [Re: George7941] #4620389
01/01/18 10:22 AM
01/01/18 10:22 AM
CA
spackard Offline
spackard  Offline
CA
Good job!
Re: Lifting a 1 1/2 Ton Counter Weight off a Forklift [Re: George7941] #4620403
01/01/18 10:39 AM
01/01/18 10:39 AM
Indiana
dlundblad Offline
dlundblad  Offline
Indiana
Hard to tell with the photo and obviously what you did worked, but the beam with the eye bolts looks like the weak link. Very good idea though and much cheaper than bringing more equipment in.
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 186k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 153k Synpower 5w30 Supertech ST3980 (Ecore)
Re: Lifting a 1 1/2 Ton Counter Weight off a Forklift [Re: George7941] #4620408
01/01/18 10:45 AM
01/01/18 10:45 AM
Duvall WA - Pacific NW USA
Pablo Offline
Pablo  Offline
hahaha cool
ALMOST as bad as changing the HVAC fan in an old Volvo 240!
DIRECT JOBBER - PABLO - for all your Amsoil needs
http://oilslubesandfilters.shopamsoil.com/
Re: Lifting a 1 1/2 Ton Counter Weight off a Forklift [Re: George7941] #4620418
01/01/18 10:53 AM
01/01/18 10:53 AM
Central Coast California
RedOakRanch Offline
RedOakRanch  Offline
I like it! I recently had to change out the large rear tires on my tractor and every step I thought about getting the tractor to lift them. Was like trying to turn the lights on when you know the power is out.
1994 Ford Crown Vic 207k-Frankenbrew 0w20,30,40!
2005 Chevy 1500 Crewcab 4X4 180k-BC 0w30 $2/qt
2016 Outback 2.5 Limited 60k-shop brand?
Re: Lifting a 1 1/2 Ton Counter Weight off a Forklift [Re: George7941] #4620419
01/01/18 10:54 AM
01/01/18 10:54 AM
Toronto, Canada
Toronto, Canada
The lower half of the beam is 7 2x4s on their sides all screwed together and the upper half is 3 4x4s. The halves are clamped together with lag bolts. The beam was cobbled together without much planning. I was expecting more bending of the beam but there is no obvious bending of the beam with a 1 1/2 ton load. It helps that the load is not all concentrated at the middle of the beam but is applied at two points a foot apart.
1987 BMW R80 - sold
2015 Honda CBR300R
Re: Lifting a 1 1/2 Ton Counter Weight off a Forklift [Re: George7941] #4620541
01/01/18 12:49 PM
01/01/18 12:49 PM
Oshawa, Ont. Canada
irv Offline
irv  Offline
Oshawa, Ont. Canada
That's pretty ingenious, and it looks like you planned it out well, but it would still make me nervous using wood. Is it off a Toyota Tow motor or something different?
2017 Chevy Impala 3.6 L.
2013 Ram 5.7 L Hemi Bighorn QC 4x4
2008 Chevy Malibu 2.4 L Ecotec
Pennzoil Platinum and/or Pennzoil Ultra Platinum in all 3.
Re: Lifting a 1 1/2 Ton Counter Weight off a Forklift [Re: irv] #4620551
01/01/18 12:59 PM
01/01/18 12:59 PM
Toronto, Canada
Toronto, Canada
It is a 1998 Toyota forklift, model 426FGU25, 2 1/2 ton capacity. Solid well built forklift with about 13000 hours on it and working very well.
I wasn't too sure about the wood beam, but,as you can see in the picture, it is not deflecting much under the 1 1/2 ton load. Also it is not as if we are working under the load. We operated the chain hoists standing away a bit from the structure in case anything failed.
1987 BMW R80 - sold
2015 Honda CBR300R
Re: Lifting a 1 1/2 Ton Counter Weight off a Forklift [Re: George7941] #4620576
01/01/18 01:23 PM
01/01/18 01:23 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
4x4 held in column is good for 50K+ so the cross beams are the weak links. You's are obviously up to the job smile
Folks have been building huge heavy stuff with wood for ever. It works as long as no mistakes are made ...
Re: Lifting a 1 1/2 Ton Counter Weight off a Forklift [Re: George7941] #4620592
01/01/18 01:36 PM
01/01/18 01:36 PM
Oshawa, Ont. Canada
irv Offline
irv  Offline
Oshawa, Ont. Canada
We use those at work as well, OPG. smile and that is likely why the use of wood makes me nervous as that is something we'd never do.
However, like you mentioned and the other reply above, you have adequate weight carrying abilities with the amount and the size of wood you used and how you designed/implemented it.
Good job. cheers
Re: Lifting a 1 1/2 Ton Counter Weight off a Forklift [Re: George7941] #4620646
01/01/18 02:36 PM
01/01/18 02:36 PM
Ontario Canada
cjcride Offline
cjcride  Offline
Ontario Canada
You can see the BITOG touch there.
Well Done.
