Maybe I'm crazy.
by TRDPRO85. 12/16/18 07:50 PM
Pacer EON E-11 Synthetic Motor Fluid
by Brandon9797. 12/16/18 07:46 PM
Reuse transmission fluid??
by FFeng7. 12/16/18 07:35 PM
Amsoil SS color change
by BigShug681. 12/16/18 07:21 PM
Why don't owner's manuals specify the oil type
by OilUzer. 12/16/18 07:13 PM
belt tensioner problems
by mobilaltima. 12/16/18 06:57 PM
How bout them Patriots
by 53' Stude. 12/16/18 06:36 PM
Hand held Ham radio suggestions
by littleant. 12/16/18 05:20 PM
Ford 2.3 EB's using 87 vs 91/93 octane
by Whimsey. 12/16/18 04:48 PM
Oil analysis pump tube?
by maximum6. 12/16/18 03:56 PM
Mahle charcoal lined filter..the best!
by TiGeo. 12/16/18 03:45 PM
Diesel engines and emissions
by spasm3. 12/16/18 03:31 PM
Experiment time
by 53' Stude. 12/16/18 02:52 PM
2019 2.7L EB - Edge ST & Catch Can
by -SyN-. 12/16/18 02:51 PM
15 Grand Caravan
by zrxkawboy. 12/16/18 02:18 PM
Pennzoil Platinum 5w30 at walmart.com
by Irishman. 12/16/18 11:08 AM
Brandon9797, Landngroove, DanielH, Cpcz9382, PPWarrior
66699 Registered Users
129 registered members (2009ram2500, 69Torino, 53' Stude, 2003f7, 11 invisible), 2,098 guests, and 35 spiders.
Topics295,165
Posts4,928,943
Members66,699
Most Online2,553
Oct 27th, 2018
Fluid temps when it's cold out #4619815
12/31/17 02:55 PM
12/31/17 02:55 PM
Ontario, Canada
OVERKILL Offline OP
OVERKILL  Offline OP
Ontario, Canada
I think we had a discussion on this in the past as one of the key points of discussion regarding winter driving has been oil temperature versus coolant temperature. I have indicated that this depends on the presence, or lack thereof, of an oil/coolant heat exchanger, which many vehicles, particularly with the pursuit of thinner lubricants, have been fitted with. My last four vehicles have all had this feature and subsequently coolant and oil temperatures track well together during warm-up.
Today it was -20C (-4F) which is a bit warmer than previous days, but unfortunately I didn't think about this until today. I can check at colder temps if there is interest.
I figured I'd snap a few shots of the VIC in UConnect for the Jeep after approximately 10 minutes of driving, here are the results:
As can be seen oil/coolant track basically identically. Trans temperature lags significantly in comparison. Also, intake air temperature is an interesting one. It drops considerably when moving however between the time I stopped and the time I took the pictures it had increased to what you see from several degrees cooler. She breathes near the rad, which is likely an important part of that.
2018 RAM 1500 Big Horn EcoDiesel
2016 Grand Cherokee SRT
Re: Fluid temps when it's cold out [Re: OVERKILL] #4619829
12/31/17 03:10 PM
12/31/17 03:10 PM
Great Lakes
Quattro Pete Offline
Great Lakes
Oil temp in wife's Q5 is at around 175F when driving around town when it's cold like today (around 10F).
BTW, these nice digital gauges make me want to get an SRT. smile
'02 530i (Edge 0W-40)
'15 Q5 3.0T (Edge 5W-40)
'18 Charger SRT (PUP 0W-40 SRT)
Re: Fluid temps when it's cold out [Re: OVERKILL] #4619830
12/31/17 03:11 PM
12/31/17 03:11 PM
Campbellsville, KY
Alex_V Offline
Alex_V  Offline
Campbellsville, KY
Must have a pretty good oil cooler. Hopefully it keeps the two temps that close when you're thrashing it on a hot summer day. wink
To quote a friend, "Synthetics, man."
'85 GMC C3500, 454, 132K
'82 Mercedes 300CD, OM617 turbo, 173K (totaled 2018, in rehab)
'85 Mercedes 300TD, OM617 turbo, 217K (wife's)
'67 Suburban, 350, 331K
Re: Fluid temps when it's cold out [Re: Alex_V] #4619841
12/31/17 03:15 PM
12/31/17 03:15 PM
Ontario, Canada
OVERKILL Offline OP
OVERKILL  Offline OP
Ontario, Canada
Yeah, it's a pretty good sized exchanger and does a good job year-round.
Here's the parts diagram for it:
Re: Fluid temps when it's cold out [Re: OVERKILL] #4619845
12/31/17 03:21 PM
12/31/17 03:21 PM
In the shop
53' Stude Online content
53' Stude  Online Content
In the shop
Overkill, thank you for the neat info smile Cheers1
09' Camry LE, 141,020 miles
PP 5w30 and TG 4967
Re: Fluid temps when it's cold out [Re: OVERKILL] #4619870
12/31/17 03:53 PM
12/31/17 03:53 PM
New Jersey
JHZR2 Offline
JHZR2  Offline
New Jersey
My 135i still hits the standard 240-ish F oil temperatures when below freezing.
Ive never found any vehicle that doesn't track to normal operating temperature in below freezing temperatures. Diesels can be tough to get to temp without load, and older small 4 cyl engines would also take forever. Modern small engines come up to temp well, I can't imagine a behemoth having an issue.
Re: Fluid temps when it's cold out [Re: JHZR2] #4619875
12/31/17 03:56 PM
12/31/17 03:56 PM
Ontario, Canada
OVERKILL Offline OP
OVERKILL  Offline OP
Ontario, Canada
My M5 was cold blooded on the oil side of things, because of its big cooler in the valley. I believe I posted some pics of it in the past. It really could not get the oil up to temp in winter months.
Re: Fluid temps when it's cold out [Re: OVERKILL] #4619888
12/31/17 04:07 PM
12/31/17 04:07 PM
Massachusetts
VeryNoisyPoet Offline
Massachusetts
Cool info! Was that slow city driving or highway driving? How much oil does the Jeep hold? Any info on where the temp probe for the oil takes the measurement?
I installed a transmission temp sensor and see similar lag compared to coolant temp. Considering an oil pressure and oil temp sensors next. My IR thermometer on bottom of sump pan shows 150 F after 10 minutes of city driving in 10 F ambient temp. Coolant temp was stable at 185 F by then. Not sure how accurately the thermometer reads or how well pan temp reflects actual oil temp.
Both transmission and engine have oil to coolant heat exchangers in the radiator end tanks.
1998 V70 GLT / 195k miles [10w-30 Valvoline Syn w/ Maxlife Tech + Mann W917 filter]
"Use yah blinkah!"
"Be nice. The alternative involves an air horn and 7000 lumens of high beam."
Re: Fluid temps when it's cold out [Re: OVERKILL] #4619891
12/31/17 04:11 PM
12/31/17 04:11 PM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
As I've mentioned before, with the G37 at least, even ten minutes of driving in these temperatures, and you won't touch the oil filter with your bare hands. It's a totally different experience from the Chevy small blocks of the day, when I could change oil in summer after a day's running in 30 C or warmer, without gloves.
Plain, simple Garak.
2008 Infiniti G37 - Shell ROTELLA T6 Multi-Vehicle 5w-30, NAPA Gold 7356
Re: Fluid temps when it's cold out [Re: VeryNoisyPoet] #4619900
12/31/17 04:19 PM
12/31/17 04:19 PM
Ontario, Canada
OVERKILL Offline OP
OVERKILL  Offline OP
Ontario, Canada
This was all city driving, was dropping off the kids for New Years at a sitter.
The Jeep holds 7L of oil roughly. The temp sensor is on the front of the engine, just below the left cylinder head IIRC.
Re: Fluid temps when it's cold out [Re: OVERKILL] #4619905
12/31/17 04:23 PM
12/31/17 04:23 PM
New Jersey
JHZR2 Offline
JHZR2  Offline
New Jersey
The 135i cooler is relatively undersized, resulting in high temps.
I'm sort of surprised any of these aren't thermally controlled. Even my early 80s diesels have thermostats to prevent the oil from being too cold.
Re: Fluid temps when it's cold out [Re: Garak] #4619909
12/31/17 04:28 PM
12/31/17 04:28 PM
New Jersey
JHZR2 Offline
JHZR2  Offline
New Jersey
I dunno. I noticed this when servicing 20kw kubota IDI diesel gensets after the hurricanes. And they had 7qt sumps.
Re: Fluid temps when it's cold out [Re: JHZR2] #4619910
12/31/17 04:28 PM
12/31/17 04:28 PM
Ontario, Canada
OVERKILL Offline OP
OVERKILL  Offline OP
Ontario, Canada
The M5 had a thermostat on its oil cooler circuit, but IIRC, the cooler was air/oil and even when bypassed, there was enough heat shedding going on that it was just not a good winter setup. In comparison, all the Chargers and the Expedition have been oil/coolant which heat up the oil in tick with the coolant.
Re: Fluid temps when it's cold out [Re: OVERKILL] #4619915
12/31/17 04:33 PM
12/31/17 04:33 PM
Cedarbrae, Ontario
xxch4osxx Offline
xxch4osxx  Offline
Cedarbrae, Ontario
The oil temp in my Ram comes up quick to about the same as the coolant even in the really cold days we have had lately. The heater in my Ram works really good as well, thankfully lol
2015 RAM SXT Crew Cab 5.7 with 6 speed tranny.
2008 Mazda 3 GS Sport Hatchback 5sp MT (Girlfriend's car)
Re: Fluid temps when it's cold out [Re: OVERKILL] #4619932
12/31/17 04:56 PM
12/31/17 04:56 PM
CO
Nederlander75 Offline
CO
My S65 M3 runs around 215F in 90 ambient and around 205 in single digits with its huge cooler. My BRZ similar with no cooler. This is after 25 minutes averaging 3500-4000RPM and a couple redline pulls. On the track itís a drastically different story.
