Storing extension ladded in garage?
by maverickfhs
06/18/18 08:27 AM
Do you let your tool batteries go dead in storage
by Snagglefoot
06/18/18 07:20 AM
BITOG using excessive CPU power?
by Kibitoshin
06/18/18 05:10 AM
Any news on what happened to this plane?
by Exhaustgases
06/18/18 02:36 AM
E4OD fluid ?
by Exhaustgases
06/18/18 02:23 AM
Update password ?
by meadows
06/17/18 11:59 PM
Delayed Sleep Phase Disorder
by Reddy45
06/17/18 11:56 PM
Nissan DLR put 0w20 in car that specs 5w30. worry?
by CrAlt
06/17/18 10:40 PM
revive Nicd battery
by Donald
06/17/18 10:27 PM
Need help finding an apartment for friend
by RazorsEdge
06/17/18 10:07 PM
ceratec with redline 5w30?
by 08z06
06/17/18 09:53 PM
does your COMCAST modem have weak wifi??
by edwardh1
06/17/18 09:50 PM
I hate stuck thermostats
by jakewells
06/17/18 09:49 PM
Mag1 75w90
by SavagePatch
06/17/18 09:32 PM
Old batteries at HD
by bbhero
06/17/18 09:27 PM
Buying a CPO Toyota - still get inspected?
by Parlay_Slow
06/17/18 09:08 PM
Water Pump Paper Gasket With RTV? Longevity?
by nobb
06/17/18 08:22 PM
Who makes Briggs & Stratton oil?
by spk2000
06/17/18 08:13 PM
Shure stylus replacement
by aquariuscsm
06/17/18 07:54 PM
Any 'crazy UCL overdose' fans out there?
by addyguy
06/17/18 07:11 PM
Orion62, Revd, blinky1041, mostdecent, T1TN
65261 Registered Users
72 registered (Artem, andyd, badtlc, AandPDan, 2K2AcuraTL, 46Harry, 8 invisible), 1393 Guests and 40 Spiders online.
65261 Members
67 Forums
285506 Topics
Page 1 of 3 1 2 3 >
#4619227 - 12/30/17 09:22 PM 98 Expedition - air in cooling system?
Fitz98 Offline
Loc: Florida
I have a 98 Expedition 5.4 in which I just changed the heater core.
All seems to be working fine, but when I shut it down, it makes a running water sound at the heater core. It sounds like a babbling brook or as if you turned a water bottle upside down to empty it.
It makes the percolating sound for about 30 seconds, almost as if the coolant is settling, or emptying from the core itself.
There are no leaks anywhere and my fluid level remains constant after running many heat cycles.
It seems to me as if air may be trapped.
I have done many burping techniques, but the situation remains the same. It is more noticeable if I shut down while the heater blower is running, than it is if I shut down with the fan off. With the fan off, the sound is still there, but it is slight and subtle.
#4619254 - 12/30/17 10:06 PM Re: 98 Expedition - air in cooling system? [Re: Fitz98]
Linctex Offline
Loc: Waco, TX
In time, the air should find its way to the coolant expansion tank.
Does the heater work?
#4619263 - 12/30/17 10:17 PM Re: 98 Expedition - air in cooling system? [Re: Fitz98]
thastinger Offline
Loc: VA
Did you replace the hoses as well? The factory hose has a flow restrictor in it and some of the cheaper aftermarket hoses don't have the flow restrictor built into them.
#4619266 - 12/30/17 10:21 PM Re: 98 Expedition - air in cooling system? [Re: Fitz98]
Fitz98 Offline
Loc: Florida
Yes, heater works.
My biggest concern is electrolysis, I can live with the sound upon shutdown, but it does not seem normal.
I replaced one heater core years ago in the same vehicle (with aftermarket core, this one is from dealer)
I had the same symptoms last time and after some time, the outlet tube developed leaks, upon removal, I see pinholes on 1 tube where quick connect fitting was. Not sure if electrolysis was to blame, or cheaper construction of heater core from after market source.
Anyone have a burping procedure for this vehicle that works, most videos on line have a radiator cap, this one just has reservoir bottle
#4619267 - 12/30/17 10:24 PM Re: 98 Expedition - air in cooling system? [Re: thastinger]
Fitz98 Offline
Loc: Florida
I only replaced 4" of hose from where previous mechanic bypassed heater core to the heater core connections.
I used a coupler from the factory existing hoses and used factory ends to complete the install
All is the same as original with regards to hoses, except for the connectors
#4619268 - 12/30/17 10:27 PM Re: 98 Expedition - air in cooling system? [Re: Fitz98]
14Accent Offline
Loc: MN
Try jacking\lifting the front end about 3 feet with the expansion tank cap off and the engine running. Give it 20 minutes with the stat open while you have it in the raised position. Should clear right up.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
#4619274 - 12/30/17 10:47 PM Re: 98 Expedition - air in cooling system? [Re: 14Accent]
Fitz98 Offline
Loc: Florida
I understand the concept, but can't quite figure out how to get a 3 foot front lift at home.
I live in Florida, everything is flat our biggest hill is the garbage dump.
#4619304 - 12/30/17 11:56 PM Re: 98 Expedition - air in cooling system? [Re: Fitz98]
Chris142 Online   content
Loc: Deplorable in apple valley, ca
Check for excessive electrolisis in the coolant with a volt meter. We have had good luck with putting zinc in the overflow bottle
02 Wrangler durablend 10w40
87 F250 traveler 15w40
04 Tahoe super-s 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
#4619310 - 12/31/17 12:09 AM Re: 98 Expedition - air in cooling system? [Re: Chris142]
Fitz98 Offline
Loc: Florida
Can you expand on the electrolysis testing procedure?
That is my biggest concern, since I don't ever want to have to change this heater core again plus I don't think my plastic dash parts can handle any more, as it is, I spent days at the junk yard salvaging dash parts to replace all the cracked and broken pieces from removal...age is making it too brittle
#4619366 - 12/31/17 03:46 AM Re: 98 Expedition - air in cooling system? [Re: Fitz98]
Black_Thunder Offline
Loc: Wisconsin
I dont' think you need to lift it 3 ft in the air, but if you could get a pair of ramps like rhino ramps or something that get the front up high enough that the air would work itself out.
or you could always drive it up on ramps and let some air out of the tires for a little extra incline.
I replaced a heater core on my brother's 02 f150 a few years back and i guess i didn't recall hearing any noises afterwards i just filled it up the top and drove it around and rechecked the level etc and the core has been good ever since.
I'd buy Callahan autoparts if I could.
#4619449 - 12/31/17 07:52 AM Re: 98 Expedition - air in cooling system? [Re: Fitz98]
Trav Offline
Loc: MA, Mittelfranken.de
Vacuum filling is the answer to your problem but you will need a compressor (a small one will work) and the tool.
#4619529 - 12/31/17 09:40 AM Re: 98 Expedition - air in cooling system? [Re: Fitz98]
https://youtu.be/6rc9t3Ve_bI
#4619573 - 12/31/17 10:51 AM Re: 98 Expedition - air in cooling system? [Re: Fitz98]
69GTX Offline
Loc: Connecticut
Cycling rpm up and down could help. I'm surprised they don't have the high point piping vent on this engine as they did for the 4.6l engines of that same era. I agree with the rhino ramps, then running the engine with the radiator cap off for a while, while cycling rpms. The car being on level ground with a reservoir about the same height as your upper coolant/heater piping makes for inefficient venting.
Expedition gurgling problem following heater core/radiator replacement
2001 Lincoln Cont 4.6L DOHC/ 39K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
#4619691 - 12/31/17 01:22 PM Re: 98 Expedition - air in cooling system? [Re: Trav]
Fitz98 Offline
Loc: Florida
I have a compressor, how do you do that vacuum filling?
#4619695 - 12/31/17 01:25 PM Re: 98 Expedition - air in cooling system? [Re: Fitz98]
Fitz98 Offline
Loc: Florida
I tried again today, should the reservoir bottle coolant get warm? I would think it should.
Upper hose is hot, heater core hoses warm, but reservoir bottle is cool.
I tried reving up for 10 minutes, still no hot fluid in bottle.
Car is jacked up on drivers side with fluid level higher than heater core hoses
Page 1 of 3 1 2 3 >
