White or milky cloud in engine oil when cold
by OilUzer. 01/20/19 02:08 AM
Karma Kruiser!
by ekpolk. 01/20/19 01:36 AM
2018 Mazda 3 SkyActive 2.0
by wolf_06. 01/20/19 12:41 AM
Kendall nitro 70
by Bullwinkle007. 01/19/19 11:11 PM
Dexron HP
by Snagglefoot. 01/19/19 11:11 PM
Ruger American 22 Mag
by TiredTrucker. 01/19/19 11:06 PM
Prestone Dex Cool vs Carquest Dexcool
by A_User55555. 01/19/19 11:05 PM
FRAM end cap differences EG and TG vs XG
by wemay. 01/19/19 09:25 PM
Valvoline modern Engine
by Pinoak. 01/19/19 09:02 PM
30 Vintage Photos
by StevieC. 01/19/19 08:23 PM
Low mileage, when to change oil?
by Metfanant. 01/19/19 08:05 PM
Filter with bypass when OEM has built-in bypass
by rubberchicken. 01/19/19 07:43 PM
Barrett Jackson 2019 Pics
by Nick1994. 01/19/19 05:41 PM
What do y'all do with old car parts?
by qdeezie. 01/19/19 05:11 PM
Diagnosing catalytic converters.
by Tlhfirelion. 01/19/19 04:20 PM
Oil recommendations for GM Vortec 8100
by Dudemanmaximus. 01/19/19 04:14 PM
Leaf Spring Questions- Lots of Questions
by George7941. 01/19/19 04:02 PM
Am I being out of line?
by Chris142. 01/19/19 04:00 PM
dougway, Jetsfan421, Fordman420, 72sbc, ejmiller
66982 Registered Users
35 registered members (c502cid, carlprop, Black_Thunder, Blkstanger, BlakeB, bubbatime, 4 invisible), 882 guests, and 30 spiders.
Topics296,866
Posts4,960,375
Members66,982
Most Online2,688
Jan 19th, 2019
Last time to be PO'd in 2017? shut off valve... #4619708
12/31/17 01:34 PM
12/31/17 01:34 PM
SW Ontario Canada
KGMtech Offline OP
KGMtech  Offline OP
SW Ontario Canada
Had to replace a cracked fuel line in my 1999 Yard King Snowblower with 10HP Tecumseh Snow King. No big deal, remove flywheel shroud, remove plastic tank, etc.
Decided to install a 90 degree fuel shut off valve, got one for $4.50 at Home Depot before Christmas original Yard King never had one from 1999. Got it all set up, fill up the tank with fresh premium (no ethanol) and start up the engine. Leaks gas from the new shut off valve mad . Doesn't leak when put in OFF position, leaks when ON. mad
Are these black plastic with red turn lever things all junk? I can order from Amazon in groups of 3pc or 5pc, which suggests that a fair number are going to be defective from get go?
The defective POS will be returned to HD, but the annoyance of doing the right thing (installing the shut off) is like the expression: "No good deed goes unpunished"
2017.5 Nissan Rogue SV FWD
2013 Nissan Maxima SV
2009 Ford Flex SEL FWD
1984 Yamaha XJ750RL
Re: Last time to be PO'd in 2017? shut off valve... [Re: KGMtech] #4619771
12/31/17 02:22 PM
12/31/17 02:22 PM
WI
HoosierJeeper Offline
WI
My late 80s MTD has a shut off valve from the factory, never leaks, maybe find an MTD one? Tecumseh engine on mine too.
15 Jeep KL Limited V6: Formula Shell 5W20
07 LR3 SE V8: Maxlife 5W30
05 Jeep KJ Limited: PHM 5W30
96 Jeep XJ Country: STP HM 5W30 (winter)
Re: Last time to be PO'd in 2017? shut off valve... [Re: KGMtech] #4619775
12/31/17 02:25 PM
12/31/17 02:25 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
You just got a bad one.
Most work fine.
Genuine Honda ones are expensive, but also the most trouble-free
Re: Last time to be PO'd in 2017? shut off valve... [Re: Linctex] #4619869
12/31/17 03:52 PM
12/31/17 03:52 PM
Storrs, Connecticut
jeepman3071 Offline
jeepman3071  Offline
Storrs, Connecticut
Most work fine.
This. I made the mistake of buying a whole bag of cheap ones on ebay since I often put them on customer machines. BIG mistake. I think out of the whole bag of 15 only about 3 of them didn't leak. Always pay more for the premium ones if you can, sometimes a dollar or two can make a difference. I've used many cheap ones with no issue, but when you do have a problem it is a big mess.
2000 Jeep Cherokee 4.0L (181k) - Pennzoil 10w30, Napa Gold 1516, Magnefine trans filter
2009 BMW 328i (36k) - Castrol Edge Euro 0w40, MANN HU816X
Re: Last time to be PO'd in 2017? shut off valve... [Re: KGMtech] #4619912
12/31/17 04:29 PM
12/31/17 04:29 PM
IL
GimmeTorq Offline
GimmeTorq  Offline
IL
Have similar Arnold one in my riding lawnmower for several years with no issues. Probably a bad one.
2017 Mazda CX-5 Touring AWD 2.5L
2014 Honda CTX700N
2012 Honda CR-V LX 2.4L
2010 Honda Fit 1.5L
2003 Honda Odyssey 3.5L - Traded-in
2002 Nissan Maxima 3.5L - Traded-in
Re: Last time to be PO'd in 2017? shut off valve... [Re: KGMtech] #4620143
12/31/17 09:37 PM
12/31/17 09:37 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
I bought a new B+S valve for the Toro. If I forget to use it the tank will be empty when I go to use it. They are all plastic , but don't leak.
Thick oil is better grin2
Re: Last time to be PO'd in 2017? shut off valve... [Re: KGMtech] #4621766
01/02/18 01:17 PM
01/02/18 01:17 PM
Buffalo, NY
JTK Offline
JTK  Offline
Buffalo, NY
I'm all for the shut-offs you can locate inline in an accessible location. Some of the newer snow engines, with the fuel s/o that threads into the tank are more of a PITA. Takes a bit more to get at them.
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
