Ac Delco oil on Rockauto
by WiskyBadger. 03/21/19 11:09 PM
Old Laptop - Keeps Freezing - Help!
by reemoe2. 03/21/19 09:52 PM
Cinnamon Cake
by StevieC. 03/21/19 09:43 PM
AMALIE OILS
by kstanf150. 03/21/19 09:41 PM
oem filters
by mobilaltima. 03/21/19 09:34 PM
Magna1 10W30
by mobilaltima. 03/21/19 09:32 PM
Found triple threat
by deven. 03/21/19 09:26 PM
Chrysler Valvetrain week??
by clinebarger. 03/21/19 08:50 PM
Lisle funnel for radiator drain & fill
by paulri. 03/21/19 07:45 PM
Rattle in Catalytic Converter 2003 Suburban
by Fitz98. 03/21/19 05:59 PM
Mobil1 5W-30 EP, 8317mi, 2007 Prius Touring, 98133
by DuckRyder. 03/21/19 05:32 PM
Maxima Pro Plus 20/50 syn bike oil
by Truckedup. 03/21/19 04:54 PM
CHAMPION COS 3593A **NEW** CUT OPEN
by 53' Stude. 03/21/19 04:28 PM
NAPA PROSELECT 21348 CUT OPEN
by 53' Stude. 03/21/19 04:21 PM
Atlanta No Nonsense Honda dealer
by DuckRyder. 03/21/19 04:16 PM
Echo (PAS) - Good, Bad, Other?
by GemStater. 03/21/19 04:06 PM
Serpentine Belt - When To Change?
by Propflux01. 03/21/19 03:08 PM
Magnetic Out, ST in at Wally Auto Care Center.
by csandste. 03/21/19 02:26 PM
scottjeffrey, Mowata, LoneWolf04, Paperboy, Flinch
67579 Registered Users
72 registered members (aaronc7, allgm59, 97prizm, Aichiguy, 2010Civic, 7 invisible), 1,252 guests, and 66 spiders.
Topics286,216
Posts4,904,445
Members67,579
Most Online2,967
Mar 10th, 2019
i think i screwed up... #4619633
12/31/17 01:15 PM
12/31/17 01:15 PM
Missouri
gabriel9766 Offline OP
Missouri
I did a trans fluid exchange on my brothers new 08 fusion with the 5 speed and used merconV because the dipstick said M V on the top.... now looking online and tig1 says it takes FNR-5 ATF. did i screw up? shifts and drives fine...
2015 Malibu LT 2.5L PPPP 0w20 46.1K
2007 Escape XLT 3.0L 5Q STHM 5w30/1Q MC full syn 5W20 115K
2010 Fusion SE 2.5L MC 0w20 110K
2008 Escape XLT 2.3L MC 5w30 187K
2007 Fusion SE 2.3L- 173.5K STHM 0W20
Re: i think i screwed up... [Re: gabriel9766] #4619652
12/31/17 01:36 PM
12/31/17 01:36 PM
MIchigan
Warstud Offline
Warstud  Offline
MIchigan
It looks like you put in the wrong fluid. And Ford screwed up putting M V on the dipstick which can be mistaken for Mercon.
Read RF Overlords post>>>>>>
https://bobistheoilguy.com/forums/ubbthreads.php/topics/1677059/1
Re: i think i screwed up... [Re: gabriel9766] #4619673
12/31/17 02:04 PM
12/31/17 02:04 PM
Georgia
Charlie2015 Offline
Charlie2015  Offline
Georgia
Just put some maxlife ATF in it
1998 Honda Accord EX 2.3L Auto (Sold) 214k mi
2009 Scion tC Manual (Daily Driver) 165k mi
Re: i think i screwed up... [Re: gabriel9766] #4619750
12/31/17 03:07 PM
12/31/17 03:07 PM
Cape Cod, MA
RF Overlord Offline
RF Overlord  Offline
Cape Cod, MA
While you might not experience any immediate effect, who knows what the long-term effects will be. If it was MY car, I'd replace the fluid with the correct stuff ASAP.
The FNR5 uses Ford-badged Mobil 3309 which is also sold as Toyota T-IV. That's what I used in my niece's '08 Fusion for many years.
Supercharged '03 Mercury Marauder - Trilogy Motorsports #61
PP 5W-30 / MC FL820S
'04 Grand Marquis LS Limited Edition - daily driver
'00 Grand Marquis GS - bad frame/future to be determined
Re: i think i screwed up... [Re: gabriel9766] #4619754
12/31/17 03:10 PM
12/31/17 03:10 PM
GA
miden851 Offline
miden851  Offline
GA
I have used Castrol, Mobil1 and Red Line ATFs on my car, never had any issues
2008 Mazda6i GT; @215K miles
2016 Honda CR-V EX-L; @40K miles
Re: i think i screwed up... [Re: Warstud] #4619764
12/31/17 03:16 PM
12/31/17 03:16 PM
Missouri
Missouri
Im good basically its a mazda transmission which takes MerconV.
Re: i think i screwed up... [Re: gabriel9766] #4619848
12/31/17 04:27 PM
12/31/17 04:27 PM
New York
NoNameJoe Offline
NoNameJoe  Offline
New York
Hate to break it to you but you are incorrect. The "M V" doesn't stand for Mercon V, it stands for Type M5. You can see this by looking up their MES number (117C as shown on that page).
Mazda has stated that their Type M5 transmission fluid is not Mercon V under bulletin: "CORRECT APPLICATIONS FOR ATF M-V (TYPE M5) AND MERCONŽV AUTO-MATIC TRANSMISSION FLUIDS", which discusses that some of their cars use Mercon V and some use Type M5 and to use the right fluid for the right car.
Quote:
DESCRIPTION
Always be sure to use the correct automatic transmission fluid when replacing ATF. Using the wrong ATF may
cause shift quality complaints or may even damage the transmission.
NOTE:
• ATF M-V (TYPE M5) IS NOT THE SAME FLUID AS MERCONŽV ATF.
• ATF M-V (TYPE M5) HAS A GREATER VISCOSITY THAN MERCONŽV ATF IN LOW TEMPERA-
TURES.
• ATF M-V (TYPE M5) HAS A GREATER ANTI-JUDDER SPECIFICATION THAN MERCONŽV ATF.
CAUTION:
• USING ATF OTHER THAN ATF M-V (TYPE M5) IN AUTOMATIC TRANSMISSIONS
DESIGNED TO USE ATF M-V (TYPE M5) MAY CAUSE SHIFT QUALITY COMPLAINTS.
• USING ATF OTHER THAN MERCONŽV IN AUTOMATIC TRANSMISSIONS DESIGNED TO
USE MERCONŽV MAY CAUSE TRANSMISSION DAMAGE.
2015 Civic LX Coupe
Re: i think i screwed up... [Re: gabriel9766] #4619867
12/31/17 04:52 PM
12/31/17 04:52 PM
USA
ozric Offline
ozric  Offline
USA
Mazda caused all kinds of grief by naming the fluid ATF-MV, which is why they renamed for clarification to ATF-M5 - you'll read all over the internet about people putting Mercon-V in their transmission due to the confusion. If Mazda took the time to create a bulletin about it, might be best to flush the Mercon-V out and put Mazda M5 in.
Re: i think i screwed up... [Re: ozric] #4619931
12/31/17 05:50 PM
12/31/17 05:50 PM
Oshawa, Ontario Canada
JC1 Offline
JC1  Offline
What a bonehead move!
2015 Grand Caravan SXT Plus 5w-20 Valvoline SynPower/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: i think i screwed up... [Re: gabriel9766] #4620001
12/31/17 07:09 PM
12/31/17 07:09 PM
Cape Cod, MA
RF Overlord Offline
RF Overlord  Offline
Cape Cod, MA
No, it does not. It takes Mazda M5...completely different fluid than Ford Mercon V.
Re: i think i screwed up... [Re: RF Overlord] #4620059
12/31/17 08:06 PM
12/31/17 08:06 PM
Missouri
Missouri
Pull this up by the vin on the ford website... MerconV
Re: i think i screwed up... [Re: gabriel9766] #4620075
12/31/17 08:32 PM
12/31/17 08:32 PM
Illinois
tig1 Online content
tig1  Online Content
Illinois
I think you will find that where this says "Motorcraft MV" that's the spec # for the Mazda trans, not Mercon V. The correct ATF for you trans is FNR-5. When I started using M1 ATF it had the Mazda MV rating. A year or so later M1 dropped the Mazda and other OEM ratings. I called Mobil tech and they told me there are too many hoops to jump through to continue all the various OEM ratings. But they also told me the M1 ATF will work great in my FNR-5 spec'd trans, which has been the case for the last 200K.
2007 Ford Fusion 239,000 miles
M1 0-20 EP
2017 Ford Fusion 67K
M1 0-20 EP
M1 ATF and Valvoline LV
M1 10-30 in all OPE
MC filters
Re: i think i screwed up... [Re: tig1] #4620082
12/31/17 08:48 PM
12/31/17 08:48 PM
Missouri
Missouri
ill double check out chart we have in parts on tuesday, but id say the trans shifts better now.
Re: i think i screwed up... [Re: gabriel9766] #4620136
12/31/17 10:27 PM
12/31/17 10:27 PM
Santa Barbara, CA
bdcardinal Offline
bdcardinal  Offline
Santa Barbara, CA
So to throw an absolute wrench in the works, Ford recently had XT-9-QMM5 aka FNR5 fluid, update to Mercon V. Mazda however insists you must use M5 fluid in their 5 speed auto.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: i think i screwed up... [Re: bdcardinal] #4620145
12/31/17 10:47 PM
12/31/17 10:47 PM
Missouri
Missouri
thts what i thought. The chart we have in parts i think said MerconV. The trans i think shifts better. Still does have a slight flare from first to second when cold. Moms trans (6f35) in her fusion has a similar flare from 2nd-3rd when cold.
