New Tire Cracking
by robd. 12/12/18 04:43 PM
SAR B6P - Thoughts?
by 28oz. 12/12/18 03:59 PM
Time to sell the 1-ton Dually
by 02SE. 12/12/18 03:55 PM
Shell Rotella Grease
by WMW0505. 12/12/18 02:27 PM
Need to add attic ladder in stairwell
by Klutch9. 12/12/18 12:51 PM
Mystik JT-8 15w40, 2015 RAM EcoDiesel, 4,995 mi
by SavagePatch. 12/12/18 12:45 PM
Fram Tough Guard Air Filters at Rock Auto
by Snagglefoot. 12/12/18 12:42 PM
Electrical contact cleaner
by CELICA_XX. 12/12/18 12:32 PM
5w-30 in 277k mile chevy 350 tbi
by dogememe. 12/12/18 12:22 PM
voltage test for coolant condition
by NissanMaxima. 12/12/18 12:17 PM
paying Premiun for the name(infiniti/nissan
by 2008wrx. 12/12/18 11:25 AM
POE oil (R-410a)
by WyrTwister. 12/12/18 09:44 AM
Any Volvo Owners, need some help!
by LazyDog. 12/12/18 09:34 AM
NOACK & Sheer
by WyrTwister. 12/12/18 09:34 AM
Rotary help. 2010 series 2 RX8
by TinyVoices. 12/12/18 08:32 AM
Can you mathematically estimate top speed?
by KCJeep. 12/12/18 08:06 AM
2019 GM 6.2 AFM
by XL1200RFan. 12/12/18 07:32 AM
Dodge Challenger R/T Tips and Tricks?
by LoneRanger. 12/12/18 06:02 AM
jefe_de_estado, CM613, Geardaddies, 01ws666, ariefnrst
66660 Registered Users
106 registered members (53' Stude, barryh, Audios, AZjeff, 69GTX, 9 invisible), 1,915 guests, and 35 spiders.
Topics294,989
Posts4,925,528
Members66,660
Most Online2,553
Oct 27th, 2018
Compressed air hose - leak at ferrule/barb #4619133
12/30/17 07:29 PM
12/30/17 07:29 PM
Where the wind comes sweepin'
Reddy45 Offline OP
Reddy45  Offline OP
I have a nice 3/8" Goodyear air hose, but it seems that air can leak out from near the ferrule if I bend the hose too much at that spot. Is this normal? I would imagine if the barbed fitting is snug enough inside the hose, then no air should leak.
I looked up methods for repair, but the tool for crimping the ferrule is expensive.
What type of local business would I approach if I wanted a new barb/ferrule installed? I can't imagine it would cost too much.
Re: Compressed air hose - leak at ferrule/barb [Re: Reddy45] #4619145
12/30/17 07:38 PM
12/30/17 07:38 PM
NE,Ohio
Rand Online content
Rand  Online Content
NE,Ohio
put a hose clamp on it or 2
edit: just read its the crimped on kind.
you can cut that off get a replacement end and put a hose clamp on it.
Re: Compressed air hose - leak at ferrule/barb [Re: Reddy45] #4619153
12/30/17 07:48 PM
12/30/17 07:48 PM
Fort Worth, Texas
clinebarger Offline
clinebarger  Offline
Fort Worth, Texas
A hydraulic hose shop may be able to help you. This would have to be a really nice hose for me not to split the crimp with a cut-off wheel, Cut off the hose a few inches & use a Ear Clamp. Some thick Heat Shrink over the clamp is a nice touch.
2001 Chevy Camaro L92/4L80E
Re: Compressed air hose - leak at ferrule/barb [Re: clinebarger] #4619217
12/30/17 09:07 PM
12/30/17 09:07 PM
Idaho
CT8 Offline
CT8  Offline
Idaho
This is what to do !!!! Or a hose clamp.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Compressed air hose - leak at ferrule/barb [Re: Reddy45] #4619249
12/30/17 09:55 PM
12/30/17 09:55 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Carefully slit the crimp with a dremel, and add a clamp
Re: Compressed air hose - leak at ferrule/barb [Re: Reddy45] #4619264
12/30/17 10:20 PM
12/30/17 10:20 PM
VA
thastinger Offline
thastinger  Offline
VA
hydraulic shop can crimp a new clamp on it but you can probably just cut the old clamp with a rotary tool and replace with a worm gear clamp
Re: Compressed air hose - leak at ferrule/barb [Re: Reddy45] #4619272
12/30/17 10:46 PM
12/30/17 10:46 PM
NJ
JLawrence08648 Offline
NJ
East to repair yourself. As I'm writing this I don't have a link or pic. There's an insert you put inside the hose then screw an outer thing over the too of this. I use to repair my hydraulic hoses on my snow plow using these and worked well.
Re: Compressed air hose - leak at ferrule/barb [Re: Reddy45] #4619315
12/31/17 12:18 AM
12/31/17 12:18 AM
'Stralia
Shannow Online content
Shannow  Online Content
'Stralia
Air hose...cut it and clamp it.
Down here, the hydraulic shops won't repair a hose that they don't have the providence of (aka didn't sell it to you).
The crimp fittings and the barb that goes in are a weak point for the hoses
