Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
FYI: Costco is now stocking the 'good' Techron
by mbz321. 03/20/19 12:32 PM
Auto maintenance advice from a locksmith?
by Variant_S. 03/20/19 12:18 PM
Purolator 12 Pack L25608 $21
by hatt. 03/20/19 12:04 PM
Dealer service and franchise laws.
by BMWTurboDzl. 03/20/19 11:46 AM
Tie rod tapers
by LeakySeals. 03/20/19 11:26 AM
Quality Lug Nuts
by jcartwright99. 03/20/19 10:56 AM
More than one Reality
by beanoil. 03/20/19 10:50 AM
Reusable Oil Storage Container
by BamaE92. 03/20/19 10:37 AM
Bank 1 on an Equinox
by Washoe_Mark. 03/20/19 08:47 AM
How do you pronounce the word Vehicle?
by ZZman. 03/20/19 08:21 AM
Inline Fuel Filter
by CCI. 03/20/19 08:08 AM
Are All Douglas Tires USA Made?
by Miller88. 03/20/19 07:30 AM
Turn signal bulbs for '15 BMW?
by Benzadmiral. 03/20/19 07:02 AM
Drain/refill vs diy flush?
by Back40. 03/20/19 05:59 AM
Valvoline 5w30 Synpower HSTS?
by avi1777. 03/20/19 05:05 AM
Castrol Edge 5W50 "Supercar Titanium FST"
by Berto. 03/20/19 02:43 AM
The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Saxman657, Maxxforce, Washoe_Mark, CG_BrianM, TBF
67565 Registered Users
110 registered members (AndyB, ArrestMeRedZ, addyguy, avi1777, anndel, 11 invisible), 2,071 guests, and 59 spiders.
Topics286,152
Posts4,903,059
Members67,565
Most Online2,967
Mar 10th, 2019
Anti-Freeze for Alaska #4620234
01/01/18 02:11 AM
01/01/18 02:11 AM
chicagoland
Lee4212 Offline OP
Lee4212  Offline OP
chicagoland
Guys talking in break room and we wondered what anti freeze they use in places like Alaska. Wouldn't that be good for area's like me right now at -5 degrees and just nasty cold air ? We we're just wondering.
Re: Anti-Freeze for Alaska [Re: Lee4212] #4620237
01/01/18 02:17 AM
01/01/18 02:17 AM
USA
oldhp Offline
oldhp  Offline
USA
If you mix any antifreeze right you can get to -30 very easy.
2018 RAM 1500 3.6/8 speed.
2017 Jeep Sahara Unlimited 3.6
"U kan't fixe it......if'n it ain't broke."
Re: Anti-Freeze for Alaska [Re: Lee4212] #4620238
01/01/18 02:18 AM
01/01/18 02:18 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
A 55/45 mix will handle the worst cold almost anywhere on the planet.
There are "waterless coolants" also available.
Re: Anti-Freeze for Alaska [Re: Lee4212] #4620240
01/01/18 02:22 AM
01/01/18 02:22 AM
WI
HoosierJeeper Offline
WI
50/50 Zerex G05 is good to -34F and I've had it in -36F with no issues at all.
15 Jeep KL Limited V6: Formula Shell 5W20
07 LR3 SE V8: Maxlife 5W30
05 Jeep KJ Limited: PHM 5W30
96 Jeep XJ Country: STP HM 5W30 (winter)
Re: Anti-Freeze for Alaska [Re: Lee4212] #4620245
01/01/18 02:33 AM
01/01/18 02:33 AM
Deplorable in apple valley, ca
Chris142 Online content
Chris142  Online Content
70% will get you down to -60f. They also run block and oil pan heaters.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Anti-Freeze for Alaska [Re: Linctex] #4620248
01/01/18 02:43 AM
01/01/18 02:43 AM
MTL, CANADA
Rolla07 Offline
Rolla07  Offline
MTL, CANADA
Im not in Alaska, but my car runs 55/45 mix here. Its been -8 Farenheit most of the week here. I do use a block heater as well.
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
Re: Anti-Freeze for Alaska [Re: Lee4212] #4620322
01/01/18 08:43 AM
01/01/18 08:43 AM
New York City
ThankYouma Offline
ThankYouma  Offline
New York City
All the information I can find says with little variation that:
Quote:
By itself ethylene glycol boils at 330F but it doesn't transfer heat very well and its freezing point is -8F. Water is added to improve heat transfer.
Here is a list of boiling and freezing point for Antifreeze to Water mixtures as measured at sea level.
30/70 boils 220F freezes 3F
40/60 boils 225F freezes -12F
50/50 boils 226F freezes -32F
60/40 boils 234F freezes -57F
Re: Anti-Freeze for Alaska [Re: ThankYouma] #4623887
01/04/18 02:53 PM
01/04/18 02:53 PM
USA
slacktide_bitog Offline
USA
It's actually +8 crzy
I was able to find this chart from a google search:
Re: Anti-Freeze for Alaska [Re: Lee4212] #4623908
01/04/18 03:13 PM
01/04/18 03:13 PM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
It varies because ethylene glycol does not have a well defined freezing point, but the melting point is generally listed as +9 deg. F. The freezing point is somewhat higher.
That graph is one of my favorite graphs to post when discussions like this come up. It clearly shows the power of a solute in a solution vs. a pure substance. After 50% you are seeing the effect of the water on the glycol.
The sweet spot is definitely at about 65%. Once in a while we get someone posting about how they run straight antifreeze to get maximum freeze protection. This graph shows why that is a foolish notion (apart from the much lower specific heat capacity of glycol).
1994 BMW 530i, 241K
1996 Honda Accord, 267K
1999 Toyota Sienna, 409K
2000 Toyota ECHO, 280K
Re: Anti-Freeze for Alaska [Re: Lee4212] #4624020
01/04/18 04:49 PM
01/04/18 04:49 PM
Alaska
m37charlie Offline
m37charlie  Offline
Alaska
When a mixture is >50-55% glycol it doesn't expand when it freezes (into a gel, not a hard crystalline mass) and therefore won't crack things. So even in Oymyakon, Yakutia, Siberia 60/40 should be safe.
05 Unimog U500/Unicat camper/Delvac 1 SHC ACEA E4/E5
09 BMW X5 35d/Delvac1 LE 5W30
88 Toyota OJ50LV OM314 motor D1 SHC
52 Dodge M37/Hercules diesel
Re: Anti-Freeze for Alaska [Re: Lee4212] #4624135
01/04/18 06:52 PM
01/04/18 06:52 PM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
So 65% seems to be the solution for when it's science fiction cold out.
Re: Anti-Freeze for Alaska [Re: DoubleWasp] #4624245
01/04/18 08:48 PM
01/04/18 08:48 PM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
Correct, and when I said "sweet spot" I meant only for the lowest freezing point not the optimal mixture for operation. In general you shouldn't mix it any more concentrated than you need since the specific heat capacity of glycol is quite a bit less than water. Some coolants specify a minimum (and maximum) concentration which obviously should be observed.
1994 BMW 530i, 241K
Re: Anti-Freeze for Alaska [Re: kschachn] #4624286
01/04/18 09:52 PM
01/04/18 09:52 PM
Alaska
m37charlie Offline
m37charlie  Offline
Alaska
?? what?
it is called a "eutectic mixture"
Re: Anti-Freeze for Alaska [Re: DoubleWasp] #4624391
01/05/18 12:24 AM
01/05/18 12:24 AM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
I would say so. I usually aim for about 60/40. That way, if I'm over on the glycol side, I'm not pushing the limits there, and if I have a bit too much water, I'll still be over closer to 55/45 and have plenty of protection. I've seen vehicles freeze up before, but never one of mine.
Plain, simple Garak.
Re: Anti-Freeze for Alaska [Re: Lee4212] #4624419
01/05/18 01:02 AM
01/05/18 01:02 AM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
Had one incident. We hit 40 below that night in Saskatoon, Canada. Had mushy ice in the rad but no damage. I try go to on the high side of 50 % with the glycol ever since.
SF
If you want the job done right......do it yourself.
