Trying to fix chainsaw
by turtlevette
06/23/18 06:48 PM
tire rotation
by marine65
06/23/18 06:48 PM
Reese hitch $30 Walmart YMMV
by pda1122
06/23/18 06:14 PM
Managing Anger During Unexpected Tire Change
by TheLawnRanger
06/23/18 06:14 PM
2016 Honda Pilot appears to be consuming oil
by pilot1226
06/23/18 06:00 PM
New belt squeal cause damage to belt?
by pda1122
06/23/18 05:33 PM
Food Safety - If You Have Children
by Zee09
06/23/18 05:15 PM
Reduce TORQUE to COMPENSATE for lubed threads?
by SumpChump
06/23/18 05:02 PM
Chain cleaning and lube
by dadinfo
06/23/18 04:57 PM
Mobil Delvac 1 ESP 5w40 $23.65 at Walmart
by 71Chevyguy
06/23/18 04:36 PM
diesel oil in older engines- RE: cats etc
by 928
06/23/18 04:35 PM
2011 F-150 Ecoboost timing chain replacement
by 14Accent
06/23/18 04:31 PM
My stash of Kendall GT1 almost gone..
by Vern_in_IL
06/23/18 04:30 PM
mobil 1 rebate check
by Fitter30
06/23/18 03:52 PM
Cab mount failure
by ram_man
06/23/18 03:31 PM
02 Saab aero oil?
by Newuser
06/23/18 03:00 PM
Extend wifi range
by clarkflower
06/23/18 02:05 PM
Under valve cover pics 207,000 miles
by WobblyElvis
06/23/18 01:57 PM
Lease Buyout by Dealer
by Throt
06/23/18 01:52 PM
13 Ford Escape
by RedOak
06/23/18 01:10 PM
bwechols, bowupid, pod423, lemaitrix, azzid0906
65303 Registered Users
79 registered (2015_PSD, 2004tdigls, Balrog006, asiancivicmaniac, AndyB, 10 invisible), 1470 Guests and 50 Spiders online.
65303 Members
67 Forums
285870 Topics
Page 1 of 2 1 2 >
#4619490 - 12/31/17 08:51 AM Cold Weather Oil Flow & MMO
Dufus2 Offline
Loc: Virginia
What is your opinion of adding Marvels Mystery Oil to improve Cold Oil Flow? The first can I read in the 90s said to use 4 oz per quart to improve oil pump-ability in cold weather. Today, the website says to use 10-25% of sump capacity. I like Marvels oil but a lot of people argue it does nothing good.
ASE Certified in Med/Heavy Truck Service including A9
Heavy Equipment Repair, Fleet Maintenance
Real Cars Rattle and Smoke a Little
#4619492 - 12/31/17 08:54 AM Re: Cold Weather Oil Flow & MMO [Re: Dufus2]
CT8 Offline
Loc: Idaho
If you use the incorrect oil viscosity MMO will thin the oil a bit.
"Don't let your preconceived notions get in the way of facts."
Geoff Metcalf
#4619499 - 12/31/17 09:01 AM Re: Cold Weather Oil Flow & MMO [Re: Dufus2]
dlundblad Offline
Loc: Indiana
I recall reading on the bottle (~3 years ago?) that a 5 quart sump could take 1/2 quart at most when the recommended oil is used so 10% sounds about right. An entire quart could be used, but the oil weight should be stepped up a grade. This is where I don't agree with the 25% assuming they want the recommended grade used. How would 4 quarts of 5w30 and 1 quart of MMO flow as opposed to just 5w20? Good question.
I've seen the stuff do some decent cleaning here with shorter OCI's so I'd say it does something.
Edited by dlundblad (12/31/17 09:02 AM)
03 Jeep WJ 4.0 199k Castrol Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 177k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 145k Rotella T5 10w30 Fram TG3980
#4619544 - 12/31/17 10:02 AM Re: Cold Weather Oil Flow & MMO [Re: Dufus2]
oil_film_movies Offline
Loc: MN
People used to put kerosene in their engine oil for very-cold starts, common until about the 1970's when multi-viscosity oils finally got really good to use in the winter.
Its a little risky since visc when HOT drops. Consider your protective KV100 will drop by 10% for 10% MMO or kerosene. Its not quite that bad in practice. You could use a Widman calculator, but just consider worst case is, say, a drop from KV100=9 to KV100=7 for a 10% mix of MMO. Then, you've just dropped 1 whole grade down. I'd safely do maybe 10% in very cold weather. No more.
#4619545 - 12/31/17 10:04 AM Re: Cold Weather Oil Flow & MMO [Re: dlundblad]
Dufus2 Offline
Loc: Virginia
The MSDS shows it has the same naphtha as most penetrating oil products. Its also my understanding it has sulfur as an antiwear additive. In my experience, MMO dissolves gum around the piston rings and loosens up carbon in the valve guides in addition to other areas with limited oil flow. I just added 3-oz per quart due to the very cold weather to prevent battery drain and help with sticktation before my next oil change.. Thanks guys for adding your opinion.
#4619552 - 12/31/17 10:17 AM Re: Cold Weather Oil Flow & MMO [Re: Dufus2]
Donald Offline
Loc: Upstate NY
MMO is an OK cleaning additive but a poor lubricant. It may help cold flow at the expense of proper lubrication.
Synthetic oil does better that conventional oil when it cold.
Use synthetic oil as listed in owners manual in temp compensated oil recommendation chart.
2015 Ford F250 w/Powerstroke
#4619553 - 12/31/17 10:17 AM Re: Cold Weather Oil Flow & MMO [Re: Dufus2]
exShuttlemech Offline
Loc: ST Augustine, FL
I remember from A&P classes at Embry-Riddle back in the '80's, that old piston aircraft engines used to dilute the engine oil with fuel upon shutting down in extremely cold environments.
2010 Rav4 4cyl 131K QSUD 0W20 Baldwin bypass filter
2003 4Runner 4.0L 219K 0W40 M1 Frantz bypass
2007 F150 4.2L 169K 5W30 QSUD
2016 NV2500
2017 RAV4
#4619568 - 12/31/17 10:42 AM Re: Cold Weather Oil Flow & MMO [Re: Dufus2]
69GTX Offline
Loc: Connecticut
Rather than use MMO for its "thin" qualities, why not just run a 0w-20/30? It doesn't have much in the way of a detergent/additives package. Good cleaner though since approx half of it are solvents.
old thread on MMO
2001 Lincoln Cont 4.6L DOHC/ 39K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
#4619570 - 12/31/17 10:43 AM Re: Cold Weather Oil Flow & MMO [Re: Dufus2]
Al Offline
Loc: Elizabethtown, Pa
Welcome to the 70 using MMO. Totally useless product. But hey..it helps the economy so buy it.
#4619576 - 12/31/17 11:01 AM Re: Cold Weather Oil Flow & MMO [Re: Al]
Bluestream Offline
Loc: Waterloo, ON
exactly
2000 VW Beetle 1.8T M5
2000 Ford Explorer 4.0 4X4
1991 BMW 735iL
"A fool and his money are soon parted" - Thomas Tusser
#4619577 - 12/31/17 11:04 AM Re: Cold Weather Oil Flow & MMO [Re: Dufus2]
Artem Offline
Loc: Florida
Sooooo.... the OP is worried about cold flow (I'm assuming for engine protection) yet is willing to pour in a "Mystery Oil" in hopes of achieving better protection??? Or just better flow at the expense of protection??
Why not just use a high quality oil for winter? It's been shown they flow just fine at insanely freezing temps, so what's the problem? Why add a snake oil? Is there data to show it helps? Why don't you put a cup of oil outside in the cold next to a cup of the same oil with your mystery snake oil added at the recommended amount and see what flows better in the AM? Wouldn't that tell you more info then a bunch of random idiotic comments of what people did in the 70s, etc? It's 2018 and NOTHING needs to be added to SN spec oil to help it flow at -40F. What utter nonsense.
Be sure to post the results of your backyard testing. I'd love to know the results.
2014 Mazda 3 Hatch 2.0L & 6spd - Idemitsu 0w20 Synthetic @ $0.75 a quart.
#4619586 - 12/31/17 11:13 AM Re: Cold Weather Oil Flow & MMO [Re: Dufus2]
Rolla07 Offline
Loc: MTL, CANADA
In virginia you dont need anything to improve flow. Modern oils are more than capable of handling low temps. No additives are needed today. I use 0w20 full synthetic oil and if its 0 Farenheit or lower just use a block heater. Much better than playing with oil chemistry. Ive had my car 7 years and always parked outside. I installed a block heater only recently and the car has always started without issue in temps down to -22 F. An old UOA I did showed very low wear numbers, thats all I need to see to keep using only a good full syn oil.
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
#4619600 - 12/31/17 11:26 AM Re: Cold Weather Oil Flow & MMO [Re: Rolla07]
JC1 Online   content
Loc: Oshawa, Ontario Canada
As others have stated, use a good quality synthetic for those cold starts.
Save the MMO for cleaning. I have some MMO left, bought a one gallon jug a few years back at WM.
2015 Grand Caravan SXT Plus 5w-20 PPPP/Wix Filter
1997 Honda Civic CX 5w-30 PPPP/Mahle Filter
#4619616 - 12/31/17 11:47 AM Re: Cold Weather Oil Flow & MMO [Re: Donald]
BrocLuno Online   content
Loc: Kalifornia Kollective
Not sure I agree ... I have been using MMO as rust preventative and slow-soak penetrating oil for about 50 years. Seems to lubricate very well. I have it trigger pump oil cans around the place. Use it on rusty hinges and the like, and they stay oily a long time - turn smooth, etc. Seems to lube well for a thin oil smile
It'll definitely thin out heavier motor oils, if you need to for winter. And is a better lube, by far, than Kerosene ... Just depends on what's in the sump right now ... Tossing a quart or two of MMO into a fresh'ish batch of 20W-50 or SAE 40 in a tractor will help it start and run better out in the fields in winter cold. Of course they are not running anywhere 200*F (+) like many modern engines ... I think it all depends on what your Op Temp is and if you can even get it there ...
Edited by BrocLuno (12/31/17 11:52 AM)
#4619628 - 12/31/17 12:04 PM Re: Cold Weather Oil Flow & MMO [Re: Dufus2]
Yah-Tah-Hey Offline
Loc: Columbus,Nebraska
Use a synthetic 0W-20 oil. No sense throwing your $$ down a rathole.
Page 1 of 2 1 2 >
